I am very confused …
Here what i have tried so far…
╰─λ pactl info | grep "Server Name"
Server Name: PulseAudio (on PipeWire 0.3.85)
╰─λ pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 332
Tile Size: 65472
User Name: asus
Host Name: asus-vivobookasuslaptopx412dax412da
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_03_00.6.analog-stereo
Default Source: alsa_input.pci-0000_03_00.6.analog-stereo
Cookie: 0393:b16e
╰─λ ps -e | grep pipewire
2589 ? 00:00:00 pipewire
2593 ? 00:00:00 pipewire-pulse
╰─λ grep "default-sample-rate" /etc/pulse/daemon.conf
ugrep: warning: /etc/pulse/daemon.conf: No such file or directory
NaN
19 November 2023 13:39
2
Always, always post your garuda-inxi
when asking for help.
Also what exactly are you confused about? You have pipewire in your system, pulseEffects is not going to work. So use easyeffects.
Just remember that you need to install all of easyeffects optional dependencies as well without them easyeffects is basically useless, you can’t do anything.
garuda-update -- easyeffects calf lsp-plugins-lv2 zam-plugins-lv2 mda.lv2
While installing it will ask which repository to install lv2 plugins from and will give you a bunch of choices. I will suggest going with element. Reason being it’s the most light weight of them all. With allmost no extra dependencies needed to be installed.
I am linking the preset I use, it works quite nicely for my system but I can’t guarantee for you. You can use it as a reference or a starting point if you wish or ignore it if you want.
https://termbin.com/9cmi
The preset is placed in the ~/.config/easyeffects/output/
directory as a json file and you need to explicitly ask easy effects to load it the first time.
Bro
19 November 2023 14:01
3
Use JamesDSP. There are Pulseaudio or Pipewire versions available. JamesDSP, unlike Pulse/Easy Effects. is human-configurable and human-understandable and easy to setup (except very limited pulseaudio-equalizer-ladspa), and then use @dr460nf1r3 ’s ‘no crackle fix’ (search the forum), and it’s easy-peasy lemon-squeezy.
I’m not joking.
I thinks jamesDSP from flatpak for user install(not system) is ok.
But how to know which is the main thing i am using just out of curiosity…
╭─asus@asus in ~ took 37ms
╰─λ pacman -Sqs | grep pipewire
pipewire-support
gst-plugin-pipewire
kpipewire
libpipewire
pipewire
pipewire-alsa
pipewire-audio
pipewire-docs
pipewire-ffado
pipewire-jack
pipewire-jack-client
pipewire-media-session
pipewire-pulse
pipewire-roc
pipewire-v4l2
pipewire-x11-bell
pipewire-zeroconf
qemu-audio-pipewire
lib32-libpipewire
lib32-pipewire
lib32-pipewire-jack
lib32-pipewire-v4l2
gst-plugin-pipewire-common-git
libpipewire-common-git
pipewire-common-alsa-git
pipewire-common-audio-git
pipewire-common-docs-git
pipewire-common-ffado-git
pipewire-common-git
pipewire-common-jack-git
pipewire-common-pulse-git
pipewire-common-roc-git
pipewire-common-v4l2-git
pipewire-common-x11-bell-git
pipewire-common-zeroconf-git
╭─asus@asus in ~ took 582ms
╰─λ pacman -Sqs | grep pulse
pulseaudio-support
libpulse
pipewire-pulse
projectm-pulseaudio
pulseaudio
pulseaudio-alsa
pulseaudio-bluetooth
pulseaudio-jack
pulseaudio-lirc
pulseaudio-qt
pulseaudio-rtp
pulseaudio-zeroconf
pulsemixer
pulseview
xfce4-pulseaudio-plugin
lib32-libpulse
jamesdsp-pulse
pulseaudio-control
pulseaudio-module-xrdp
pulseeffects-legacy
Here is my garuda-inxi:-
╰─λ garuda-inxi
root=UUID=2ed2acf4-12e7-497f-8e9e-ffd85e2b465f rw rootflags=subvol=@
quiet resume=UUID=2f3ba04a-a237-4756-a5f2-6aab596e0917 loglevel=3 ibt=off
Desktop: GNOME v: 45.1 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM
v: 45.0.1 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X412DA_X412DA
Mobo: ASUSTeK model: X412DA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X412DA.316 date: 10/08/2021
ID-1: BAT0 charge: 11.0 Wh (42.1%) condition: 26.1/37.1 Wh (70.4%)
power: 6.1 W volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: discharging cycles: 433
Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1464 high: 2100 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1397
3: 1397 4: 1397 5: 1226 6: 2100 7: 1400 8: 1397 bogomips: 33537
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 39.0 C
Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.1:3
chip-ID: 13d3:56dd class-ID: 0e02 serial: <filter>
compositor: gnome-shell driver: X: loaded: amdgpu
Screen-1: 0 s-res: 1280x720 s-dpi: 96 s-size: 339x191mm (13.35x7.52")
s-diag: 389mm (15.32")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x07f6 built: 2018
res: 1280x720 hz: 60 dpi: 105 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:15d8 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp3x
v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.2:4
chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 4 state: down bt-service: disabled
rfk-block: hardware: no software: yes address: see --recommends
Local Storage: total: 476.94 GiB used: 14.68 GiB (3.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
model: RBUSNS8154P3512GJ3 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: E8FK1A.2 temp: 30.9 C scheme: GPT
used: 14.68 GiB (3.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 5.73 GiB used: 854.5 MiB (14.6%)
System Temperatures: cpu: 39.2 C mobo: N/A gpu: amdgpu temp: 39.0 C
Fan Speeds (rpm): cpu: 2000
Processes: 324 Uptime: 27m wakeups: 0 Memory: total: 6 GiB
available: 5.73 GiB used: 2.37 GiB (41.3%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1142
pm: pacman pkgs: 1102 libs: 365 tools: paru pm: flatpak pkgs: 31 pm: snap
pkgs: 9 Shell: Bash v: 5.2.15 running-in: gnome-terminal inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-11-17
Last full system update: 2023-11-19
Ok got it, I have Pipewire in my system. But JamesDsp ui is my user type. Thanks its squeezy-peesy-easy… jamesdsp for pipewires
system
Closed
21 November 2023 15:08
6
