Hi, with the latest bauh I get this error:
Icon theme "elementary" not found.
Icon theme "gnome" not found.
File "/usr/lib/python3.10/site-packages/bauh/view/qt/window.py", line 702, in _finish_refresh_packages
if self.update_pkgs(res['installed'], as_installed=as_installed, types=res['types']):
File "/usr/lib/python3.10/site-packages/bauh/view/qt/window.py", line 964, in update_pkgs
self._update_table(pkgs_info=pkgs_info)
File "/usr/lib/python3.10/site-packages/bauh/view/qt/window.py", line 842, in _update_table
self._resize(accept_lower_width=len(self.pkgs) > 0)
File "/usr/lib/python3.10/site-packages/bauh/view/qt/window.py", line 1079, in _resize
self.resize(new_width, self.height())
TypeError: arguments did not match any overloaded call:
resize(self, QSize): argument 1 has unexpected type 'float'
resize(self, int, int): argument 1 has unexpected type 'float'
Fatal Python error: Aborted
Thread 0x00007f459effd640 (most recent call first):
File "/usr/lib/python3.10/site-packages/bauh/view/qt/thread.py", line 822 in run
Thread 0x00007f459f7fe640 (most recent call first):
File "/usr/lib/python3.10/site-packages/bauh/view/qt/prepare.py", line 140 in run
Thread 0x00007f45c77fe640 (most recent call first):
File "/usr/lib/python3.10/site-packages/bauh/view/util/cache.py", line 96 in run
File "/usr/lib/python3.10/threading.py", line 1009 in _bootstrap_inner
File "/usr/lib/python3.10/threading.py", line 966 in _bootstrap
Current thread 0x00007f45f7b5b740 (most recent call first):
File "/usr/lib/python3.10/site-packages/bauh/app.py", line 57 in main
File "/usr/bin/bauh", line 33 in
Extension modules: PyQt5.QtCore, yaml._yaml, PyQt5.QtGui, PyQt5.QtWidgets, PyQt5.QtNetwork, lxml._elementpath,
lxml.etree (total: 7)
fish: Job 1, 'bauh' terminated by signal SIGABRT (Abort)
If you include terminal outputs in your post please use the proper output format in your post.
Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
