Hi,
I'm using the Garuda Dragonized edition and I ran into an issue with icons for: Garuda Assistant, Garuda Welcome, Garuda Gamer and the Garuda Settings Manager. The issue is that all of the icons displayed by these apps look pixelated when I increase the display's global scale to 125% from KDE's Display Settings menu.
Here is an example.
The issue is restricted to the Garuda apps. Other software installed on my system seems to display icons just fine.
This issue wasn't there when I had the scale set to the default 100%. I understand that a workaround is to just revert the setting, however I'd very much like to keep the 125% scale because I have a smaller, 14" screen and the text is harder to read at the default scale.
I tried looking this up, haven't found anything similar except maybe this post, but that seems like a separate problem.
garuda-inxi output:
Kernel: 6.4.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=4fdf9e35-eb8e-4181-93e8-eae07da02c42 rw rootflags=subvol=@
amd_iommu=on ibt=off
Type: Laptop System: LENOVO product: 82KC v: Lenovo V14 G2 ALC
serial: <superuser required> Chassis: type: 10 v: Lenovo V14 G2 ALC
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: GLCN46WW date: 04/29/2022
ID-1: BAT0 charge: 38.0 Wh (98.2%) condition: 38.7/38.0 Wh (101.9%)
volts: 8.4 min: 7.7 model: LGC L20L2PF0 type: Li-poly serial: <filter>
status: not charging cycles: 61
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 2081 high: 2100 min/max: 1400/4056 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2100 2: 2100
3: 2100 4: 2100 5: 2100 6: 2100 7: 2100 8: 1880 9: 2100 10: 2100 11: 2100
12: 2100 bogomips: 50302
Device-1: AMD Lucienne vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:164c class-ID: 0300
temp: 43.0 C
Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 5986:2137
class-ID: 0e02
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x208d built: 2019
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.4.2-zen1-1-zen) direct-render: Yes
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.4.2-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.73 status: active with: 1: pipewire-pulse
vendor: Lenovo driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:c822
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 0bda:c123
address: <filter>
Local Storage: total: 476.94 GiB used: 105.2 GiB (22.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo
model: UMIS RPJTJ512MEE1OWX size: 476.94 GiB block-size: physical: 512 B
fw-rev: 2.1C0628 temp: 37.9 C scheme: GPT
ID-1: / raw-size: 256.64 GiB size: 256.64 GiB (100.00%)
used: 67.42 GiB (26.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 256.64 GiB size: 256.64 GiB (100.00%)
ID-4: /var/log raw-size: 256.64 GiB size: 256.64 GiB (100.00%)
ID-5: /var/tmp raw-size: 256.64 GiB size: 256.64 GiB (100.00%)
ID-1: swap-1 type: zram size: 21.37 GiB used: 39 MiB (0.2%) priority: 100
System Temperatures: cpu: 47.8 C mobo: N/A gpu: amdgpu temp: 43.0 C
Processes: 411 Uptime: 1h 40m wakeups: 1 Memory: available: 21.37 GiB
used: 5.76 GiB (27.0%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1492 libs: 387 tools: octopi,paru,yay Shell: fish v: 3.6.1
running-in: yakuake inxi: 3.3.27
System install date: 2023-06-28
Last full system update: 2023-07-12 ↻
