Probably another newb Q
Hello Garuda users.
OK, the mandatory garuda-inxi thing is at the bottom of this, I hope.
I’ve done my searches, and I’ve not come up with anything helpful, so…
I’m, using Garuda KDE Dragonized. Love the theming of course. Now I fire up something like vlc, or perhaps qBitorrent or whatever. They have no window decorations, so no ‘Close’ button. You have to hit the menu then ‘Quit’ or ‘Exit’.
I posted one recently about the ‘System Settings’ app which is worse, as it has window decorations, but disables the ‘Close’ button. Luckily a kind person gave me a two-key workaround for that (but still not a true fix), but I would never have known if I hadn’t asked.
Anyway, any constructive feedback welcomed!
G’night
K
╰─λ garuda-inxi
root=UUID=360ddc4a-a310-4174-b63c-ffe8787a1f4c rw rootflags=subvol=@
rd.luks.uuid=1358f973-b13a-473d-843e-792ec54a2721 quiet
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: HP product: HP EliteBook 840 G3 v: N/A
Mobo: HP model: 8079 v: KBC Version 85.77 serial: <superuser required>
UEFI: HP v: N75 Ver. 01.18 date: 10/17/2017
ID-1: BAT0 charge: 35.5 Wh (95.2%) condition: 37.3/37.3 Wh (100.0%)
volts: 12.6 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
Info: model: Intel Core i7-6600U bits: 64 type: MT MCP arch: Skylake
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3333 high: 3401 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 3239 2: 3312 3: 3401
4: 3380 bogomips: 22399
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
EliteBook 840 G3 driver: i915 v: kernel arch: Gen-9 process: Intel 14n
built: 2015-16 ports: active: DP-1 off: eDP-1
empty: DP-2,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
Device-2: Lite-On HP HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:5 chip-ID: 04ca:7054
Monitor-1: DP-1 res: 1920x1080 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
device-ID: 8086:1916 memory: 30.5 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 520 (SKL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:1916 surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard EliteBook
840 G3 driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Device-2: HP USB Audio driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5.2:6
chip-ID: 03f0:056b class-ID: 0300 serial: <filter>
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-LM vendor: Hewlett-Packard EliteBook 840 G3
driver: e1000e v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24f3 class-ID: 0280
rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3.4:6
IF: enp0s20f0u3u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 8087:0a2b
Local Storage: total: 2.29 TiB used: 1010.21 GiB (43.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD8SN8U-512G-1006
size: 476.94 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0006 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: PSSD T7
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: PSSD T7
used: 37.82 GiB (7.9%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-1358f973-b13a-473d-843e-792ec54a2721
used: 720 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: zram size: 31.23 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 54.0 C pch: 36.0 C mobo: N/A
Processes: 222 Uptime: 48m wakeups: 0 Memory: total: 32 GiB
available: 31.23 GiB used: 3.17 GiB (10.1%) Init: systemd v: 254
pm: pacman pkgs: 1461 libs: 421 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 default: Bash v: 5.2.15 running-in: konsole inxi: 3.3.31
Garuda (2.6.17-1):
System install date:     2023-09-21
Last full system update: 2023-11-07
I think in this case a screenshot would be helpful to diagnose the issue.
VLC UI option here:
check other apps for similar settings.
check Latte dock window buttons configuration
also check your kde settings. Kde allows you to completely remove all window decorations. Maybe you did that by accident?
I’ve had similar issues with KDE before, and what worked for me was to change my display scaling, fire up the application, and it would be displayed with window decoration, close button, normal.
After, resize the application window, if desired, then reset the display scaling to whatever value it was.
For me, in the past, this has done the trick. Give that a try.
You could try ctrl + q for exitting, killing app, working allmost on all apps
