Im trying to use proton with steam, followed some guides, but i cant make it work.
Seems like vxdk and all the directx games cant run properly. Tried to reinstall multiple times but no luck
If you include terminal outputs in your post please use the proper output format in your post. Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
I tried fo search on garuda's forum and on google before posting, tried to install amdgpu-pro or, after a new installation, to uninstall vulkan-swrast or installing mesa-git but nothing worked and im out of ideas right now.
If i try to run tropico 4 i have this in terminal
GameAction [AppID 57690, ActionID 2] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 57690, ActionID 2] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 57690, ActionID 2] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 57690, ActionID 2] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/indst/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=57690 -- '/home/indst/.local/
share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/ind
st/.local/share/Steam/steamapps/common/Proton 6.3'/proton waitforexitandrun '/home/indst/.local/share/Steam/s
teamapps/common/Tropico 4/Tropico4.exe'\0
Game update: AppID 57690 "", ProcID 57612, IP 0.0.0.0:0
Starting app 57690
>>> Adding process 57612 for game ID 57690
GameAction [AppID 57690, ActionID 2] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 57690, ActionID 2] : LaunchApp changed task to Completed with ""
ERROR: ld.so: object '/home/indst/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD canno
t be preloaded (wrong ELF class: ELFCLASS32): ignored.
ERROR: ld.so: object '/home/indst/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD canno
t be preloaded (wrong ELF class: ELFCLASS64): ignored.
pid 57616 != 57613, skipping destruction (fork without exec?)
>>> Adding process 57613 for game ID 57690
>>> Adding process 57614 for game ID 57690
>>> Adding process 57615 for game ID 57690
>>> Adding process 57617 for game ID 57690
>>> Adding process 57618 for game ID 57690
>>> Adding process 57881 for game ID 57690
>>> Adding process 57882 for game ID 57690
>>> Adding process 57883 for game ID 57690
>>> Adding process 57884 for game ID 57690
>>> Adding process 57886 for game ID 57690
>>> Adding process 57890 for game ID 57690
>>> Adding process 57892 for game ID 57690
>>> Adding process 57895 for game ID 57690
esync: up and running.
wine: RLIMIT_NICE is <= 20, unable to use setpriority safely
>>> Adding process 57897 for game ID 57690
>>> Adding process 57899 for game ID 57690
>>> Adding process 57901 for game ID 57690
>>> Adding process 57903 for game ID 57690
>>> Adding process 57905 for game ID 57690
>>> Adding process 57908 for game ID 57690
>>> Adding process 57910 for game ID 57690
>>> Adding process 57911 for game ID 57690
>>> Adding process 57912 for game ID 57690
>>> Adding process 57913 for game ID 57690
>>> Adding process 57914 for game ID 57690
>>> Adding process 57917 for game ID 57690
>>> Adding process 57919 for game ID 57690
>>> Adding process 57922 for game ID 57690
>>> Adding process 57930 for game ID 57690
>>> Adding process 57936 for game ID 57690
>>> Adding process 57953 for game ID 57690
>>> Adding process 57958 for game ID 57690
Game update: AppID 57690 "", ProcID 57913, IP 0.0.0.0:0
RecordSteamInterfaceCreation (PID 57913): SteamUtils009 / Utils
Setting breakpad minidump AppID = 57690
RecordSteamInterfaceCreation (PID 57913): SteamUser019 / User
Steam_SetMinidumpSteamID: Caching Steam ID: 76561198081794107 [API loaded no]
RecordSteamInterfaceCreation (PID 57913): SteamFriends015 / Friends
RecordSteamInterfaceCreation (PID 57913): SteamMatchMaking009 / Matchmaking
RecordSteamInterfaceCreation (PID 57913): SteamMatchMakingServers002 / MatchmakingServers
RecordSteamInterfaceCreation (PID 57913): STEAMUSERSTATS_INTERFACE_VERSION011 / UserStats
RecordSteamInterfaceCreation (PID 57913): STEAMAPPS_INTERFACE_VERSION008 / Apps
RecordSteamInterfaceCreation (PID 57913): SteamNetworking005 / Networking
RecordSteamInterfaceCreation (PID 57913): STEAMREMOTESTORAGE_INTERFACE_VERSION014 / RemoteStorage
RecordSteamInterfaceCreation (PID 57913): STEAMSCREENSHOTS_INTERFACE_VERSION003 / Screenshots
RecordSteamInterfaceCreation (PID 57913): STEAMHTTP_INTERFACE_VERSION002 / HTTP
RecordSteamInterfaceCreation (PID 57913): SteamController006 / Controller
RecordSteamInterfaceCreation (PID 57913): STEAMUGC_INTERFACE_VERSION010 / UGC
RecordSteamInterfaceCreation (PID 57913): STEAMAPPLIST_INTERFACE_VERSION001 / AppList
RecordSteamInterfaceCreation (PID 57913): STEAMMUSIC_INTERFACE_VERSION001 / Music
RecordSteamInterfaceCreation (PID 57913): STEAMMUSICREMOTE_INTERFACE_VERSION001 / MusicRemote
RecordSteamInterfaceCreation (PID 57913): STEAMHTMLSURFACE_INTERFACE_VERSION_004 / HTMLSurface
RecordSteamInterfaceCreation (PID 57913): STEAMINVENTORY_INTERFACE_V002 / Inventory
RecordSteamInterfaceCreation (PID 57913): STEAMVIDEO_INTERFACE_V002 / Video
RecordSteamInterfaceCreation (PID 57913): STEAMPARENTALSETTINGS_INTERFACE_VERSION001 / ParentalSettings
WARNING: radv is not a conformant vulkan implementation, testing use only.
>>> Adding process 57972 for game ID 57690
>>> Adding process 57986 for game ID 57690
Game update: AppID 57690 "", ProcID 57986, IP 0.0.0.0:0
RecordSteamInterfaceCreation (PID 57986): SteamUtils005 / Utils
RecordSteamInterfaceCreation (PID 57986): SteamUser016 / User
RecordSteamInterfaceCreation (PID 57986): STEAMAPPTICKET_INTERFACE_VERSION001 /
RecordSteamInterfaceCreation (PID 57986): SteamUser014 / User
RecordSteamInterfaceCreation (PID 57986): SteamFriends008 / Friends
RecordSteamInterfaceCreation (PID 57986): SteamMatchMaking008 / Matchmaking
RecordSteamInterfaceCreation (PID 57986): SteamMatchMakingServers002 / MatchmakingServers
RecordSteamInterfaceCreation (PID 57986): STEAMUSERSTATS_INTERFACE_VERSION009 / UserStats
RecordSteamInterfaceCreation (PID 57986): STEAMAPPS_INTERFACE_VERSION004 / Apps
RecordSteamInterfaceCreation (PID 57986): SteamNetworking004 / Networking
RecordSteamInterfaceCreation (PID 57986): STEAMREMOTESTORAGE_INTERFACE_VERSION004 / RemoteStorage
Fossilize INFO: Overriding serialization path: "/home/indst/.local/share/Steam/steamapps/shadercache/57690/foz
pipelinesv5/steamapprun_pipeline_cache".
pid 57915 != 57914, skipping destruction (fork without exec?)
Game removed: AppID 57690 "", ProcID 57986
Game 57690 created interface STEAMAPPS_INTERFACE_VERSION004 / Apps
Game 57690 created interface STEAMAPPTICKET_INTERFACE_VERSION001 /
Game 57690 created interface STEAMREMOTESTORAGE_INTERFACE_VERSION004 / RemoteStorage
Game 57690 created interface STEAMUSERSTATS_INTERFACE_VERSION009 / UserStats
Game 57690 created interface SteamFriends008 / Friends
Game 57690 created interface SteamMatchMaking008 / Matchmaking
Game 57690 created interface SteamMatchMakingServers002 / MatchmakingServers
Game 57690 created interface SteamNetworking004 / Networking
Game 57690 created interface SteamUser014 / User
Game 57690 created interface SteamUser016 / User
Game 57690 created interface SteamUtils005 / Utils
Game 57690 method call count for IClientUtils::RecordSteamInterfaceCreation : 12
Game 57690 method call count for IClientUtils::GetAppID : 14
Game 57690 method call count for IClientFriends::GetPersonaName : 1
Game 57690 method call count for IClientUser::GetAppOwnershipTicketExtendedData : 1
Game 57690 method call count for IClientUser::GetSteamID : 2
Uploaded AppInterfaceStats to Steam
Exiting app 57690
No cached sticky mapping in ActivateActionSet.[2021-07-30 14:32:30] Background update loop checking for update
[2021-07-30 14:32:30] Verifica della disponibilità di aggiornamenti...
[2021-07-30 14:32:30] Downloading manifest: https://cdn.cloudflare.steamstatic.com/client/steam_client_publicb
eta_ubuntu12
Installing breakpad exception handler for appid(steam)/version(1627607186)
[2021-07-30 14:32:31] Download skipped by HTTP 304 Not Modified
[2021-07-30 14:32:31] Nothing to do
