Hello everyone. I downloaded Garuda KDE Dr460nized and made bootable usb(32 Gb, usb 3.0). In live cd all works perfectly. After that I installed system on my ssd(NVME, PC SN530 SDBPNPZ-512G-1114) and reboot. Grub founded efi and begin starting system and... she freezed. Console output of inxi -Fxxxza :
Kernel: 5.11.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
misobasedir=garuda misolabel=GARUDA_DR460NIZED_SOARING_ quiet
systemd.show_status=1 systemd.unified_cgroup_hierarchy=1 driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: Acer product: Aspire A514-54 v: V1.08 serial: <filter>
Mobo: TGL model: Lily_TL v: V1.08 serial: <filter> UEFI: Insyde v: 1.08
date: 01/22/2021
ID-1: BAT1 charge: 54.6 Wh (100.0%) condition: 54.6/53.0 Wh (103.0%) volts: 17.5
min: 15.4 model: PANASONIC AP19B5L type: Li-ion serial: <filter> status: Full
cycles: 24
Info: Quad Core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 8C (140) stepping: 1 microcode: 60 cache:
L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38707
Speed: 3806 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 3806 2: 4142 3: 4200
4: 4016 5: 4193 6: 4200 7: 4045 8: 3841
Device-1: Intel Iris Xe Graphics vendor: Acer Incorporated ALI driver: i915
v: kernel bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-8:3
chip-ID: 04f2:b64f class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.0.1
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
driver: sof-audio-pci alternate: snd_hda_intel,snd_sof_pci bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.11.10-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.24 running: no
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel port: 4000
bus-ID: 0000:00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 0000:01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 8087:0026
Report: ID: hci0 state: up address: <filter>
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd v: 0.6
port: 4000 bus-ID: 0000:00:0e.0 chip-ID: 8086.9a0b rev: class-ID: 0104
Local Storage: total: 505.85 GiB used: 0 KiB (0.0%)
model: PC SN530 SDBPNPZ-512G-1114 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: 21113000 temp: 28.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: A-Data model: USB Flash Drive
size: 28.91 GiB block-size: physical: 512 B logical: 512 B speed: <unknown>
rotation: SSD serial: <filter> rev: 1100 scheme: MBR
Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
ID-1: swap-1 type: zram size: 968.9 MiB used: 0 KiB (0.0%) priority: 32767
ID-2: swap-2 type: zram size: 968.9 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-3: swap-3 type: zram size: 968.9 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-4: swap-4 type: zram size: 968.9 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
ID-5: swap-5 type: zram size: 968.9 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram4
ID-6: swap-6 type: zram size: 968.9 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram5
ID-7: swap-7 type: zram size: 968.9 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram6
ID-8: swap-8 type: zram size: 968.9 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram7
System Temperatures: cpu: 27.8 C mobo: N/A
Processes: 229 Uptime: 9m wakeups: 2044 Memory: 7.57 GiB used: 3.88 GiB (51.2%)
Init: systemd v: 247 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0
Packages: pacman: 1180 lib: 291 Shell: fish v: 3.2.1 running-in: konsole
inxi: 3.3.03
