I just did "garuda-update", after the downloading part finished I typed "shutdown -r 10" into a new window and then I went afk to eat dinner. After I got back my system was stuck on a black screen with the error message 'setfont: KDFONTOP: Function not implemented'.
I was shutting off my pc and turned it back on, after I selected a boot option my system ever just returned to the error screen. Snapshot recovery are resulting in the same outcome. 'GRUB Commandline' and 'Garuda Linux, with Linux linux-zen (recovery mode)' are the only working things, but I don't know what to do with it. The error message 'setfont: KDFONTOP: Function not implemented' already appeared before today and ignoring it wasn't causing any problems til now.
garuda-inxi:
driver: rtu89 8852ae v: kernel modules: rtu_8852ae pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e888 bus-ID: 04:08.8 chip-ID: 18ec:8852 class-10: 8288
IF: ulp4s8 state: down mac:
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d888 bus-10: 85:88.8 chip-10: 18ec:8168 class-ID: 8280
IF: enp5s8 state: down mac: Bluetooth:
Device-1: Realtek Bluetooth Radio driver: btusb v: 8.8 type: USB rev: 1.8 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-18:6 chip-ID: 8bda: 4852 class-ID: e001 serial: Report: bt-adapter ID: hci0 rfk-id: 1 state: up address:
Drives: Local Storage: total: 477.88 GiB used: 385.33 GiB (88.6%)
ID-1: /dev/nvme8n1 maj-min: 259:8 vendor: Samsung model: MZVL2512HCJQ-88BL7 size: 476.94 GiB block-size: physical: 512 B logical: 512 8 speed: 63.2 Gb/s lanes: 4 tech: SSD serial: fu-rev: AL206XA7 temp: 41.9 C scheme: GPT SMART: yes health: PASSED on: 17d 18h cycles: 495 read-units: 32,422,874 [16.6 TB]
written-units: 9,314,458 [4.76 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Generic model: Flash Disk size: 968 MiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.8 spd: 488 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: fu-rev: 8.87 scheme: MBR
ID-1: /raw-size: 128 GiB size: 128 GiB (188.88%) used: 48.48 618 (48.4%) fs: btrfs block-size: 4096 B dev: /dev/nvmeBnip3 maj-min: 259:3
block-size: 512 B dev: /dev/nvme@nip1 maj-min: 259:1 ID-3: /home raw-size: 348.6 618 size: 348.6 GiB (188.88%) used: 336.85 GiB (98.9%) fs: btrfs
ID-2: /boot/efi rau-size: 512 MiB size: 511 MiB (99.88%) used: 576 KiB (8.1%) fs: vfat block-size: 4896 8 dev: /dev/nvme8n1p3 maj-min: 259:3 ID-5: /var/tmp rau-size: 128 GiB size: 128 GiB (188.88%) used: 48.48 GiB (48.4%) fs: btrfs block-size: 4896 B dev: /dev/nvme8n1p3 maj-min: 259:3
block-size: 4896 B dev: /dev/nvme8n1p4 maj-min: 259:4 ID-4: /var/log rau-size: 128 GiB size: 128 GiB (188.88%) used: 48.48 GiB (48.4%) fs: btrfs
Kernel: swappiness: 133 (default 68) cache-pressure: 180 (default) ID-1: swap-1 type: zran size: 15.46 GiB used: 8 KiB (0.8%) priority: 100 dev: /dev/zramB ID-2: swap-2 type: partition size: 15.83 GiB used: 8 KiB (0.8%) priority: -2 dev: /dev/nvae8n1p2 maj-min: 259:2 Sensors:
System Temperatures: cpu: 54.2 C mobo: N/A gpu: nvidia temp: 33 C Fan Speeds (RPM): N/A Info:
Processes: 242 Uptime: 8n wakeups: 2 Memory: available: 15.46 GiB used: 720.9 MiB (4.6%) Init: systemd v: 253 default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.8.7 Packages: 1762 pm: pacman pkgs: 1756 libs: 586 tools: octopi,paru pm: flatpak pkgs: 6 Shell: Bash v: 5.1.16 running-in: tty 1 inxi: 3.3.27 Garuda (2.6.16-1):
System install date: 2822-12-28 Last full system update: 2823-86-28
Relevant software:
snapper akinitcpio nvidia-dkes
Windows dual boot:
No/Undetected
[root@stk-98rc88f4ge "1#
