I have problem with CS:GO. When I turn on CS: GO I get a black screen and turns off. When I turned on with the proton, the error launcher was showing up. I don't know what to do, please help. Btw sorry for my english
Please provide the output of your garuda-inxi as requested by the topic template.
Can I do it tomorrow? I'm going to sleep soon
Try searching on proton.db for steam games problems.
Here is the thread for CS:GO
https://www.protondb.com/app/730
Kernel: 6.0.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=51911192-c46d-4ebb-8f27-151f928334dc rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.0 tk: Qt v: 5.15.6 info: latte-dock
Type: Laptop System: HP product: HP 250 G4 Notebook PC
Mobo: HP model: 80C2 v: 96.38 serial: <superuser required> UEFI: Insyde
v: F.19 date: 08/27/2015
ID-1: BAT1 charge: 34.5 Wh (100.0%) condition: 34.5/41.6 Wh (83.0%)
volts: 16.6 min: 14.6 model: COMPAL PABAS0241231 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1885 high: 1900 min/max: 500/1900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1900 2: 1896 3: 1849
4: 1896 bogomips: 15963
Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-8 process: Intel 14nm built: 2014-15 ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon
520 Mobile] vendor: Hewlett-Packard driver: radeon v: kernel
alternate: amdgpu arch: GCN-1 code: Southern Islands process: TSMC 28nm
built: 2011-20 pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 0d:00.0 chip-ID: 1002:6660 class-ID: 0380
temp: 40.0 C
Device-3: Cheng Uei Precision Industry (Foxlink) HP Webcam type: USB
driver: uvcvideo bus-ID: 1-5:4 chip-ID: 05c8:022a class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: modesetting,radeon
alternate: fbdev,intel,vesa dri: iris,radeonsi gpu: i915 display-ID: :0
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: Samsung 0x4c51 built: 2014 res: 1366x768 hz: 60
dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa
22.2.1 direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
chip-ID: 8086:9ca0 class-ID: 0403
Sound API: ALSA v: k6.0.1-zen2-1-zen running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet
speed: 2.5 GT/s lanes: 1 port: 5000 bus-ID: 07:00.0 chip-ID: 10ec:8136
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 13:00.0 chip-ID: 10ec:b723
IF: wlp19s0 state: up mac: <filter>
bus-ID: 1-4:3 chip-ID: 0bda:b006 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 465.76 GiB used: 83.38 GiB (17.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LT012-1DG142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: YAM1
ID-1: / raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 83.38 GiB
(17.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 83.38
GiB (17.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 83.38
ID-5: /var/tmp raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 83.38
ID-1: swap-1 type: zram size: 3.75 GiB used: 40 MiB (1.0%) priority: 100
System Temperatures: cpu: 44.0 C pch: 40.5 C mobo: N/A gpu: radeon
temp: 40.0 C
Processes: 191 Uptime: 34m wakeups: 1 Memory: 3.75 GiB used: 1.98 GiB
(52.7%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1834
libs: 514 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
Garuda (2.6.8-1):
System install date: 2022-10-15
Last full system update: 2022-10-16
I adjusted the inxi post to be more readable, according to the relevant tutorial.
As far as the issue is concerned, I cannot help much since I'm not a gamer.
Anyway, you could give a look at the topics below, containing "CS:GO" and solved.
https://forum.garudalinux.org/search?q=%22CS%3AGO%22%20status%3Asolved
The only suggestion I could think of is to try disabling the compositor (alt+shift+F12) before launching the game
(maybe this is already among the suggestions in the list above anyway).
Don’t use Proton for CSGO.
thanks for your help
Do you know how to solve my problem with csgo?
Change launch options to
prime-run %command%
If csgo run in window I must launch -fullscreen?
You can enable fullscreen in game settings, IIRC the launch parameter for that is "-full".
Now Csgo crashes fastly
I have problem with run CSGO. When I run CSGO in native it shows black screen.
Now I'm trying to turn csgo through a proton. But if I do this it shows "Fatal error, failed to connect with local Stean Client process". I don't know what to do.
ID-1: BAT1 charge: 34.8 Wh (100.0%) condition: 34.8/41.6 Wh (83.5%)
Speed (MHz): avg: 1897 high: 1900 min/max: 500/1900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1896 2: 1898 3: 1896
4: 1900 bogomips: 15962
temp: 49.0 C
address: <filter>
Local Storage: total: 465.76 GiB used: 72.13 GiB (15.5%)
ID-1: / raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 72.13 GiB
(15.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 72.13
GiB (15.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 72.13
ID-5: /var/tmp raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 72.13
ID-1: swap-1 type: zram size: 3.75 GiB used: 1.59 GiB (42.5%)
System Temperatures: cpu: 53.0 C pch: 49.5 C mobo: N/A gpu: radeon
temp: 49.0 C
Processes: 220 Uptime: 1h 47m wakeups: 1 Memory: 3.75 GiB used: 2.37 GiB
(63.2%) Init: systemd v: 251 default: graphical tool: systemctl
Garuda (2.6.8-1):
Do not open new help requests for the same problem, please, it is rude.
doesn’t start in btrfs partition, only in case insensitive FSs
You could try to break off some space for the game, format it with ext4 and try running the game then. A lot of work for a game, but if you really wanna play… doesn’t seem to work on Btrfs.
Could also try launch-option -nojoy
There seem to be a lot of hits and guides on the Internet for this error, although they don't seem to be a big deal at all...
Have you tried anything?
Even though they are always Windows-based, Steam is Steam, maybe you can try.
I just link one of them randomly:
https://thedroidguy.com/csgo-failed-to-connect-with-local-steam-client-process-error-1137680
