All the clocks and widgets stop fonctionning after a couple of minutes of desktop inactivity, i have to click on the desktop directly or on the clock to unfreeze the whole thing, It's like the whole desktop freezes or something.
I made a video to show an example:
Here is my garuda-inxi:
Kernel: 6.0.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=99b6afc9-ab3d-4e2c-8f83-29439ae9a164 rw [email protected]
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_wayland vt: 2
Type: Desktop System: Hewlett-Packard product: HP Z400 Workstation v: N/A
serial: <superuser required> Chassis: type: 6 serial: <superuser required>
Mobo: Hewlett-Packard model: 0B4Ch v: D serial: <superuser required>
BIOS: Hewlett-Packard v: 786G3 v03.07 date: 04/06/2010
Info: model: Intel Xeon X5675 bits: 64 type: MCP arch: Nehalem level: v2
built: 2008-10 process: Intel 45nm family: 6 model-id: 0x2C (44) stepping: 2
microcode: 0x1F
Topology: cpus: 1x cores: 6 smt: disabled cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 1739 high: 2048 min/max: 1596/3060 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2048 2: 1991
3: 1600 4: 1600 5: 1599 6: 1600 bogomips: 36797
disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT disabled
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, IBRS_FW, RSB
filling, PBRSB-eIBRS: Not affected
Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
vendor: Sapphire driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s ports: active: DP-1,DVI-D-1 empty: HDMI-A-1
bus-ID: 0f:00.0 chip-ID: 1002:699f class-ID: 0300 temp: 57.0 C
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 4570x2570
display-ID: 0
Monitor-1: DP-1 pos: top-right res: 2650x1490 size: N/A modes: N/A
Monitor-2: DVI-D-1 pos: bottom-l res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon RX 550 / 550 Series
(polaris12 LLVM 14.0.6 DRM 3.48 6.0.12-zen1-1-zen) direct render: Yes
Device-1: Intel 82801JI HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3a3e
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: Sapphire driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s bus-ID: 0f:00.1 chip-ID: 1002:aae0
Sound API: ALSA v: k6.0.12-zen1-1-zen running: yes
Device-1: Broadcom NetXtreme BCM5764M Gigabit Ethernet PCIe
vendor: Hewlett-Packard driver: tg3 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: N/A bus-ID: 01:00.0 chip-ID: 14e4:1684 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: d0c0
bus-ID: 00:1f.2 chip-ID: 8086:2822 rev: class-ID: 0104
Local Storage: total: 1.13 TiB used: 40.5 GiB (3.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: A-Data model: SU630 size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD
serial: <filter> rev: 1c87 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500DM002-1BD142
type: HDD rpm: 7200 serial: <filter> rev: KC45 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST500DM002-1BD142
ID-1: / raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
used: 40.5 GiB (18.1%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-3: /var/log raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-4: /var/tmp raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.67 GiB used: 475.8 MiB (4.0%)
System Temperatures: cpu: 32.0 C mobo: N/A gpu: amdgpu temp: 56.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1160
Processes: 283 Uptime: 10h 49m wakeups: 0 Memory: 11.67 GiB
used: 6.01 GiB (51.5%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1417
pm: pacman pkgs: 1413 libs: 360 tools: octopi,pamac,paru pm: flatpak pkgs: 4
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.24
Garuda (2.6.12-1):
System install date: 2022-11-13
Last full system update: 2022-12-21
Please, post terminal input and output as text formatted between three ~ in first and last line.
my terminal text
my terminal text
greetings SGS
