Kernel: 5.18.0-1-mainline arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-mainline
root=UUID=53e270ad-dfd5-4874-a125-69d21ada6b8d rw [email protected]
sysrq_always_enabled=1 amdgpu.ppfeaturemask=0xffffffff nowatchdog
amdgpu.aspm=0 pcie_aspm=off
Type: Desktop Mobo: ASRock model: X470 Taichi serial: <superuser required>
UEFI: American Megatrends v: P4.86 date: 01/27/2022
Device-2: ps-controller-battery-4c:b9:9b:1b:68:38 model: N/A serial: N/A
charge: N/A status: discharging
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 4045 high: 4050 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4048 2: 4047
3: 4050 4: 4039 5: 4050 6: 4046 7: 4048 8: 4050 9: 4050 10: 4015 11: 4050
12: 4050 bogomips: 86438
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M]
vendor: Gigabyte driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,HDMI-A-2
bus-ID: 0f:00.0 chip-ID: 1002:73df class-ID: 0300
compositor: kwin_x11 driver: X: loaded: amdgpu gpu: amdgpu display-ID: :0
Screen-1: 0 s-res: 6400x2160 s-dpi: 96 s-size: 1691x571mm (66.57x22.48")
s-diag: 1785mm (70.27")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left
model: LG (GoldStar) HDR WFHD serial: <filter> built: 2021 res: 2560x1080
hz: 60 dpi: 81 gamma: 1.2 size: 798x334mm (31.42x13.15")
diag: 869mm (34.2") modes: max: 2560x1080 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Samsung
serial: <filter> built: 2019 res: 3840x2160 hz: 60 dpi: 52 gamma: 1.2
size: 1872x1053mm (73.7x41.46") diag: 1093mm (43") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
OpenGL: renderer: AMD Radeon RX 6700 XT (navy_flounder LLVM 13.0.1 DRM
3.46 5.18.0-1-mainline)
v: 4.6 Mesa 22.1.0 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0f:00.1 chip-ID: 1002:ab28
Sound Server-1: ALSA v: k5.18.0-1-mainline running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 09:00.0
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Edimax Bluetooth Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-8:4 chip-ID: 7392:c611 class-ID: e001 serial: <filter>
Local Storage: total: 2.96 TiB used: 3.2 TiB (108.1%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung
model: SSD 970 EVO 250GB size: 232.89 GiB block-size: physical: 512 B
rev: 2B2QEXE7 temp: 37.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7
temp: 36.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164
type: HDD rpm: 7200 serial: <filter> rev: CC41 scheme: GPT
used: 777.84 GiB (83.5%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 16.3 MiB (5.5%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 31.27 GiB used: 89 MiB (0.3%) priority: 100
System Temperatures: cpu: N/A mobo: 0.0 C gpu: amdgpu temp: 54.0 C
mem: 56.0 C
Fan Speeds (RPM): fan-3: 0 fan-5: 0 gpu: amdgpu fan: 0
Processes: 449 Uptime: 17m wakeups: 5 Memory: 31.27 GiB
used: 13.28 GiB (42.5%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 2334 lib: 582 flatpak: 0
Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: alacritty
inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-05-22
Last full system update: 2022-05-27
basically, this is a continuation of Radeon 6700xt performance issues on garuda after switching from 1080 - #10 by zany130 originally I though just disabling mangohud vsync and fps settings would fix my issues but I was wrong and my issue persists.
I am having problems getting it to work correctly on any game I have tried (tomb raider, trails of cold steel 3, GTAV, and a hat in time.
On X I get really bad tearing regardless of vsync unless I run xrandr --output HDMI-A-0 --set TearFree on (or use an xorg config to set it permanently which is what I am doing now) but then that introduces stuttering (tried lowering graphical settings to see if that helps and it does not, it stutters regardless of gpu load)
on Wayland tearing is fixed but I get stuttering
I tried using corctl to set the performance mode to high and also added amdgpu.ppfeaturemask=0xffffffff to my grub settings and no dice.
also found this issue which seems to be related? As Im using a fps limiter (although running uncapped also gives some stuttering issues) power saving too agressive on RX 6800, causes stuttering with fps limiters (#1500) ยท Issues ยท drm / amd ยท GitLab
on Windows my GPU works without issues so I don't think its defective hardware.
Any help would be greatly appreciated
I have tried different kernels , also tried setting the gpu min clocks to 100 mhz less then its max clocks in corectl to force the gpu into higher frequencies. Tried with and without gamescope to see if that would maybe help (edited)
