Hi, I'm new to Garuda and tryng out the Sway edition. After a fresh install, it seems I cannot start a few Qt-applications. When clicking their icons, a text box appears where I'm to enter password but nothing happens.
Any suggestions as to solve this?
When trying from terminal, I get the following:
$ lxqt-sudo btrfs-assistant
"Icon Theme not set. Fallbacking to Oxygen, if installed"
"Fallback Icon Theme (Oxygen) not found"
kf.windowsystem: Could not find any platform plugin
Authorization required, but no authorization protocol specified
qt.qpa.xcb: could not connect to display :0
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
/usr/bin/btrfs-assistant: line 22: 10034 Aborted (core dumped) btrfs-assistant-bin ${params}
here is the output from garuda-inixi:
root=UUID=195d67a3-d3a0-4c73-9415-42c06def7a67 rw rootflags=subvol=@
quiet
cryptdevice=UUID=6fd2cdb1-7e23-446e-9ed8-45f0eac1c05a:luks-6fd2cdb1-7e23-446e-9ed8-45f0eac1c05a
root=/dev/mapper/luks-6fd2cdb1-7e23-446e-9ed8-45f0eac1c05a quiet splash
Desktop: sway v: 1.7 info: waybar vt: 1 dm: greetd Distro: Garuda Linux
Type: Desktop System: Exertis_CapTech product: N/A v: N/A
Mobo: ASUSTeK model: ROG STRIX X399-E GAMING v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1206
date: 07/15/2021
Info: model: AMD Ryzen Threadripper 1900X bits: 64 type: MT MCP MCM
arch: Zen family: 0x17 (23) model-id: 1 stepping: 1 microcode: 0x8001137
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 dies: 2 smt: enabled
cache: L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1931 high: 2553 min/max: 2200/3800 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2123 2: 1815
3: 1716 4: 1715 5: 1889 6: 1889 7: 1889 8: 1927 9: 2553 10: 1992 11: 1842
12: 1789 13: 1888 14: 1887 15: 2109 16: 1886 bogomips: 121357
vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: DP-2 empty: DP-1, DVI-D-1, HDMI-A-1, HDMI-A-2
bus-ID: 0a:00.0 chip-ID: 1002:67df class-ID: 0300
Device-2: AMD Baffin [Radeon RX 550 640SP / 560/560X]
vendor: Micro-Star MSI driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 8 ports: active: DP-3,HDMI-A-3 empty: DVI-D-2 bus-ID: 42:00.0
chip-ID: 1002:67ff class-ID: 0300
Display: wayland server: Xwayland v: 22.1.1 compositor: sway v: 1.7
driver: gpu: amdgpu d-rect: 11520x2160 display-ID: 1
Monitor-1: DP-2 pos: right model: Philips PHL 278E1 serial: <filter>
built: 2020 res: 3840x2160 hz: 60 dpi: 163 gamma: 1.2 scale: 1
max: 3840x2160 min: 720x400
Monitor-2: DP-3 pos: primary,left model: Dell P2415Q serial: <filter>
built: 2018 res: 3840x2160 hz: 60 dpi: 185 gamma: 1.2 scale: 1
Monitor-3: HDMI-A-3 pos: center model: Philips PHL 278E1 serial: <filter>
Message: Wayland GBM/EGL data currently not available.
lanes: 16 bus-ID: 0a:00.1 chip-ID: 1002:aaf0 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0c:00.3
Device-3: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 42:00.1 chip-ID: 1002:aae0 class-ID: 0403
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: ASUSTeK
driver: rtw_8822be v: N/A modules: rtw88_8822be pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:b822
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 1000 bus-ID: 05:00.0
Device-1: ASUSTek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-2:2 chip-ID: 0b05:185c class-ID: e001 serial: <filter>
Local Storage: total: 4.55 TiB used: 7.32 GiB (0.2%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung
model: SSD 970 EVO 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 2B2QEXE7 temp: 43.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
model: SSD 960 EVO 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 3B7QCXE7 temp: 34.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Seagate model: BUP RD
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 0304 scheme: GPT
ID-1: / raw-size: 465.26 GiB size: 465.26 GiB (100.00%)
used: 7.32 GiB (1.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-6fd2cdb1-7e23-446e-9ed8-45f0eac1c05a
used: 720 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
ID-3: /home raw-size: 465.26 GiB size: 465.26 GiB (100.00%)
ID-4: /var/log raw-size: 465.26 GiB size: 465.26 GiB (100.00%)
ID-5: /var/tmp raw-size: 465.26 GiB size: 465.26 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.56 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.5 C mobo: 37.0 C
Fan Speeds (RPM): cpu: 2343 case-1: 0 case-2: 0 case-3: 0 fan-1: 536
GPU: device: amdgpu temp: 45.0 C fan: 1190 watts: 16.12 device: amdgpu
temp: 49.0 C fan: 1466 watts: 27.07
Power: 12v: 11.90 5v: N/A 3.3v: N/A vbat: 3.03
Processes: 457 Uptime: 50m wakeups: 0 Memory: 15.56 GiB
used: 2.54 GiB (16.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1161 lib: 297 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.14
Garuda (2.6.1-1):
System install date: 2022-04-07
Last full system update: 2022-04-08 ↻
Edit: running sudo -E btrfs-assistant-bin works instead. Still, it does not launch from the Garuda Welcome Dialouge (or whatever it is called). Same thing for garuda-settings-manager and garuda-network-assistant.
