Problems with Garuda on Lenovo Legion 5 pro
Greetings. Firstly my garuda-inxi:
Kernel: 6.9.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=72720d44-97ba-4087-bf3a-1e733bbcc616 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: LENOVO product: 82RG v: Legion 5 Pro 16ARH7H
serial: <superuser required> Chassis: type: 10 v: Legion 5 Pro 16ARH7H
Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN
serial: <superuser required> part-nu: LENOVO_MT_82RG_BU_idea_FM_Legion 5
Pro 16ARH7H uuid: <superuser required> UEFI: LENOVO v: JUCN64WW
date: 01/09/2024
ID-1: BAT0 charge: 66.2 Wh (85.0%) condition: 77.9/80.0 Wh (97.4%)
volts: 16.5 min: 15.4 model: BYD L21B4PC0 type: Li-poly serial: <filter>
status: not charging cycles: 104
Info: model: AMD Ryzen 7 6800H with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404105
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1027 high: 2736 min/max: 400/4785 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1368 2: 400 3: 1370
4: 1368 5: 1827 6: 400 7: 1459 8: 400 9: 1736 10: 2736 11: 1371 12: 400
13: 400 14: 400 15: 400 16: 400 bogomips: 102208
Device-1: NVIDIA GA104M [Geforce RTX 3070 Ti Laptop GPU] vendor: Lenovo
driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:24e0
Device-2: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-3,
DP-4, DP-5, DP-6, Writeback-1 bus-ID: 34:00.0 chip-ID: 1002:1681
class-ID: 0300 temp: 46.0 C
gpu: nvidia,amdgpu display-ID: 0
Monitor-1: eDP-1 res: 1707x1067 size: N/A modes: N/A
surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: zink
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Ti Laptop
GPU/PCIe/SSE2 memory: 7.81 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Ti Laptop GPU driver: nvidia v: 550.78
device-ID: 10de:24e0 surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: AMD Radeon Graphics (RADV REMBRANDT)
driver: mesa radv v: 24.1.0-arch1.1 device-ID: 1002:1681
17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.0-arch1.1 (LLVM 17.0.6)
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 34:00.5
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 34:00.6
API: ALSA v: k6.9.3-zen1-1-zen status: kernel-api tools: N/A
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 14c3:0616 class-ID: 0280
port: 4000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Foxconn / Hon Hai Bluetooth 5.2 Adapter [MediaTek MT7922]
driver: btusb v: 0.8 type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 3-3:4 chip-ID: 0489:e0d8 class-ID: e001 serial: <filter>
Local Storage: total: 983.31 GiB used: 14.03 GiB (1.4%)
model: MZVL21T0HCLR-00BL2 size: 953.87 GiB block-size: physical: 512 B
fw-rev: CL1QGXA7 temp: 47.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Verbatim model: MyUSB size: 29.44 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 1100
scheme: MBR
ID-1: / raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
used: 13.97 GiB (7.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 59.4 MiB (61.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-4: /var/log raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-5: /var/tmp raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-1: swap-1 type: partition size: 977 MiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 14.81 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 54.8 C mobo: 50.0 C gpu: amdgpu temp: 47.0 C
Memory: total: 16 GiB note: est. available: 14.82 GiB used: 3.17 GiB (21.4%)
Processes: 413 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
image: 5.88 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1362 libs: 405 tools: octopi,paru Compilers:
gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.34
System install date:     2024-06-03
Last full system update: 2024-06-03
There are two major problems I’ve noticed just after installing Garuda. Firstly, It’s related to the drivers I guess, cuz the browsers are working awful, with lags, glitches and so on. Eve right now typing this text it glitches after every letter (Tried both on Google and Brave).
Secondly I noticed that my system just freezes after reboot or power on, which is only resolved by hard reboot. Help please?
Try X11 from login screen.
Yep, it worked. And what about the freeze at the boot?
Check your /etc/fstab
with your
lsblk -f
BTW
  • ONE issue per topic.
Sorry, didn’t get it. What should I check?
Make a new topic, “Freezes at startup with Legion 5 Pro”
Then provide your disk mount information with the command lsblk -f.
fstab - contains all the info about auto mount partitions.
lsblk -f - shows all the partitions.
