While running garuda-update
I hit this error. I've been following best practices and using virtual environments for all my python related things, so I don't know why this would happen. I found this possibly related issue on GitHub: error on pip install, tried with various packages · Issue #10984 · pypa/pip · GitHub and this issue here (which failed the same way): Not able to install Python Pip Package
Kernel: 5.18.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=1748cca7-e422-4ed9-bd5c-3d12856f8671 rw [email protected]
resume=UUID=dbb7a323-f52a-40d2-8ad1-ca512a750c83 loglevel=3
sysrq_always_enabled=1
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
Type: Desktop Mobo: ASRock model: X570 Taichi serial: <superuser required>
UEFI: American Megatrends v: P4.30 date: 04/14/2021
Info: model: AMD Ryzen 9 3900XT bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 4133 high: 4249 min/max: 2200/4776 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4225 2: 4249
3: 4114 4: 4240 5: 4219 6: 4233 7: 4071 8: 3880 9: 4065 10: 3766 11: 4214
12: 4239 13: 4225 14: 4239 15: 4140 16: 4071 17: 3706 18: 4204 19: 4138
20: 4185 21: 4181 22: 4187 23: 4181 24: 4242 bogomips: 182403
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M]
vendor: ASRock driver: amdgpu v: kernel arch: RDNA 2 process: TSMC n7 (7nm)
active: DP-1, DP-2, DP-3, HDMI-A-1 empty: none bus-ID: 0f:00.0
chip-ID: 1002:73df class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-4:3 chip-ID: 046d:085c
alternate: fbdev,vesa gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 7680x1971 s-dpi: 96 s-size: 2032x521mm (80.00x20.51")
s-diag: 2098mm (82.59")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: 3-4 model: Samsung SyncMaster
serial: <filter> built: 2006 res: 1280x1024 hz: 60 dpi: 86 gamma: 1.2
size: 376x301mm (14.8x11.85") diag: 482mm (19") ratio: 5:4 modes:
max: 1280x1024 min: 720x400
Monitor-2: DP-2 mapped: DisplayPort-1 pos: 2-1 model: Acer G246HL
serial: <filter> built: 2013 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
Monitor-3: DP-3 mapped: DisplayPort-2 pos: primary,1-2
model: LG (GoldStar) QHD serial: <filter> built: 2021 res: 2560x1440
hz: 144 dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43")
diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 640x480
Monitor-4: HDMI-A-1 mapped: HDMI-A-0 pos: 4-3 model: LCD TV built: 2011
res: 1920x1080 hz: 60 dpi: 3048 gamma: 1.2 size: 16x9mm (0.63x0.35")
diag: 6mm (0.2") ratio: 15:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD Radeon RX 6700 XT (navy_flounder LLVM 13.0.1 DRM
3.46 5.18.3-zen1-1-zen)
v: 4.6 Mesa 22.1.2 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: bus-ID: 3-4:3 gen: 4 chip-ID: 046d:085c speed: 16 GT/s class-ID: 0102
lanes: 16 serial: <filter> bus-ID: 0f:00.1 chip-ID: 1002:ab28
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 11:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech C922 Pro Stream Webcam type: USB
Device-4: C-Media USB PnP Sound Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-3:4 chip-ID: 0d8c:013a
Sound Server-1: ALSA v: k5.18.3-zen1-1-zen running: yes
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
bus-ID: 3-2:2 chip-ID: 8087:0029 class-ID: e001
address: <filter>
Local Storage: total: 2.27 TiB used: 1.63 TiB (71.7%)
rev: 2B2QEXM7 temp: 49.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 500GB
type: SSD serial: <filter> rev: DB6Q scheme: GPT
ID-1: / raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 1.63 TiB (93.1%)
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
used: 546 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
used: 1.63 TiB (93.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
ID-1: swap-1 type: zram size: 62.73 GiB used: 138 MiB (0.2%)
ID-2: swap-2 type: partition size: 69.07 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 41.0 C mobo: 41.0 C gpu: amdgpu temp: 58.0 C
mem: 56.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1049 fan-3: 0 fan-4: 1488 fan-5: 1162
fan-6: 2231 fan-7: 0 gpu: amdgpu fan: 0
Processes: 635 Uptime: 13d 5h 50m wakeups: 0 Memory: 62.73 GiB
used: 18.8 GiB (30.0%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 2851
lib: 628 flatpak: 0 Shell: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2021-06-18
Last full system update: 2022-06-29 ↻
Failed units: [email protected]
garuda is up to date
core is up to date
extra is up to date
community is up to date
multilib is up to date
aurto is up to date
chaotic-aur is up to date
--> Refreshing mirrorlists using reflector, please be patient..
[2022-06-30 03:48:35] WARNING: failed to rate http(s) download (https://mirror.cyberbits.asia/archlinux/community/os/x86_64/community.db): HTTP Error 403: Forbidden
################# Arch Linux mirrorlist generated by Reflector #################
# With: reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist
# When: 2022-06-30 07:48:42 UTC
# From: https://archlinux.org/mirrors/status/json/
# Retrieved: 2022-06-30 07:48:35 UTC
# Last Check: 2022-06-30 07:02:15 UTC
Server = https://geo.mirror.pkgbuild.com/$repo/os/$arch
Server = https://archlinux.mirror.luzea.de/$repo/os/$arch
Server = https://mirror.moson.org/arch/$repo/os/$arch
Server = https://archlinux.thaller.ws/$repo/os/$arch
Server = https://mirror.cyberbits.asia/archlinux/$repo/os/$arch
garuda 73.3 KiB 169 KiB/s 00:00 [------------------------------------------------------------------------------------] 100%
core 156.4 KiB 304 KiB/s 00:01 [------------------------------------------------------------------------------------] 100%
extra 1718.6 KiB 2.41 MiB/s 00:01 [------------------------------------------------------------------------------------] 100%
community 6.7 MiB 6.28 MiB/s 00:01 [------------------------------------------------------------------------------------] 100%
multilib 170.6 KiB 299 KiB/s 00:01 [------------------------------------------------------------------------------------] 100%
aurto 170.0 KiB 55.3 MiB/s 00:00 [------------------------------------------------------------------------------------] 100%
chaotic-aur 1855.3 KiB 2.08 MiB/s 00:01 [------------------------------------------------------------------------------------] 100%
spawn pacman -Su
resolving dependencies...
Package (21) Old Version New Version Net Change
community/argyllcms 2.3.0-1 2.3.1-1 -0.29 MiB
chaotic-aur/cmake-git 3.24.0.rc2.209.gb1d8141534-1 3.24.0.rc2.210.g4c2cead0c3-1 0.00 MiB
extra/glib-networking 1:2.72.0-1 1:2.72.1-1 0.00 MiB
extra/harfbuzz 4.4.0-1 4.4.1-1 0.00 MiB
extra/harfbuzz-icu 4.4.0-1 4.4.1-1 0.00 MiB
extra/hplip 1:3.22.4-2 1:3.22.6-1 1.78 MiB
chaotic-aur/latte-dock-git 0.10.6.r260.g899c0155-1 0.10.6.r260.g899c0155-1.1 0.00 MiB
multilib/lib32-glib-networking 2.72.0-1 2.72.1-1 0.00 MiB
multilib/lib32-harfbuzz 4.4.0-1 4.4.1-1 0.00 MiB
chaotic-aur/makemkv 1.16.7-1 1.17.0-1 0.28 MiB
chaotic-aur/nheko-git 0.9.3.r226.gb6bbbdea-1 0.9.3.r227.g91f1c00e-1 0.00 MiB
chaotic-aur/peazip-qt5 8.6.0-2 8.7.0-1 0.11 MiB
chaotic-aur/pnpm 7.2.1-0 7.4.0-0 0.39 MiB
extra/python-pip 21.0-1 22.1.2-1 1.04 MiB
extra/python-resolvelib 0.5.5-4 0.8.1-1 0.01 MiB
community/python-tenacity 8.0.1-3 0.14 MiB
extra/qt5-base 5.15.5+kde+r163-1 5.15.5+kde+r166-1 0.03 MiB
core/sqlite 3.38.5-1 3.39.0-2 0.02 MiB
chaotic-aur/sweet-theme-full-git r273.053be77-1 r274.7da8215-1 -0.03 MiB
aurto/viddy 0.3.4-1 0.3.6-1 0.01 MiB
chaotic-aur/ytfzf-git r1539.1b17caa-1 r1543.29f2710-1 0.00 MiB
Total Installed Size: 430.59 MiB
Net Upgrade Size: 3.49 MiB
:: Retrieving packages...
viddy-0.3.6-1-x86_64 is up to date
(21/21) checking keys in keyring [------------------------------------------------------------------------------------] 100%
(21/21) checking package integrity [------------------------------------------------------------------------------------] 100%
(21/21) loading package files [------------------------------------------------------------------------------------] 100%
(21/21) checking for file conflicts [------------------------------------------------------------------------------------] 100%
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/commands/__pycache__/index.cpython-310.pyc exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/commands/index.py exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/index/__pycache__/sources.cpython-310.pyc exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/index/sources.py exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/locations/__init__.py exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/locations/__pycache__/__init__.cpython-310.pyc exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/locations/__pycache__/_distutils.cpython-310.pyc exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/locations/__pycache__/_sysconfig.cpython-310.pyc exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/locations/__pycache__/base.cpython-310.pyc exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/locations/_distutils.py exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/locations/_sysconfig.py exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/locations/base.py exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/metadata/__init__.py exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/metadata/__pycache__/__init__.cpython-310.pyc exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/metadata/__pycache__/base.cpython-310.pyc exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/metadata/__pycache__/pkg_resources.cpython-310.pyc exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/metadata/base.py exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/metadata/pkg_resources.py exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/operations/build/__pycache__/metadata_editable.cpython-310.pyc exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/operations/build/__pycache__/wheel_editable.cpython-310.pyc exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/operations/build/metadata_editable.py exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/operations/build/wheel_editable.py exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/utils/__pycache__/_log.cpython-310.pyc exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/utils/__pycache__/egg_link.cpython-310.pyc exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/utils/_log.py exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/_internal/utils/egg_link.py exists in filesystem
python-pip: /usr/lib/python3.10/site-packages/pip/py.typed exists in filesystem
