As you can see from my inxi
inxi
Kernel: 6.3.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=6a7bcee6-f3ae-4c03-b6b0-7cb27fb4c8d4 rw rootflags=subvol=@
resume=UUID=1b9b6f2d-a19b-4eee-b2bf-6af31dfdf566 loglevel=3 ibt=off
Type: Convertible System: LENOVO product: 81X1 v: IdeaPad Flex 5 14IIL05
serial: <superuser required> Chassis: type: 31 v: IdeaPad Flex 5 14IIL05
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55722 WIN
serial: <superuser required> UEFI: LENOVO v: ECCN41WW date: 06/27/2022
ID-1: BAT0 charge: 12.1 Wh (28.9%) condition: 41.9/52.6 Wh (79.6%)
volts: 11.0 min: 11.5 model: Sunwoda L19D3PD6 type: Li-poly serial: <filter>
status: discharging cycles: 1690
Info: model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xBA
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 887 high: 1000 min/max: 400/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 875 2: 967 3: 828 4: 827
5: 929 6: 953 7: 718 8: 1000 bogomips: 23961
Device-1: Intel Iris Plus Graphics G7 vendor: Lenovo driver: i915 v: kernel
arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a52
Device-2: NVIDIA GP108M [GeForce MX330] vendor: Lenovo driver: nvidia
v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1d16
class-ID: 0302
Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 5986:212a
class-ID: 0e02
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1406 built: 2019 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: Mesa Intel Iris Plus Graphics
(ICL GT2) direct-render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-icl
alternate: snd_hda_intel,snd_sof_pci_intel_icl bus-ID: 00:1f.3
chip-ID: 8086:34c8 class-ID: 0401
API: ALSA v: k6.3.9-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.72 status: active with: 1: pipewire-pulse
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
Report: bt-adapter ID: hci0 rfk-id: 39 state: down
address: <filter>
Local Storage: total: 476.94 GiB used: 134.39 GiB (28.2%)
model: MZALQ512HALU-000L2 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 3L1QFXV7 temp: 28.9 C scheme: GPT
ID-1: / raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
used: 134.39 GiB (29.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
ID-4: /var/log raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.29 GiB used: 4.45 GiB (29.1%)
ID-2: swap-2 type: partition size: 16.82 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 54.0 C mobo: N/A
Processes: 381 Uptime: 3d 8h 5m wakeups: 8414 Memory: available: 15.29 GiB
used: 5.03 GiB (32.9%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1402
libs: 387 tools: paru Shell: fish v: 3.6.1 running-in: konsole inxi: 3.3.27
System install date: 2022-11-12
Last full system update: 2023-07-04 ↻
Failed units: hblock.service
I have both
modesetting and nvidia drivers in my system. I have a hybrid graphics scenario where I use my intel drivers by default and for any apps or games that I must run on my nvidia card I use the prime render offload. I haven’t set this up myself it came as the default when I installed garuda.
Dont’ know why the situation is different for you. Does your intel chip not provide integrated graphics?
I can check my respective graphics card usage with the following commands.
- for nvidia
nvidia-smi
- for intel integrated
sudo intel_gpu_top
(You need intel-gpu-tools for this one).
By default with no processes running on my nvidia GPU it looks like this on nvidia-smi
nvidia-smi
Fri Jul 7 10:48:37 2023
| NVIDIA-SMI 535.54.03 Driver Version: 535.54.03 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce MX330 Off | 00000000:01:00.0 Off | N/A |
| N/A 51C P8 N/A / ERR! | 4MiB / 2048MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 832 G /usr/lib/Xorg 4MiB |
Offloading any processes to this GPU will add them to it’s list on processes like my steam games that I launch with prime-run %command%
PS: I haven’t checked if the plymouth-git package works for me so I guess I can do that and see if having modesetting enabled helps.
