Hi everyone
I'm trying to find solutions from the forum, wikis, etc., to some problem I find in the system, and I just don't see it very clearly, because before shuffling trying luck (I'm not a computer scientist) with different things , I would like to know if everything comes from the same place or are they different problems. In summary I would say that they are cuts of different services (personal opinion of fan)
The fact is that at the time of entering the user there are small flashes in parts of the screen, a few seconds, then it no longer does.
There are also small cuts of wifi, it does not disconnect but the traffic is at 0B/s for a second or two. Sometimes it’s hard to load pages, although when I do speed tests, I’m more or less at 50Mbps download, 35Mbps upload, 18ms latency, and 84ms jitter.
Finally I also have cuts via bluetooth, it does not disconnect from the devices but stops transmitting sound. For example if I use a bluetooth speaker, every now and then it is not heard, even though the player and audio signal is working, I have to close the player and reopen it. Or if I’m playing from my cell phone from time to time the sound goes off, I have to disconnect and reconnect.
I leave the journalctl and inxi -Fxxxza output in case anyone has been there, sorry for the long post but I wanted to explain it in detail to make things easier for you. My English is from Google Translator. forgive me.
Thank you so much.
╭─[email protected] in ~ took 5ms
╰─λ journalctl -p 3 -xb
-- Journal begins at Wed 2021-04-07 17:08:59 CEST, ends at Tue 2021-05-11 18:42:19 CEST. --
de maig 11 17:23:22 tuxpep kernel: x86/cpu: SGX disabled by BIOS
de maig 11 17:23:23 tuxpep systemd-tmpfiles[532]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
de maig 11 17:23:23 tuxpep kernel:
de maig 11 17:23:23 tuxpep kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 460.67 Thu Mar 11 00:11:45 UTC 2021
de maig 11 17:23:24 tuxpep kernel: nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
de maig 11 17:23:24 tuxpep kernel: ucsi_ccg 0-0008: i2c_transfer failed -110
de maig 11 17:23:24 tuxpep kernel: ucsi_ccg 0-0008: ucsi_ccg_init failed - -110
de maig 11 17:23:30 tuxpep nmbd[4043]: [2021/05/11 17:23:30.985152, 0] ../../lib/util/become_daemon.c:147(daemon_status)
de maig 11 17:23:30 tuxpep nmbd[4043]: daemon_status: daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...
de maig 11 17:23:30 tuxpep nmbd[4043]: [2021/05/11 17:23:30.985266, 0] ../../source3/nmbd/nmbd_subnetdb.c:253(create_subnets)
de maig 11 17:23:30 tuxpep nmbd[4043]: NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
de maig 11 17:23:35 tuxpep sddm-helper[4055]: gkr-pam: unable to locate daemon control file
de maig 11 17:23:37 tuxpep pulseaudio[4608]: No s'ha pogut obrir el mòdul module-esound-protocol-tcp.so: module-esound-protocol-tcp.so: no s’ha pogut obrir el fitxer d’objecte compartit: El fitxer o directori no existeix
de maig 11 17:23:37 tuxpep pulseaudio[4608]: Failed to open module "module-esound-protocol-tcp".
de maig 11 17:23:37 tuxpep pulseaudio[4608]: pa_module_load() failed
de maig 11 17:23:37 tuxpep pulseaudio[4608]: connect() failed: La xarxa és inabastable
de maig 11 17:23:37 tuxpep pulseaudio[4608]: Failed to load module "module-rtp-send" (argument: "[email protected][email protected] loop=0"): initialization failed.
de maig 11 17:23:37 tuxpep pulseaudio[4608]: Master sink not found.
de maig 11 17:23:37 tuxpep pulseaudio[4608]: Failed to load module "module-ladspa-sink" (argument: "sink_name=ladspa_output.mbeq_1197.mbeq sink_master=bluez_sink.78_44_05_68_AD_77.a2dp_sink plugin=mbeq_1197 label=mbeq control=4.0,2.0,1.0>
de maig 11 17:23:37 tuxpep pulseaudio[4608]: Sink ladspa_output.mbeq_1197.mbeq does not exist.
de maig 11 17:23:37 tuxpep pulseaudio[4608]: No sink found by this name or index.
de maig 11 17:23:40 tuxpep nmbd[4043]: [2021/05/11 17:23:40.985835, 0] ../../lib/util/become_daemon.c:135(daemon_ready)
de maig 11 17:23:40 tuxpep nmbd[4043]: daemon_ready: daemon 'nmbd' finished starting up and ready to serve connections
de maig 11 17:23:41 tuxpep smbd[4878]: [2021/05/11 17:23:41.028207, 0] ../../lib/util/become_daemon.c:135(daemon_ready)
de maig 11 17:23:41 tuxpep smbd[4878]: daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
de maig 11 17:23:43 tuxpep bluetoothd[564]: src/profile.c:record_cb() Unable to get Headset Voice gateway SDP record: Host is down
de maig 11 17:24:03 tuxpep nmbd[4043]: [2021/05/11 17:24:03.056231, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
de maig 11 17:24:03 tuxpep nmbd[4043]: *****
de maig 11 17:24:03 tuxpep nmbd[4043]: Samba name server TUXPEP is now a local master browser for workgroup WORKGROUP on subnet 192.168.0.197
lines 1-34/34 (END)
The first line of Pulseaudio is in Catalan, the language of the system, and reads as follows: The module module-esound-protocol-tcp.so could not be opened: module-esound-protocol-tcp.so: no could not open shared object file: File or directory does not exist
╰─λ inxi -Fxxxza
System: Kernel: 5.12.2-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=73fd15b3-147e-42cb-8f83-fead19893501 rw
[email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 loglevel=3 nouveau.modeset=0
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop System: HP product: HP Pavilion Gaming Desktop TG01-1xxx v: N/A serial: <filter> Chassis: type: 3
Mobo: HP model: 8767 v: A (SMVB) serial: <filter> UEFI: AMI v: F.22 date: 11/27/2020
CPU: Info: 6-Core model: Intel Core i5-10400F bits: 64 type: MT MCP arch: Comet Lake family: 6 model-id: A5 (165)
stepping: 3 microcode: E0 cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 69597
Speed: 3347 MHz min/max: 800/4300 MHz Core speeds (MHz): 1: 3347 2: 4283 3: 4217 4: 4066 5: 4078 6: 4197 7: 4303
8: 4200 9: 4200 10: 4199 11: 4196 12: 4200
Graphics: Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Hewlett-Packard driver: nvidia v: 460.67
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:21c4 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x312mm (20.6x12.3") s-diag: 610mm (24")
Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 82 size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: GeForce GTX 1660 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA 460.67 direct render: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.12.2-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.27 running: yes
Network: Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0026 class-ID: e001
RAID: Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: 5020 bus-ID: 00:17.0 chip-ID: 8086.2822
rev: class-ID: 0104
Drives: Local Storage: total: 1.38 TiB used: 62.52 GiB (4.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8H size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: HPS1 scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-60WN4A1 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1A03 scheme: GPT
Partition: ID-1: / raw-size: 234.38 GiB size: 234.38 GiB (100.00%) used: 62.49 GiB (26.7%) fs: btrfs dev: /dev/nvme0n1p5
maj-min: 259:5
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 25.5 MiB (26.5%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 234.38 GiB size: 234.38 GiB (100.00%) used: 62.49 GiB (26.7%) fs: btrfs dev: /dev/nvme0n1p5
maj-min: 259:5
ID-4: /var/log raw-size: 234.38 GiB size: 234.38 GiB (100.00%) used: 62.49 GiB (26.7%) fs: btrfs
ID-5: /var/tmp raw-size: 234.38 GiB size: 234.38 GiB (100.00%) used: 62.49 GiB (26.7%) fs: btrfs
ID-1: swap-1 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
ID-9: swap-9 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram8
ID-10: swap-10 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram9
ID-11: swap-11 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram10
ID-12: swap-12 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram11
Sensors: System Temperatures: cpu: 36.0 C mobo: 27.8 C gpu: nvidia temp: 33 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 42%
Info: Processes: 334 Uptime: 1h 29m wakeups: 0 Memory: 15.5 GiB used: 3.09 GiB (19.9%) Init: systemd v: 248
tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1889 lib: 550 Shell: fish v: 3.2.2
running-in: konsole inxi: 3.3.04
Thnks a lot!
