Hi everyone,
I'm trying to get Quod Libet working. It has worked on my system before, but it broke a few months ago. I get the following output:
$ env G_MESSAGES_DEBUG=all quodlibet --run
(quodlibet:164173): GLib-GIO-DEBUG: 20:45:09.860: _g_io_module_get_default: Found default implementation local(GLocalVfs) for ‘gio-vfs’
(quodlibet:164173): Gtk-WARNING **: 20:45:09.886: Theme parsing error: gtk-dark.css:5823:26: '-shadow' is not a valid color name
(quodlibet:164173): Gtk-WARNING **: 20:45:09.886: Theme parsing error: gtk-dark.css:5826:14: not a number
(quodlibet:164173): Gtk-WARNING **: 20:45:09.886: Theme parsing error: gtk-dark.css:5827:13: not a number
(quodlibet:164173): Gtk-WARNING **: 20:45:09.886: Theme parsing error: gtk-dark.css:5828:11: Expected a length
(quodlibet:164173): GLib-GIO-DEBUG: 20:45:09.929: _g_io_module_get_default: Found default implementation dconf(DConfSettingsBackend) for ‘gsettings-backend’
(quodlibet:164173): dconf-DEBUG: 20:45:09.929: watch_fast: "/org/appmenu/gtk-module/" (establishing: 0, active: 0)
(quodlibet:164173): dconf-DEBUG: 20:45:09.929: unwatch_fast: "/org/appmenu/gtk-module/" (active: 0, establishing: 1)
(quodlibet:164173): dconf-DEBUG: 20:45:09.931: watch_established: "/org/appmenu/gtk-module/" (establishing: 0)
(quodlibet:164173): dconf-DEBUG: 20:45:09.931: watch_fast: "/org/appmenu/gtk-module/" (establishing: 0, active: 0)
(quodlibet:164173): dconf-DEBUG: 20:45:09.931: unwatch_fast: "/org/appmenu/gtk-module/" (active: 0, establishing: 1)
(quodlibet:164173): dconf-DEBUG: 20:45:09.932: watch_established: "/org/appmenu/gtk-module/" (establishing: 0)
** (io.github.quodlibet.QuodLibet:164173): WARNING **: 20:45:11.523: Failed to load shared library 'libdee-1.0.so.4' referenced by the typelib: libicui18n.so.70: cannot open shared object file: No such file or directory
E: 1.892: errorreport.main.errorhook: types.py:247:__init__: TypeError: must be an interface
I searched the web, but I couldn't find anything related to the error. Can somebody help figure this out?
Kernel: 5.18.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=220d401c-e739-49f7-b37b-c9837e340ce5 rw rootflags=subvol=@
loglevel=3 pci=noaer ibt=off
Type: Laptop System: HP product: HP Pavilion Gaming Notebook
Mobo: HP model: 816B v: 91.1E serial: <superuser required> UEFI: Insyde
v: F.91 date: 08/20/2019
ID-1: BAT0 charge: 27.5 Wh (100.0%) condition: 27.5/27.5 Wh (100.0%)
volts: 16.4 min: 14.8 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
Info: model: Intel Core i7-6700HQ bits: 64 type: MT MCP arch: Skylake-S
gen: core 6 built: 2015 process: Intel 14nm family: 6 model-id: 0x5E (94)
stepping: 3 microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1703 high: 2168 min/max: 800/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 1927 2: 2168 3: 1544
4: 1602 5: 1958 6: 1182 7: 1655 8: 1592 bogomips: 41599
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling
Device-1: Intel HD Graphics 530 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: HDMI-A-1,eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:191b
Device-2: NVIDIA GM107M [GeForce GTX 950M] vendor: Hewlett-Packard
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:139a class-ID: 0302
Device-3: Intel RealSense 3D Camera (Front F200) type: USB
driver: uvcvideo bus-ID: 2-3:2 chip-ID: 8086:0a66 class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
s-diag: 1245mm (49.01")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,right
model: Dell S2722DGM serial: <filter> built: 2021 res: 2560x1440 hz: 60
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-2: eDP-1 pos: primary,left model: Samsung 0x5844 built: 2015
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 22.1.4
direct render: Yes
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.18.16-zen1-1-zen running: yes
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 08:00.0 chip-ID: 10ec:b723
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 09:00.0 chip-ID: 10ec:8136
IF-ID-2: br-6d1386589274 state: down mac: <filter>
IF-ID-3: docker0 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-4: veth8a05746 state: up speed: 10000 Mbps duplex: full
mac: <filter>
bus-ID: 1-7:3 chip-ID: 0bda:b006 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 1.03 TiB used: 888.64 GiB (84.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZNLF128HCHP-000H1
type: SSD serial: <filter> rev: 1H1Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ01ABD100
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 2C scheme: GPT
ID-1: / raw-size: 55.99 GiB size: 55.99 GiB (100.00%) used: 49.48 GiB
(88.4%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 81.6 MiB
(31.9%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 55.99 GiB size: 55.99 GiB (100.00%) used: 49.48 GiB
ID-4: /var/log raw-size: 55.99 GiB size: 55.99 GiB (100.00%) used: 49.48
GiB (88.4%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-5: /var/tmp raw-size: 55.99 GiB size: 55.99 GiB (100.00%) used: 49.48
ID-1: swap-1 type: zram size: 15.47 GiB used: 4.06 GiB (26.3%)
ID-2: swap-2 type: partition size: 4.88 GiB used: 989.4 MiB (19.8%)
priority: -2 dev: /dev/sdb5 maj-min: 8:21
System Temperatures: cpu: 44.0 C pch: 45.5 C mobo: N/A
Processes: 366 Uptime: 9h 7m wakeups: 60 Memory: 15.47 GiB used: 10.98 GiB
(71.0%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 Packages: 1659 nix-default: 45 nix-sys: 0 nix-usr: 0
pacman: 1614 lib: 378 Shell: fish v: 3.5.1 running-in: konsole inxi: 3.3.20
Garuda (2.6.5-1):
System install date: 2022-04-24
Last full system update: 2022-08-06
Is partially upgraded: Yes
