Whatsup everyone. When I run on battery, I usually disable Multi-Core Processing in the bios and just run with one hyper-threaded core with the Performance governor. I've been curious how the performance compares with, say, if I run all cores hyper-threaded but set to Powersave. So I ran some benchmarks and thought maybe some of you would find it interesting as well. The result may say that the performance is about equal, or slightly better with all cores set to powersave, but I still think I'd rather have 1 core working fast than 4 cores working slow.
First my inxi because it's relevant.
â•─user@maruda in ~ took 27s
╰─λ garuda-inxi
Kernel: 6.1.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=60eceb2e-a436-41ed-8626-e6a62b3bf76d rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: LENOVO product: 427639U v: ThinkPad W520
Mobo: LENOVO model: 427639U serial: <superuser required> UEFI: LENOVO
v: 8BET45WW (1.25 ) date: 05/18/2011
ID-1: BAT0 charge: 72.0 Wh (100.0%) condition: 72.0/93.6 Wh (76.9%)
volts: 12.9 min: 11.1 model: LGC 42T4912 type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-2820QM bits: 64 type: MT MCP arch: Sandy Bridge
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2648 high: 3400 min/max: 800/3400 scaling:
driver: intel_cpufreq governor: performance cores: 1: 797 2: 2501 3: 3400
4: 3400 5: 3400 6: 3400 7: 3400 8: 886 bogomips: 36680
vulnerable
vendor: Lenovo driver: i915 v: kernel arch: Gen-6 process: Intel 32nm
built: 2011 ports: active: LVDS-1 empty: VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0126 class-ID: 0300
Device-2: NVIDIA GF108GLM [Quadro 1000M] vendor: Lenovo driver: nvidia
v: 390.157 alternate: nouveau,nvidia_drm non-free: series: 390.xx+
status: legacy-active (EOL~late 2022) arch: Fermi code: GF1xx
process: 40/28nm built: 2010-16 pcie: gen: 2 speed: 5 GT/s lanes: 16
ports: active: none empty: DP-1, DP-2, DP-3, LVDS-2, VGA-2 bus-ID: 01:00.0
chip-ID: 10de:0dfa class-ID: 0300
Device-3: Chicony Lenovo Integrated Camera (0.3MP) type: USB
driver: uvcvideo bus-ID: 1-1.6:6 chip-ID: 04f2:b217 class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: crocus
Monitor-1: LVDS-1 mapped: LVDS-1-1 model: Lenovo 0x40b2 built: 2009
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
API: OpenGL v: 4.6.0 NVIDIA 390.157 renderer: Quadro 1000M/PCIe/SSE2
direct render: Yes
vendor: Lenovo ThinkPad T520 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GF108 High Definition Audio vendor: Lenovo
bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
Sound API: ALSA v: k6.1.1-zen1-1-zen running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo ThinkPad T520
driver: e1000e v: kernel port: 6080 bus-ID: 00:19.0 chip-ID: 8086:1502
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
chip-ID: 8086:0085 class-ID: 0280
Device-3: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
bus-ID: 1-1.2:3 chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
IF: wlp0s26u1u2 state: up mac: <filter>
Device-1: Broadcom BCM2045B (BDC-2.1) type: USB driver: btusb v: 0.8
bus-ID: 1-1.4:5 chip-ID: 0a5c:217f class-ID: fe01 serial: <filter>
Local Storage: total: 704.24 GiB used: 141.98 GiB (20.2%)
model: WD5000LPCX-75VHAT1 size: 465.76 GiB block-size: physical: 4096 B
rev: 1A05 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SK Hynix model: SC210 mSATA 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 1L00 scheme: GPT
ID-1: / raw-size: 32 GiB size: 32 GiB (100.00%) used: 9.54 GiB (29.8%)
fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 608 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 205.97 GiB size: 205.97 GiB (100.00%)
used: 132.44 GiB (64.3%) fs: btrfs dev: /dev/sdb3 maj-min: 8:19
ID-4: /var/log raw-size: 32 GiB size: 32 GiB (100.00%)
used: 9.54 GiB (29.8%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-5: /var/tmp raw-size: 32 GiB size: 32 GiB (100.00%)
Kernel: swappiness: 2 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: zram size: 15.51 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 62.0 C mobo: N/A gpu: nvidia temp: 58 C
Fan Speeds (RPM): cpu: 3366
Processes: 271 Uptime: 29m wakeups: 2 Memory: 15.51 GiB
used: 2.93 GiB (18.9%) Init: systemd v: 252 default: graphical
pkgs: 1303 libs: 324 tools: octopi,pamac,paru Shell: fish v: 3.5.1
Garuda (2.6.12-1):
System install date: 2022-12-25
Last full system update: 2023-01-02
And here are the results.
GEEKBENCH 5 --- 2nd GEN CORE i7-2820QM 2.4 GHz - 3.4GHz Turbo
SINGLE CORE / PERFORMANCE
Single Core = 737
Multi Core = 728
SINGLE CORE / POWERSAVE
Single Core = 166
Multi Core = 167
SINGLE CORE / HYPER-THREADED / PERFORMANCE
Single Core = 658
Multi Core = 817
SINGLE CORE / HYPER-THREADED / POWERSAVE
Single Core = 158
Multi Core = 200
QUAD CORE / PERFORMANCE
Single Core = 741
Multi Core = 2459
QUAD CORE / POWERSAVE
Single Core = 187
Multi Core = 678
QUAD CORE / HYPER-THREADED / PERFORMANCE
Single Core = 742
Multi Core = 2790
QUAD CORE / HYPER-THREADED / POWERSAVE
Single Core = 165
Multi Core = 823`
