So I was thinking to try tiling wm. So I thought to try sway but, I was getting this error: I can't install Wayfire, could not get it resolved by the solutions (same error in virtualbox as well as on real hardware)
Then I tried qtile but get this error in virtualbox:
It's not much to write the error its just in the config file.(And got same error when tried on real hardware.)
Iso's name are:
garuda-qtile-linux-zen-210917.iso
garuda-sway-linux-zen-210914.iso
System: Kernel: 5.14.5-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=f843752b-be3a-4b0e-8dfb-b51dbeb30c59
systemd.unified_cgroup_hierarchy=1 loglevel=3 mitigations=off
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1 Distro: Garuda Linux
Machine: Type: Desktop System: LENOVO product: Lenovo H430 v: Lenovo Product serial: <filter>
Mobo: LENOVO model: MAHOBAY serial: <filter> BIOS: LENOVO v: ECKT21A date: 07/11/2012
CPU: Info: Dual Core model: Intel Pentium G640 bits: 64 type: MCP arch: Sandy Bridge family: 6
model-id: 2A (42) stepping: 7 microcode: 2F cache: L2: 3 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 11175
Speed: 2306 MHz min/max: 1600/2800 MHz Core speeds (MHz): 1: 2306 2: 2413
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable, SMT disabled
Type: mds status: Vulnerable; SMT disabled
Type: meltdown status: Vulnerable
status: Vulnerable: __user pointer sanitization and usercopy barriers only; no swapgs barriers
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: Lenovo
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0102 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: gnome-shell driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display-ID: :1 screens: 1
Monitor-1: VGA1 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.1x9.1") diag: 470mm (18.5")
OpenGL: renderer: Mesa DRI Intel HD Graphics 2000 (SNB GT1) v: 3.3 Mesa 21.2.1 compat-v: 3.0
direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.14.5-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169
v: kernel port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Drives: Local Storage: total: 232.89 GiB used: 61.46 GiB (26.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD2500AAKX-19U6AA0 size: 232.89 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1H15 scheme: MBR
Partition: ID-1: / raw-size: 224.68 GiB size: 224.68 GiB (100.00%) used: 61.46 GiB (27.4%) fs: btrfs
dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 224.68 GiB size: 224.68 GiB (100.00%) used: 61.46 GiB (27.4%) fs: btrfs
ID-3: /var/log raw-size: 224.68 GiB size: 224.68 GiB (100.00%) used: 61.46 GiB (27.4%)
fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-4: /var/tmp raw-size: 224.68 GiB size: 224.68 GiB (100.00%) used: 61.46 GiB (27.4%)
ID-1: swap-1 type: zram size: 3.73 GiB used: 344 MiB (9.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 8.21 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
maj-min: 8:2
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C
Info: Processes: 216 Uptime: 26m wakeups: 0 Memory: 3.73 GiB used: 1.55 GiB (41.7%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1224 lib: 311
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: gnome-terminal inxi: 3.3.06
