Pipewire random audio cutouts
so ive just installed garuda dragonized kde and i have very often cutouts in audio
i hope someone can help me with this
Kernel: 6.5.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=a8219a55-e325-447f-a625-61753b548261 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop System: Gigabyte product: X670 AORUS ELITE AX v: -CF
Mobo: Gigabyte model: X670 AORUS ELITE AX v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F9
date: 06/06/2023
Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB desc: 12x1024 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2607 high: 4971 min/max: 400/5733 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3744 2: 3324 3: 4971
4: 400 5: 400 6: 400 7: 4963 8: 4953 9: 3712 10: 400 11: 400 12: 4965
13: 400 14: 400 15: 400 16: 400 17: 400 18: 400 19: 4953 20: 4234 21: 3542
22: 4964 23: 4931 24: 4934 bogomips: 225184
Device-1: AMD Navi 21 [Radeon RX 6950 XT] vendor: XFX driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3,HDMI-A-1
empty: DP-1,DP-2 bus-ID: 03:00.0 chip-ID: 1002:73a5 class-ID: 0300
Device-2: AMD Raphael vendor: Gigabyte driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-2
empty: DP-4,DP-5,DP-6 bus-ID: 17:00.0 chip-ID: 1002:164e class-ID: 0300
temp: 47.0 C
Screen-1: 0 s-res: 5520x1095 s-dpi: 96 s-size: 1456x288mm (57.32x11.34")
s-diag: 1484mm (58.43")
Monitor-1: DP-3 mapped: DisplayPort-2 pos: primary,middle-r
model: Samsung S24D300 serial: <filter> built: 2014 res: 1920x1080 hz: 60
dpi: 92 gamma: 1.2 size: 531x299mm (20.91x11.77") diag: 609mm (24")
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: top-center
model: Samsung C27F390 serial: <filter> built: 2019 res: 1920x1080 hz: 60
dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
Monitor-3: HDMI-A-2 mapped: HDMI-A-1-1 pos: bottom-l model: Dell 2209WA
serial: <filter> built: 2009 res: 1680x1050 hz: 60 dpi: 90 gamma: 1.2
size: 474x296mm (18.66x11.65") diag: 559mm (22") ratio: 16:10 modes:
max: 1680x1050 min: 720x400
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6950 XT (navi21 LLVM
16.0.6 DRM 3.54 6.5.8-zen1-1-zen) device-ID: 1002:73a5 memory: 15.62 GiB
unified: no
API: Vulkan v: 1.3.264 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX 6950 XT (RADV NAVI21) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:73a5 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 23.2.1-arch1.2 device-ID: 1002:164e surfaces: xcb,xlib device: 2
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 17:00.1
Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 17:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.5.8-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 10:00.0
IF: enp16s0 state: up speed: 100 Mbps duplex: full mac: <filter>
bus-ID: 11:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp17s0 state: down mac: <filter>
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 0e8d:0616
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 931.51 GiB used: 54.65 GiB (5.9%)
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 41.9 C scheme: GPT
used: 54.65 GiB (5.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 55.9 C mobo: 40.0 C
GPU: device: amdgpu temp: 55.0 C mem: 52.0 C fan: 518 watts: 56.00
device: amdgpu temp: 46.0 C
Processes: 463 Uptime: 1h 4m wakeups: 0 Memory: total: 32 GiB note: est.
available: 30.5 GiB used: 8.7 GiB (28.5%) Init: systemd v: 254
pm: pacman pkgs: 1370 libs: 440 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date:     2023-10-21
Last full system update: 2023-10-21
Please post your garuda-inxi as per the template so we can have some idea of what’s going on in your system. Also please post the full output and do not crop it.
date: 06/06/2023
temp: 47.0 C
unified: no
Garuda (2.6.17-1):
I would suggest trying out the easiest solution first. Try changing the kernel to the LTS kernel.
and then you can either go to garuda boot options software and select the default boot to option as Garuda linux with linux-lts. Or just select advanced boot optiongaruda linux with linux-lts every boot from grub.
If this doesn’t help then my friend sit tight since you are in for a journey according to the archwiki. First download alsa-utils
sudo pacman -S alsa-utils
Archwiki has a topic called Random lack of sound on startup. which says
If you have no sound on startup, this may be because your system has multiple sound cards, and their order may sometimes change on startup. If this is the case, try setting the default sound card.
And you do fit this description to a T. You have multiple sound cards and do face random lack of sound on startup.
Visit this archwiki page → Advanced Linux Sound Architecture/Troubleshooting - ArchWiki to begin troubleshooting your device.
I understand that this troubleshooting journey might be a little tedious but do hold on and post on forum if you get stuck anywhere.
Thank you so much, i ended up using the solution in section 3.2.3 in the wiki you sent me and now the sounds work better and there are no cutouts and random degradation of audio
tho they say to set it to the first name that comes out but i ended up setting ALSA_CARD to generic_1 which is my onboard sound card
:grin:
edit:
sometimes it comes back even after setting the sound card
setting the bluetooth in settings from restore previous state to enable bluetooth
and disabling and enabling bluetooth again
I hope this environment variable was set using /etc/environment file. Like this,
ALSA_CARD=generic_1
If it was try setting it to the first sound card name that comes out.
You can also look around more using
alsamixer
A tui utility that should have been a part of alsa-utils we installed before.
I am not quite sure what you are trying to convey in this line. Were you trying to share some steps to troubleshooting you have tried?
