I only have time to post the outputs of the things you asked for right now. I will try your other suggestions soon and get back to you.
sudo dmesg | grep -Ei âerror|fail|firm|deauth|qos|crda|regdom|cfg80211|alpha2|wl|blueâ | grep -viE âacpi|ras|nvidia|ethâ
[ 0.112389] AMD-Vi: [Firmware Bug]: : IOAPIC[4] not in IVRS table
[ 0.112390] AMD-Vi: [Firmware Bug]: : IOAPIC[5] not in IVRS table
[ 0.112391] AMD-Vi: [Firmware Bug]: : No southbridge IOAPIC found
[ 2.003415] [drm] Found UVD firmware Version: 1.130 Family ID: 16
[ 2.004592] [drm] Found VCE firmware Version: 53.26 Binary ID: 3
[ 2.760186] [drm] Found VCN firmware Version ENC: 1.12 DEC: 2 VEP: 0 Revision: 1
[ 2.760189] [drm] PSP loading VCN firmware
[ 12.830907] systemd[1]: systemd-vconsole-setup.service: Main process exited, code=exited, status=1/FAILURE
[ 12.831011] systemd[1]: systemd-vconsole-setup.service: Failed with result 'exit-code'.
[ 12.831196] systemd[1]: Failed to start Setup Virtual Console.
[ 13.115579] tpm_crb: probe of MSFT0101:00 failed with error -16
[ 13.234868] elan_i2c i2c-ELAN061E:00: Elan Touchpad: Module ID: 0x005b, Firmware: 0x0001, Sample: 0x0002, IAP: 0x0000
[ 13.288139] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 13.297570] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 13.371734] Bluetooth: Core ver 2.22
[ 13.371764] Bluetooth: HCI device and connection manager initialized
[ 13.371769] Bluetooth: HCI socket layer initialized
[ 13.371772] Bluetooth: L2CAP socket layer initialized
[ 13.371777] Bluetooth: SCO socket layer initialized
[ 13.705974] pcieport 0000:00:01.2: AER: Corrected error received: 0000:00:01.0
[ 13.705985] pcieport 0000:00:01.2: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)
[ 13.705987] pcieport 0000:00:01.2: device [1022:15d3] error status/mask=00000040/00006000
[ 13.782930] ath10k_pci 0000:02:00.0: firmware ver WLAN.TF.2.1-00021-QCARMSWP-1 api 6 features wowlan,ignore-otp crc32 42e41877
[ 13.982797] Bluetooth: BNEP filters: protocol multicast
[ 13.982803] Bluetooth: BNEP socket layer initialized
[ 14.011846] ath: EEPROM regdomain: 0x6c
[ 14.011852] ath: Country alpha2 being used: 00
[ 14.028790] ath10k_pci 0000:02:00.0 wlp2s0: renamed from wlan0
[ 14.344474] pcieport 0000:00:01.2: AER: Corrected error received: 0000:00:01.0
[ 14.344488] pcieport 0000:00:01.2: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)
[ 14.344491] pcieport 0000:00:01.2: device [1022:15d3] error status/mask=00000040/00006000
[ 14.375365] pcieport 0000:00:01.2: AER: Corrected error received: 0000:00:01.0
[ 14.375376] pcieport 0000:00:01.2: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)
[ 14.375379] pcieport 0000:00:01.2: device [1022:15d3] error status/mask=00000040/00006000
[ 14.642635] pcieport 0000:00:01.2: AER: Corrected error received: 0000:00:01.0
[ 14.642660] pcieport 0000:00:01.2: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)
[ 14.642663] pcieport 0000:00:01.2: device [1022:15d3] error status/mask=00000040/00006000
[ 26.979329] audit: type=1100 audit(1617816491.608:453): pid=2058 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="sky" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 26.981149] audit: type=1103 audit(1617816491.610:455): pid=2058 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="sky" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 27.009260] audit: type=1103 audit(1617816491.638:459): pid=2060 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="sky" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 29.311239] Bluetooth: RFCOMM TTY layer initialized
[ 29.311248] Bluetooth: RFCOMM socket layer initialized
[ 29.311255] Bluetooth: RFCOMM ver 1.11
[ 53.774578] ath10k_pci 0000:02:00.0: failed to receive scan abortion completion: timed out
[ 53.774592] ath10k_pci 0000:02:00.0: failed to abort scan: -110
[ 53.776348] wlp2s0: authenticate with e0:24:81:8f:da:78
[ 58.958550] ath10k_pci 0000:02:00.0: failed to synchronize setup for vdev 0 restart 0: -110
[ 58.958559] ath10k_pci 0000:02:00.0: failed to start vdev 0 addr 30:d1:6b:e2:3d:af on freq 5180: -110
[ 61.966547] ath10k_pci 0000:02:00.0: failed to start WMI vdev 0: -11
[ 61.966550] ath10k_pci 0000:02:00.0: failed to start vdev 0 addr 30:d1:6b:e2:3d:af on freq 5180: -11
[ 61.966574] ath10k_pci 0000:02:00.0: failed to start WMI vdev 0: -108
[ 61.966576] ath10k_pci 0000:02:00.0: failed to start vdev 0 addr 30:d1:6b:e2:3d:af on freq 5180: -108
[ 61.966578] ath10k_pci 0000:02:00.0: failed to flush transmit queue (skip 1 ar-state 1): 5000
[ 61.966586] ath10k_pci 0000:02:00.0: failed to start WMI vdev 0: -108
[ 61.966587] ath10k_pci 0000:02:00.0: failed to start vdev 0 addr 30:d1:6b:e2:3d:af on freq 5180: -108
[ 62.175589] ath10k_pci 0000:02:00.0: Failed to get pcie state addr: -16
[ 62.175595] ath10k_pci 0000:02:00.0: failed to setup init config: -16
[ 62.176058] p2p-dev-wlp2s0: Failed check-sdata-in-driver check, flags: 0x0
[ 62.176285] cfg80211_stop_p2p_device+0x5c/0x190 [cfg80211]
[ 62.176319] cfg80211_shutdown_all_interfaces+0x8e/0xd0 [cfg80211]
[ 62.176668] cfg80211_stop_p2p_device+0x5c/0x190 [cfg80211]
[ 62.176699] cfg80211_shutdown_all_interfaces+0x8e/0xd0 [cfg80211]
[ 62.309051] ath10k_pci 0000:02:00.0: Failed to get pcie state addr: -16
[ 62.309056] ath10k_pci 0000:02:00.0: failed to setup init config: -16
[ 372.100345] audit: type=1100 audit(1617816836.729:479): pid=11904 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="sky" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 372.102536] audit: type=1110 audit(1617816836.731:481): pid=11904 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
systemctl list-units | grep -iE â(net|dhcp|conn)â
sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-net-wlp2s0.device loadedactive plugged QCA9377 802.11ac Wireless Network Adapter (Qualcomm Atheros QCA9377 Wireless Network Adapter)
sys-devices-pci0000:00-0000:00:01.3-0000:03:00.0-net-eno1.device loadedactive plugged RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
sys-subsystem-net-devices-eno1.device loadedactive plugged RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
sys-subsystem-net-devices-wlp2s0.device loadedactive plugged QCA9377 802.11ac Wireless Network Adapter (Qualcomm Atheros QCA9377 Wireless Network Adapter)
sys-fs-fuse-connections.mount loadedactive mounted FUSE Control File System
bluetooth-autoconnect.service loadedactive running Bluetooth autoconnect service
NetworkManager.service loadedactive running Network Manager
systemd-timesyncd.service loadedactive running Network Time Synchronization
network.target loadedactive active Network
systemctl --failed --all
â systemd-vconsole-setup.service loaded failed failed Setup Virtual Console
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
1 loaded units listed.
To show all installed unit files use 'systemctl list-unit-files'.
lsmod |sort
ac97_bus 16384 1 snd_soc_core
acpi_cpufreq 28672 0
aesni_intel 372736 7
af_alg 36864 6 algif_hash,algif_skcipher
agpgart 40960 5 intel_agp,intel_gtt,ttm,nouveau,drm
algif_hash 20480 1
algif_skcipher 16384 1
amdgpu 7282688 35
ath10k_core 679936 1 ath10k_pci
ath10k_pci 57344 0
ath 36864 1 ath10k_core
blake2b_generic 20480 0
bluetooth 786432 43 btrtl,btintel,btbcm,bnep,btusb,rfcomm
bnep 32768 2
bpf_preload 16384 0
btbcm 16384 1 btusb
btintel 36864 1 btusb
btrfs 1642496 1
btrtl 28672 1 btusb
btusb 69632 0
cbc 16384 0
ccp 122880 1 kvm_amd
cec 81920 2 drm_kms_helper,i915
cfg80211 1064960 3 ath,mac80211,ath10k_core
cmac 16384 2
crc16 16384 1 bluetooth
crc32c_generic 16384 0
crc32c_intel 24576 2
crc32_pclmul 16384 0
crct10dif_pclmul 16384 1
cryptd 28672 5 crypto_simd,ghash_clmulni_intel
crypto_simd 16384 1 aesni_intel
crypto_user 20480 0
dm_crypt 57344 2
dm_mod 159744 6 dm_crypt
drm 622592 16 gpu_sched,drm_kms_helper,amdgpu,radeon,drm_ttm_helper,i915,ttm,nouveau
drm_kms_helper 307200 4 amdgpu,radeon,i915,nouveau
drm_ttm_helper 16384 3 amdgpu,radeon,nouveau
ecc 36864 1 ecdh_generic
ecdh_generic 16384 1 bluetooth
edac_mce_amd 32768 0
elan_i2c 57344 0
encrypted_keys 20480 1 dm_crypt
fat 90112 1 vfat
fb_sys_fops 16384 1 drm_kms_helper
fuse 167936 1
ghash_clmulni_intel 16384 0
glue_helper 16384 1 aesni_intel
gpu_sched 45056 1 amdgpu
i2c_algo_bit 16384 4 amdgpu,radeon,i915,nouveau
i2c_hid 36864 0
i2c_piix4 28672 0
i915 2965504 0
ideapad_laptop 24576 0
intel_agp 24576 0
intel_gtt 24576 2 intel_agp,i915
intel_rapl_common 32768 1 intel_rapl_msr
intel_rapl_msr 20480 0
ip_tables 32768 0
irqbypass 16384 1 kvm
joydev 28672 0
k10temp 16384 0
kvm 1056768 1 kvm_amd
kvm_amd 139264 0
ledtrig_audio 16384 1 snd_hda_codec_generic
libarc4 16384 1 mac80211
libcrc32c 16384 1 btrfs
libphy 163840 3 r8169,mdio_devres,realtek
mac80211 1232896 1 ath10k_core
mac_hid 16384 0
mc 77824 4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
mdio_devres 16384 1 r8169
Module Size Used by
mousedev 24576 0
mxm_wmi 16384 1 nouveau
nouveau 2506752 0
pinctrl_amd 32768 1
r8169 122880 0
radeon 1761280 0
raid6_pq 122880 1 btrfs
rapl 16384 0
realtek 28672 1
rfcomm 94208 16
rfkill 32768 10 bluetooth,ideapad_laptop,cfg80211
rng_core 20480 2 ccp,tpm
serio_raw 20480 0
snd 118784 17 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_timer,snd_compress,snd_soc_core,snd_pcm
snd_compress 28672 1 snd_soc_core
snd_hda_codec 184320 3 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel
snd_hda_codec_generic 110592 1
snd_hda_codec_hdmi 86016 1
snd_hda_core 114688 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
snd_hda_intel 57344 4
snd_hwdep 16384 1 snd_hda_codec
snd_intel_dspcfg 28672 1 snd_hda_intel
snd_pcm 163840 8 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,soundwire_intel,snd_compress,snd_soc_core,snd_hda_core,snd_pcm_dmaengine
snd_pcm_dmaengine 16384 1 snd_soc_core
snd_soc_core 352256 1 soundwire_intel
snd_timer 45056 1 snd_pcm
soundcore 16384 1 snd
soundwire_bus 98304 3 soundwire_intel,soundwire_generic_allocation,soundwire_cadence
soundwire_cadence 36864 1 soundwire_intel
soundwire_generic_allocation 16384 1 soundwire_intel
soundwire_intel 45056 1 snd_intel_dspcfg
sp5100_tco 20480 0
sparse_keymap 16384 1 ideapad_laptop
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
tpm 77824 4 tpm_tis,trusted,tpm_crb,tpm_tis_core
tpm_crb 24576 0
tpm_tis 16384 0
tpm_tis_core 32768 1 tpm_tis
trusted 28672 1 encrypted_keys
ttm 90112 4 amdgpu,radeon,drm_ttm_helper,nouveau
uinput 24576 0
uvcvideo 118784 0
vfat 24576 1
video 53248 3 ideapad_laptop,i915,nouveau
videobuf2_common 69632 2 videobuf2_v4l2,uvcvideo
videobuf2_memops 20480 1 videobuf2_vmalloc
videobuf2_v4l2 36864 1 uvcvideo
videobuf2_vmalloc 20480 1 uvcvideo
videodev 294912 3 videobuf2_v4l2,uvcvideo,videobuf2_common
wmi 36864 4 wmi_bmof,ideapad_laptop,mxm_wmi,nouveau
wmi_bmof 16384 0
xhci_pci 24576 0
xhci_pci_renesas 20480 1 xhci_pci
xor 24576 1 btrfs
x_tables 57344 1 ip_tables
zram 36864 16
