WARN] - (starship::configs::starship_root): Unknown config key 'docker'
[WARN] - (starship::configs::starship_root): Did you mean 'docker_context'?
[WARN] - (starship::configs::starship_root): Unknown config key 'haskell'
[WARN] - (starship::configs::starship_root): Did you mean 'shell'?
[WARN] - (starship::configs::starship_root): Unknown config key 'docker'
[WARN] - (starship::configs::character): Unknown config key 'use_symbol_for_status'
Please always start with a search on the forum.
It is a known problem.
Just check here for the solution:
Read
please
and post
inxi -Fxxxza
as text next time. Even if you personally think it is unnecessary.
and
Use forum search function first, it is explained more than one time
