Pipewire-pulse and pulseaudio are in conflict
Hi,
I have been using garuda for a month now but today when I wanted to upgrade using the command
sudo pacman -Syyu
I get the following output
:: pipewire-pulse and pulseaudio are in conflict. Remove pulseaudio? [y/N] y
:: pipewire-pulse and pulseaudio-modules-bt-git are in conflict (pulseaudio-bluetooth).
Remove pulseaudio-modules-bt-git? [y/N] y
:: removing pulseaudio breaks dependency 'pulseaudio=14.0-1' required by pulseaudio-jack
:: removing pulseaudio breaks dependency 'pulseaudio=14.0-1' required by pulseaudio-lirc
:: removing pulseaudio breaks dependency 'pulseaudio=14.0-1' required by pulseaudio-rtp
:: removing pulseaudio breaks dependency 'pulseaudio=14.0-1' required by pulseaudio-zeroconf
When I disagree to remove pulseaudio I get
:: pipewire-pulse and pulseaudio are in conflict. Remove pulseaudio? [y/N] n
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
Can Something Be Done
Yes.
Either remove pipewire-pulse or replace pulseaudio.
The packages conflict as Pipewire is intended as a replacement for Pulseaudio.
Thanks but will it break the system in anyway or are pipewire and pulseaudio the same
Okay I have tried it and IT WORKS !! thanks
:slight_smile:
Btw,
I am in the same boat. I have installed pipewire-pulse, and removed pulseaudio. Now I have no volume control in my tray and no audio on the system. I was not able to upgrade the rest of the system until I removed pulse due to dependencies.
here is the output of the pipewire commands on the Arch wiki
I’d suggest reinstalling Pulseaudio to remove Pipewire as a factor.
However, it sounds like you removed some other packages, e.g. a volume control, which depends specifically on a pulseaudio-* package?
I just logged in and got the same. I haven't changed anythiong yet. Will remove Pipewire and report my mileage.
―― 05:22:24 - System update ――――――――――――――――――――――――――――――――――――――――――――――――――――
[sudo] password for alienprober:
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
 chaotic-aur is up to date
resolving dependencies...
:: pipewire-pulse and pulseaudio-modules-bt-git are in conflict (pulseaudio-bluetooth). Remove pulseaudio-modules-bt-git? [y/N] y
error installing repo packages
Retry? (y)es/(N)o/(s)hell
Tried a different approach, looked a bit into what I’d need to do to replace pulseaudio, so I removed garuda-pulse and after the update all I needed to do was adding β€œ-e bluez5” to the end of the exec line at /etc/pipewire/pipewire.conf to enable bluetooth audio and then β€œsystemctl restart --user pipewire.service pipewire-pulse.service”
Rebooted the system and everything but switching between my headphones and my laptop speakers from the Plasma’s audio plasmoid work flawlessly. Pipewire is closer and closer from being a perfect substitute to pulse.
EDIT: Found that the main issue that impedes me from switching audio sources comes from an error with pipewire.service
dez 03 13:37:46 pasha-garuda systemd[927]: Started Multimedia Service.
dez 03 13:37:46 pasha-garuda pipewire[1434]: Could not get portal pid: Argument 0 is specified to be of type β€œuint32”, but is a>
dez 03 13:37:47 pasha-garuda pipewire-media-session[1436]: Register() failed: org.freedesktop.DBus.Error.ServiceUnknown
dez 03 10:39:36 pasha-garuda pipewire[1434]: alsa-pcm 0x55ceaa1572e8: snd_pcm_status error: Broken pipe
dez 03 10:41:26 pasha-garuda pipewire[1434]: alsa-pcm 0x55ceaa1572e8: snd_pcm_status error: Broken pipe
dez 03 10:42:57 pasha-garuda pipewire[1434]: alsa-pcm 0x55ceaa1572e8: snd_pcm_status error: Broken pipe
Any ideas of how one can solve this?
removing pipewire-pulse seems to have done the trick. Thanks
sudo pacman -Rns garuda-pipewire pipewire-pulse pipewire-alsa pipewire-jack
sudo pacman -Syu
this post helped me and i thank you for it .
I got no errors in grub now , also livecd had internet, no odd internet issues.
loving it ty for this distro.
How do you remove packages?
See librewish's post two post above yours.
Woof. Man. I am too dumb to live. Thanks.
I wouldn't say that. We've all looked at something and it just didn't register. Quick fix for that.
