Hello, I want to know if someone says something a little stutters what needs to be said because we have an installation
Welcome to the forums
We need more details and also the output of garuda-inxi as requested in the template.
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=82442d96-7163-4efb-a941-c51a39c7f9a3 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1
Type: Desktop Mobo: ASUSTeK model: Z170I PRO GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3805
date: 05/16/2018
Info: model: Intel Core i7-7700K bits: 64 type: MCP arch: Kaby Lake
family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xEC
Topology: cpus: 1x cores: 4 smt: disabled cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 4600 min/max: 800/4600 scaling: driver: intel_pstate
governor: performance cores: 1: 4600 2: 4600 3: 4600 4: 4600
bogomips: 33600
mitigation: Retpolines, IBPB: conditional, IBRS_FW, RSB filling
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: Gigabyte driver: nvidia
v: 510.68.02 alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f82 class-ID: 0300
Device-2: HHT UVC CAMERA type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-2.4:7 chip-ID: 2757:2001 class-ID: 0102 serial: <filter>
compositor: kwin_x11 driver: X: loaded: nvidia
Screen-1: 0 s-res: 3840x2160 s-dpi: 139 s-size: 702x392mm (27.64x15.43")
s-diag: 804mm (31.65")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 139
size: 700x390mm (27.56x15.35") diag: 801mm (31.55") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 510.68.02 direct render: Yes
Device-1: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
vendor: ASUSTeK driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 05:00.0 chip-ID: 168c:003e class-ID: 0280
Device-1: ASUSTek Qualcomm Bluetooth 4.1 type: USB driver: btusb v: 0.8
bus-ID: 1-13:5 chip-ID: 0b05:1825 class-ID: e001
Local Storage: total: 465.76 GiB used: 58.66 GiB (12.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SWORDFISH
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: VC0S0285
temp: 46.9 C scheme: GPT
used: 58.66 GiB (12.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.57 GiB used: 13.5 MiB (0.1%)
System Temperatures: cpu: 68.0 C mobo: 27.8 C gpu: nvidia temp: 48 C
Processes: 247 Uptime: 55m wakeups: 0 Memory: 15.57 GiB
used: 4.94 GiB (31.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1846 lib: 522 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-05-07
Last full system update: 2022-05-07 ↻
Your post has been edited to add code formatting. Please add three tildes (~) before and after terminal output to use this formatting.
code formatting
Can you describe your problem another way? The issue you are experiencing is unclear.
After install und update reboot the system.
I need how to do it after nvidia installation because we have even worse jams, we need to play and repair wine as well as installation
Sounds like an issue so moved it there. If not then my bad. Can't really understand what the problem is lol
If you are having a problem with the English language please repost with more details in: Languages - Garuda Linux Forum
Just someone please remotely connect to see what's going on there
Did you mean fresh installation of Garuda linux ?
What do you mean by that ?
Simply you want to know your GPU works with Garuda, and do you want to know more about Garuda or your motherboard support Garuda Linux
GPU Problems ?
Do you have problem in your NVIDIA GPU ?
Chill dude, it’s a forum and we cannot connect to your PC
Also we are not any Technical supporters
Tell your problems one by one any one will answer it
lol, I feel like I’m back at work all of a sudden.
As much as I love this forum and this community, asking strangers from the internet to remotely connect to your computer–for any purpose–is unwise.
To use this forum, you really do need to try to describe your issue in a way that other people can understand–otherwise it’s just impossible to help you.
Now we need the whole configuration and plus the nvidia installation the whole thing, please give me the configuration exactly, quite the information because we have a problem jamming something wrong
Which language are you comfortable to speak, ask questions in that that language don’t hesitate we answer BTW you have problem with NVIDIA GPU
Sound like you have problem in wine
Does Your GPU works Good in other parts, I mean other than wine ? Please clarify that
I think …
You have problem in Gaming your GPU doesn’t works as expected ?
But it was about the installation so you can specify the installation exactly or explain it exactly on nvidia
Unless you are experiencing a problem, you don’t need to do anything else–you have already successfully installed the Nvidia driver and are currently using it.
All done!
it was that the drivers from where I get for the installation, so that you can do it exactly, I will ask for the configuration for installation and the whole where I can find if it also needs to be added https://forum.garudalinux.org/t/nvidia-all-frogging-family-drivers-guide-installation / 8195
only they are ok, but when adding drivers, the solution needs no jamming for players, so what do you need to add action and also additional wine, please
There surely must be other Polish-speakers on the forum...
Ok, you have problem with wine not with NVIDIA GPU drivers in Garuda linux, I don't use wine
If u do want run in wine then install Nvidia windows driver inside wine
My suggestion :
Try gaming in virtual machine [like Virtual Box] also u can run Adobe photoshop etc etc ...
I just did not have it installed so just something strange the image under nvidia also stutters and not clearly not full not installed
