Question about when the next Garuda release will be
Just out of curiosity, is there gonna be another release from the garuda team this year still ?
Know you guys usually only do 1 release, mostly in the last months, but this year it came early because of plasma 6, so the thought crossed my mind.
Cheers !
I mean its a arch based distro an always rolling so its just a update. Though with all the backend changes with arch an pacman an all that it might be nice for just a new stable image.
One zen an one LTS since that seems to be a thing now.
Well, it’s always up-to-date, it would just reduce the effort of a larger (garuda-update) download amount.
You are talking about dragonized here, there are no other LTS versions apart from Xfce. :slight_smile:
I would be happy to build new ISO’s if testers could be found who would install them on hardware, although at the moment we probably have to consider other than just the Ventoy variant, i.e. dd etc…
There seem to be problems with Ventoy.
Our small team does not only have Garuda in mind, it also has, I hope :wink: , a private life.
The more people help, the faster we can simplify the life of all new users, the rest is always up-to-date anyway. Always keep an eye on /etc/skel , and the forum.
You can’t compare a rolling distribution with M$ or Ubuntu, Mint, MX Linux, where an upgrade is necessary every year.
just out of curiosity, because its a software that I use, whats the problems with ventoy ?
It doesn’t install the ISO :slight_smile: ,
but it varies from user to user or hardware to hardware or whatever.
IDK why it doesn’t work anymore. I think we need a ventoy update.
Has anyone reported the hit or miss situation to the devs? As you said it works for some and not others. I have yet to have a issue with Ventoy, but it’s probably past due for a update since it’s been on 1.0.99 for awhile now.
I offered to help but no-one asked me…
Daily Driver is Garuda Dr460nized.
(Fully up to date, no ignores or errors)
I also have two or three Laptops running various versions of Hyprland.
I have a spare notebook too if you need help testing anew ISO in the future.
I know that new releases are not needed in rolling releases every year, I manly enjoy them to display new features to new users and promote the distro. The birds of prey one with kde 6 and the new firedragon was a great one !
Yes i can help out here too, both on a desktop, and a laptop computer, if there is need.
FWIW, I’ve never had the .tar not work. Just open it and run it that way. I’ve had not great luck with the AUR version over the years. Just something people could try if their having issues with it. It was not the most useful thing until I started actually getting it from them.
Translation problem?
Ventoy starts, but the installation of ISOs fails.
No. I was saying the AUR version I’ve had problems with. Never the actual offering from them. Maybe it’s an AUR thing :wink:
In chaotic-aur, you only build what is currently available on AUR.
It should be up-to-date. If there is something newer on their homepage that works, I don’t understand anything anymore :crazy_face:
Maybe it differs on different hardware???
But it’s nice to see that you still like my avatar for you :hugs: :hugs:
I’ll test now to see what I get cause I just updated the ISO’s I have in Ventoy. I’ll test Reborn and Cachy.
That’s nice of you, more helpful would be if KDE Garuda dragonized can be installed . :slight_smile:
Ask and you shall receive. The fresh install of Garuda I did not even a week ago to see if I could get rid of the monitor issue I mentioned in my one thread was done using the current Ventoy and It installed perfectly. All in all it was under five minutes til I was on the installed desktop. Before I replace the ISO’s on it I created a fresh Ventoy key so it’s less than two weeks old itself.
Thank you very much, btw. what is a new ventoy key?
sudo ventoy -l /dev/sda
      Ventoy: 1.0.99  x86_64
      longpanda admin@ventoy.net
      https://www.ventoy.net
Ventoy Version in Disk: 1.0.98
Disk Partition Style  : MBR
Secure Boot Support   : YES
 ╭─sgs@y7p in ~ as 🧙 took 94ms
 🕙 17:52:14
 ╰─λ sudo ventoy -u /dev/sda
Upgrade operation is safe, all the data in the 1st partition (iso files and other) will be unchanged!
Update Ventoy  1.0.98 ===> 1.0.99   Continue? (y/n) y
esp partition processing ...
Update Ventoy on /dev/sda successfully finished.
I used the install instead of update to wipe and reinstall Ventoy.
Ventoy Version in Disk: 1.0.99
Disk Partition Style  : GPT
Is this the 240428 ISO? I think Ventoy is broken again on the new ISOs (from here: https://iso.builds.garudalinux.org/iso/garuda/).
Yea it is. Do you want me to test on the dev version?
