inxi -Faz
produces:
System: Kernel: 5.13.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=a2f9b7ce-1d14-45ec-960d-80f6deb84e9b
rw rootflags=subvol=@ quiet
cryptdevice=UUID=ed9fb91f-024a-4397-9ad0-e4eabee27366:luks-ed9fb91f-024a-4397-9ad0-e4eabee27366
root=/dev/mapper/luks-ed9fb91f-024a-4397-9ad0-e4eabee27366 splash rd.udev.log_priority=3
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1 Distro: Garuda Linux
Machine: Type: Laptop System: Acer product: Nitro AN515-42 v: V1.18 serial: <filter>
Mobo: RR model: Freed_RRS v: V1.18 serial: <filter> UEFI: Insyde v: 1.18 date: 06/18/2020
Battery: ID-1: BAT1 charge: 30.0 Wh (100.0%) condition: 30.0/48.9 Wh (61.3%) volts: 16.0 min: 15.2
model: LG 0x41,0x43,0x31,0x34,0x42,0x38,0x007A type: Li-ion serial: <filter> status: Unknown
CPU: Info: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP
arch: Zen family: 17 (23) model-id: 11 (17) stepping: 0 microcode: 810100B cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31938
Speed: 2006 MHz min/max: 1600/2000 MHz boost: enabled Core speeds (MHz): 1: 2006 2: 1399
3: 1375 4: 1393 5: 1729 6: 2185 7: 1394 8: 2054
Graphics: Device-1: AMD Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:67ef
class-ID: 0380
Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel bus-ID: 04:00.0 chip-ID: 1002:15dd
Device-3: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 3-1:2 chip-ID: 04f2:b5f7
class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: gnome-shell driver: loaded: amdgpu,ati
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.41.0 5.13.10-zen1-1-zen LLVM 12.0.1)
v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.13.10-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI
driver: r8169 v: kernel port: 2000 bus-ID: 02:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f1 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Lite-On
driver: ath10k_pci v: kernel port: 2000 bus-ID: 03:00.0 chip-ID: 168c:003e class-ID: 0280
Bluetooth: Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-4:2 chip-ID: 04ca:3016
Drives: Local Storage: total: 931.51 GiB used: 727.95 GiB (78.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 033 scheme: GPT
Partition: ID-1: / raw-size: 931.25 GiB size: 931.25 GiB (100.00%) used: 727.95 GiB (78.2%) fs: btrfs
dev: /dev/dm-0 maj-min: 254:0 mapped: luks-ed9fb91f-024a-4397-9ad0-e4eabee27366
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 708 KiB (0.3%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 931.25 GiB size: 931.25 GiB (100.00%) used: 727.95 GiB (78.2%) fs: btrfs
ID-4: /var/log raw-size: 931.25 GiB size: 931.25 GiB (100.00%) used: 727.95 GiB (78.2%)
fs: btrfs dev: /dev/dm-0 maj-min: 254:0 mapped: luks-ed9fb91f-024a-4397-9ad0-e4eabee27366
ID-5: /var/tmp raw-size: 931.25 GiB size: 931.25 GiB (100.00%) used: 727.95 GiB (78.2%)
ID-1: swap-1 type: zram size: 30.27 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 48.9 C mobo: N/A
GPU: device: amdgpu temp: 48.0 C device: amdgpu temp: 36.0 C watts: 7.13
Info: Processes: 352 Uptime: 8h 9m wakeups: 1 Memory: 30.27 GiB used: 4.29 GiB (14.2%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1743 lib: 538
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: gnome-terminal inxi: 3.3.06
Issue: Sometimes I boot up and the wifi scan will see all of the nearby networks for about three seconds before it indicates that there are no networks available.
Note: When it does work, it works permanently. There are no intermittent drops or slow speeds. My workaround has been restarting my computer over and over until the wifi works and then avoiding shutting down.
wlp3s0 is down.
$ iplink
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp2s0f1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000
link/ether 98:28:a6:30:84:11 brd ff:ff:ff:ff:ff:ff
3: wlp3s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noqueue state DOWN mode DORMANT group default qlen 1000
link/ether ea:99:e1:93:1f:76 brd ff:ff:ff:ff:ff:ff permaddr f8:a2:d6:55:24:a7
5: enp4s0f3u1c4i2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP mode DEFAULT group default qlen 1000
link/ether be:fe:d9:37:f4:bb brd ff:ff:ff:ff:ff:ff
ath10k driver is being used, though modified to no effect (more on that below).
$ lspci -kv
03:00.0 Network controller: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter (rev 32)
Subsystem: Lite-On Communications Inc Device 0807
Flags: bus master, fast devsel, latency 0, IRQ 65, IOMMU group 10
Memory at e0200000 (64-bit, non-prefetchable) [size=2M]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable+ Count=1/8 Maskable+ 64bit-
Capabilities: [70] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [148] Virtual Channel
Capabilities: [168] Device Serial Number 00-00-00-00-00-00-00-00
Capabilities: [178] Latency Tolerance Reporting
Capabilities: [180] L1 PM Substates
Kernel driver in use: ath10k_pci
Kernel modules: ath10k_pci
When I searched the dmesg log for ath10k, everything is failing.
# dmesg | grep ath10k
[ 4059.023621] ath10k_pci 0000:03:00.0: failed to receive initialized event from target: 00000000
[ 4059.023627] ath10k_pci 0000:03:00.0: failed to wait for target after cold reset: -110
[ 4059.023631] ath10k_pci 0000:03:00.0: failed to reset chip: -110
[ 4059.023634] ath10k_pci 0000:03:00.0: Could not init hif: -110
[ 4475.040158] ath10k_pci 0000:03:00.0: failed to receive initialized event from target: 00000000
[ 4475.040163] ath10k_pci 0000:03:00.0: failed to wait for target after cold reset: -110
[ 4475.040167] ath10k_pci 0000:03:00.0: failed to reset chip: -110
[ 4475.040169] ath10k_pci 0000:03:00.0: Could not init hif: -110
This is the dmesg log on a good boot:
[ 12.308497] ath10k_pci 0000:03:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 12.575104] ath10k_pci 0000:03:00.0: qca6174 hw3.2 target 0x05030000 chip_id 0x00340aff sub 11ad:0807
[ 12.575114] ath10k_pci 0000:03:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
[ 12.576026] ath10k_pci 0000:03:00.0: firmware ver WLAN.RM.2.0-00180-QCARMSWPZ-1 api 4 features wowlan,ignore-otp,no-4addr-pad crc32 75dee6c5
[ 12.644053] ath10k_pci 0000:03:00.0: board_file api 1 bmi_id N/A crc32 872f3cc5
[ 12.737500] ath10k_pci 0000:03:00.0: htt-ver 3.26 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[ 12.820143] ath10k_pci 0000:03:00.0 wlp3s0: renamed from wlan0
I have ath10k driver installed, but I messed with it to try to fix this. I have reversed and reimplemented the change to no effect.
# pacman -Fl linux | grep ath10k
linux usr/lib/modules/5.13.10-arch1-1/kernel/drivers/net/wireless/ath/ath10k/
linux usr/lib/modules/5.13.10-arch1-1/kernel/drivers/net/wireless/ath/ath10k/ath10k_core.ko.zst
linux usr/lib/modules/5.13.10-arch1-1/kernel/drivers/net/wireless/ath/ath10k/ath10k_pci.ko.zst
linux usr/lib/modules/5.13.10-arch1-1/kernel/drivers/net/wireless/ath/ath10k/ath10k_sdio.ko.zst
linux usr/lib/modules/5.13.10-arch1-1/kernel/drivers/net/wireless/ath/ath10k/ath10k_usb.ko.zst
Also potentially relevant: the "ath10k_core" is used by "ath10k_pci" and "ath10k_pci" isn't used by anything when I run
$ lsmod
ath10k_pci 57344 0
uvcvideo 126976 0
ath10k_core 684032 1 ath10k_pci
and searching for ath10k finds other things that seem messy.
$ lsmod | grep ath10k
ath10k_pci 57344 0
ath 36864 1 ath10k_core
mac80211 1241088 1 ath10k_core
cfg80211 1069056 3 ath,mac80211,ath10k_core
I messed with the ath10k driver following a post here ( https://bbs.archlinux.org/viewtopic.php?id=208874 ), but it did not solve the problem.
I do have linux-firmware installed.
I do have a Windows partition on an external drive, but it is messed up and I don't think fast boot was on.
In this pastebin, you will find the journalctl of a good boot and a bad boot:
Follow what tbg says about changing your grub config file to make sure your driver initializes--that's what fixed it for me.
