my wifi periodically disconnects several times per hour and immediately reconnect after a few 100 ms. I have monitored my journal ctl below is the series of events before disconnecting.
I found some users have had similar problems on other forums and they recommended switching from wpa_supplicants to iwd this did not help. switch to different wifi card(same chipset different model) to test if its a hardware issue.
Do you have any recommendations where to continue?
Kernel: 6.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=bb12ebc2-6a57-4f98-a646-94523c18f119 rw rootflags=subvol=@
quiet resume=UUID=e987f210-942e-4903-9be3-ed582d859a89 loglevel=3
Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
Type: Desktop Mobo: ASUSTeK model: ROG STRIX Z390-E GAMING v: Rev 1.xx
serial: <superuser required> part-nu: ASUS_MB_CNL uuid: <superuser required>
Firmware: UEFI vendor: American Megatrends v: 1105 date: 06/06/2019
Info: model: Intel Core i7-9700K bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0x104
Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 smt: <unsupported> cache:
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4602 min/max: 800/4900 scaling: driver: intel_pstate
governor: powersave cores: 1: 4602 2: 4602 3: 4602 4: 4602 5: 4602 6: 4602
7: 4602 8: 4602 bogomips: 57600
Device-1: NVIDIA TU106 [GeForce RTX 2070 Rev. A] vendor: ASUSTeK
driver: nvidia v: 580.105.08 alternate: nouveau,nvidia_drm
non-free: 550-580.xx+ status: current (as of 2025-11; EOL~2026-12-xx)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports:
active: DP-3,HDMI-A-1 empty: DP-1,DP-2,Unknown-2 bus-ID: 01:00.0
chip-ID: 10de:1f07 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.1:19
gpu: nv_platform,nvidia,nvidia-nvswitch d-rect: 3840x1080 display-ID: 0
Monitor-1: DP-3 pos: right model: Asus VS248 serial: <filter> built: 2013
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 92 gamma: 1.2
max: 1920x1080 min: 640x480
Monitor-2: HDMI-A-1 pos: primary,left model: Asus VS248 serial: <filter>
built: 2015 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 92 gamma: 1.2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.105.08
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2
API: Vulkan v: 1.4.328 layers: 12 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 2070 driver: nvidia v: 580.105.08
device-ID: 10de:1f07 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.6 256 bits) driver: mesa llvmpipe v: 25.3.1-arch1.2 (LLVM
Device-2: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Focusrite-Novation Scarlett Solo (3rd Gen.)
driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-10:8 chip-ID: 1235:8211 class-ID: 0102 serial: <filter>
API: ALSA v: k6.17.9-zen1-1-zen status: kernel-api tools: N/A
IF: wlan0 state: down mac: <filter>
Device-2: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Device-3: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0
IF: wlan1 state: up mac: <filter>
Device-4: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9.3.2:14
IF: enp0s20f0u9u3u2 state: down mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:12
Report: btmgmt ID: hci1 rfk-id: 1 state: up address: <filter> bt-v: 5.1
Device-2: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6.2:21 chip-ID: 8087:0032
Report: ID: hci0 rfk-id: 5 state: up address: <filter> bt-v: 5.4 lmp-v: 13
status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 9.99 TiB used: 6.54 TiB (65.5%)
model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size: physical: 512 B
fw-rev: 102000WD temp: 37.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
model: WD BLACK SN750 SE 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 711240WD temp: 30.9 C scheme: GPT
model: WD8001FZBX-00ASYA0 size: 7.28 TiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 QVO 1TB
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: Intel model: SSDSC2BB480G4I 00AJ031
00AJ034IBM size: 447.13 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: NB33 scheme: GPT
ID-1: / raw-size: 431.09 GiB size: 431.09 GiB (100.00%)
used: 282.64 GiB (65.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 431.09 GiB size: 431.09 GiB (100.00%)
ID-4: /var/log raw-size: 431.09 GiB size: 431.09 GiB (100.00%)
ID-5: /var/tmp raw-size: 431.09 GiB size: 431.09 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.25 GiB used: 16.3 MiB (0.1%)
ID-2: swap-2 type: partition size: 34.38 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 38.0 C mobo: N/A
Memory: total: 32 GiB available: 31.25 GiB used: 6.52 GiB (20.9%)
Processes: 416 Power: uptime: 37m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.45 GiB services: org_kde_powerdevil,
Packages: 1768 pm: pacman pkgs: 1750 libs: 410 tools: octopi,paru
pm: flatpak pkgs: 18 Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash
v: 5.3.8 default: fish v: 4.2.1 running-in: konsole inxi: 3.3.40
Garuda (2.11.1-1):
System install date: 2025-03-30
Garuda release: 250308
Last full system update: 2025-12-07
Relevant software: snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
25/26 checks run in 0.79 seconds β
Powered by garuda-health π¦
e
β
System health check passed. No issues found.
journal during disconnect.
Dec 08 19:56:28 mg-hal9 wpa_supplicant\[805\]: wlan1: WNM: Disassociation Imminent - Disassociation Timer 60
Dec 08 19:56:28 mg-hal9 wpa_supplicant\[805\]: wlan1: WNM: Preferred List Available
Dec 08 19:56:34 mg-hal9 wpa_supplicant\[805\]: wlan1: WNM: Disassociation Imminent - Disassociation Timer 60
Dec 08 19:56:34 mg-hal9 wpa_supplicant\[805\]: wlan1: WNM: Preferred List Available
Dec 08 19:56:40 mg-hal9 wpa_supplicant\[805\]: wlan1: WNM: Disassociation Imminent - Disassociation Timer 60
Dec 08 19:56:40 mg-hal9 wpa_supplicant\[805\]: wlan1: WNM: Preferred List Available
Dec 08 19:56:47 mg-hal9 wpa_supplicant\[805\]: wlan1: WNM: Disassociation Imminent - Disassociation Timer 60
Dec 08 19:56:47 mg-hal9 wpa_supplicant\[805\]: wlan1: WNM: Preferred List Available
Dec 08 19:56:53 mg-hal9 wpa_supplicant\[805\]: wlan1: Reject scan trigger since one is already pending
Dec 08 19:56:59 mg-hal9 wpa_supplicant\[805\]: wlan1: WNM: Disassociation Imminent - Disassociation Timer 60
Dec 08 19:56:59 mg-hal9 wpa_supplicant\[805\]: wlan1: WNM: Preferred List Available
Dec 08 19:57:04 mg-hal9 wpa_supplicant\[805\]: wlan1: Reject scan trigger since one is already pending
Dec 08 19:57:05 mg-hal9 wpa_supplicant\[805\]: wlan1: SME: Trying to authenticate with 06:93:97:4f:a5:73 (SSID='ATTtw5nn6a' freq=5200 MHz)
Dec 08 19:57:05 mg-hal9 kernel: wlan1: disconnect from AP 10:93:97:4f:a5:70 for new auth to 06:93:97:4f:a5:73
Dec 08 19:57:05 mg-hal9 NetworkManager\[708\]: <info> \[1765241825.7093\] device (wlan1): ip:dhcp4: restarting
Dec 08 19:57:05 mg-hal9 NetworkManager\[708\]: <info> \[1765241825.7094\] dhcp4 (wlan1): canceled DHCP transaction
Dec 08 19:57:05 mg-hal9 NetworkManager\[708\]: <info> \[1765241825.7094\] dhcp4 (wlan1): activation: beginning transaction (timeout in 45 seconds)
Dec 08 19:57:05 mg-hal9 NetworkManager\[708\]: <info> \[1765241825.7094\] dhcp4 (wlan1): state changed no lease
Dec 08 19:57:05 mg-hal9 NetworkManager\[708\]: <info> \[1765241825.7094\] device (wlan1): ip:dhcp6: restarting
Dec 08 19:57:05 mg-hal9 NetworkManager\[708\]: <info> \[1765241825.7095\] dhcp6 (wlan1): canceled DHCP transaction
Dec 08 19:57:05 mg-hal9 NetworkManager\[708\]: <info> \[1765241825.7095\] dhcp6 (wlan1): activation: beginning transaction (timeout in 45 seconds)
Dec 08 19:57:05 mg-hal9 NetworkManager\[708\]: <info> \[1765241825.7095\] dhcp6 (wlan1): state changed no lease
Dec 08 19:57:05 mg-hal9 kernel: wlan1: authenticate with 06:93:97:4f:a5:73 (local address=d4:ab:61:b4:61:a3)
Dec 08 19:57:05 mg-hal9 NetworkManager\[708\]: <info> \[1765241825.7290\] device (wlan1): supplicant interface state: completed -> authenticating
Dec 08 19:57:05 mg-hal9 kernel: wlan1: send auth to 06:93:97:4f:a5:73 (try 1/3)
Dec 08 19:57:05 mg-hal9 NetworkManager\[708\]: <info> \[1765241825.7290\] device (p2p-dev-wlan1): supplicant management interface state: completed -> authenticating
Dec 08 19:57:05 mg-hal9 kernel: wlan1: send auth to 06:93:97:4f:a5:73 (try 2/3)
Dec 08 19:57:05 mg-hal9 kernel: wlan1: send auth to 06:93:97:4f:a5:73 (try 3/3)
Dec 08 19:57:06 mg-hal9 kernel: wlan1: authentication with 06:93:97:4f:a5:73 timed out
Dec 08 19:57:06 mg-hal9 wpa_supplicant\[805\]: wlan1: Added BSSID 06:93:97:4f:a5:73 into ignore list, ignoring for 10 seconds
Dec 08 19:57:06 mg-hal9 wpa_supplicant\[805\]: wlan1: BSSID 06:93:97:4f:a5:73 ignore list count incremented to 2, ignoring for 10 seconds
Dec 08 19:57:06 mg-hal9 NetworkManager\[708\]: <info> \[1765241826.0843\] device (wlan1): supplicant interface state: authenticating -> disconnected
Dec 08 19:57:06 mg-hal9 NetworkManager\[708\]: <info> \[1765241826.0844\] device (p2p-dev-wlan1): supplicant management interface state: authenticating -> disconnected
Dec 08 19:57:06 mg-hal9 NetworkManager\[708\]: <info> \[1765241826.1844\] device (wlan1): supplicant interface state: disconnected -> scanning
Dec 08 19:57:06 mg-hal9 NetworkManager\[708\]: <info> \[1765241826.1845\] device (p2p-dev-wlan1): supplicant management interface state: disconnected -> scanning
Dec 08 19:57:06 mg-hal9 wpa_supplicant\[805\]: wlan1: SME: Trying to authenticate with 10:93:97:4f:a5:70 (SSID='ATTtw5nn6a' freq=2412 MHz)
Dec 08 19:57:06 mg-hal9 kernel: wlan1: authenticate with 10:93:97:4f:a5:70 (local address=d4:ab:61:b4:61:a3)
Dec 08 19:57:06 mg-hal9 kernel: wlan1: send auth to 10:93:97:4f:a5:70 (try 1/3)
Dec 08 19:57:06 mg-hal9 NetworkManager\[708\]: <info> \[1765241826.2133\] device (wlan1): supplicant interface state: scanning -> authenticating
Dec 08 19:57:06 mg-hal9 NetworkManager\[708\]: <info> \[1765241826.2133\] device (p2p-dev-wlan1): supplicant management interface state: scanning -> authenticating
Dec 08 19:57:06 mg-hal9 wpa_supplicant\[805\]: wlan1: Trying to associate with 10:93:97:4f:a5:70 (SSID='ATTtw5nn6a' freq=2412 MHz)
Dec 08 19:57:06 mg-hal9 NetworkManager\[708\]: <info> \[1765241826.2437\] device (wlan1): supplicant interface state: authenticating -> associating
Dec 08 19:57:06 mg-hal9 NetworkManager\[708\]: <info> \[1765241826.2437\] device (p2p-dev-wlan1): supplicant management interface state: authenticating -> associating
Dec 08 19:57:06 mg-hal9 kernel: wlan1: authenticated
Dec 08 19:57:06 mg-hal9 kernel: wlan1: associate with 10:93:97:4f:a5:70 (try 1/3)
Dec 08 19:57:06 mg-hal9 kernel: iwlwifi 0000:02:00.0: Unhandled alg: 0x707
Dec 08 19:57:06 mg-hal9 kernel: wlan1: RX AssocResp from 10:93:97:4f:a5:70 (capab=0x411 status=30 aid=35)
Dec 08 19:57:06 mg-hal9 kernel: wlan1: 10:93:97:4f:a5:70 rejected association temporarily; comeback duration 292 TU (299 ms)
Dec 08 19:57:06 mg-hal9 kernel: wlan1: associate with 10:93:97:4f:a5:70 (try 2/3)
Dec 08 19:57:06 mg-hal9 kernel: iwlwifi 0000:02:00.0: Unhandled alg: 0x400707
Dec 08 19:57:06 mg-hal9 kernel: wlan1: associate with 10:93:97:4f:a5:70 (try 3/3)
Dec 08 19:57:06 mg-hal9 kernel: wlan1: association with 10:93:97:4f:a5:70 timed out
Dec 08 19:57:06 mg-hal9 wpa_supplicant\[805\]: wlan1: Added BSSID 10:93:97:4f:a5:70 into ignore list, ignoring for 10 seconds
Dec 08 19:57:06 mg-hal9 NetworkManager\[708\]: <info> \[1765241826.8189\] device (wlan1): supplicant interface state: associating -> disconnected
Dec 08 19:57:06 mg-hal9 NetworkManager\[708\]: <info> \[1765241826.8189\] device (p2p-dev-wlan1): supplicant management interface state: associating -> disconnected
Dec 08 19:57:07 mg-hal9 NetworkManager\[708\]: <info> \[1765241827.3174\] device (wlan1): supplicant interface state: disconnected -> scanning
Dec 08 19:57:07 mg-hal9 NetworkManager\[708\]: <info> \[1765241827.3174\] device (p2p-dev-wlan1): supplicant management interface state: disconnected -> scanning
Dec 08 19:57:07 mg-hal9 kernel: iwlwifi 0000:02:00.0: Unhandled alg: 0x703
Dec 08 19:57:08 mg-hal9 wpa_supplicant\[805\]: wlan1: Removed BSSID 10:93:97:4f:a5:70 from ignore list (clear)
Dec 08 19:57:08 mg-hal9 wpa_supplicant\[805\]: wlan1: Removed BSSID 06:93:97:4f:a5:73 from ignore list (clear)
Dec 08 19:57:08 mg-hal9 wpa_supplicant\[805\]: wlan1: SME: Trying to authenticate with 06:93:97:4f:a5:73 (SSID='ATTtw5nn6a' freq=5200 MHz)
Dec 08 19:57:08 mg-hal9 kernel: wlan1: authenticate with 06:93:97:4f:a5:73 (local address=d4:ab:61:b4:61:a3)
Dec 08 19:57:08 mg-hal9 NetworkManager\[708\]: <info> \[1765241828.4867\] device (wlan1): supplicant interface state: scanning -> authenticating
Dec 08 19:57:08 mg-hal9 NetworkManager\[708\]: <info> \[1765241828.4867\] device (p2p-dev-wlan1): supplicant management interface state: scanning -> authenticating
Dec 08 19:57:08 mg-hal9 kernel: wlan1: send auth to 06:93:97:4f:a5:73 (try 1/3)
Dec 08 19:57:08 mg-hal9 kernel: wlan1: send auth to 06:93:97:4f:a5:73 (try 2/3)
Dec 08 19:57:08 mg-hal9 kernel: wlan1: send auth to 06:93:97:4f:a5:73 (try 3/3)
Dec 08 19:57:08 mg-hal9 kernel: wlan1: authentication with 06:93:97:4f:a5:73 timed out
Dec 08 19:57:08 mg-hal9 wpa_supplicant\[805\]: wlan1: Added BSSID 06:93:97:4f:a5:73 into ignore list, ignoring for 10 seconds
Dec 08 19:57:08 mg-hal9 wpa_supplicant\[805\]: wlan1: BSSID 06:93:97:4f:a5:73 ignore list count incremented to 2, ignoring for 10 seconds
Dec 08 19:57:08 mg-hal9 NetworkManager\[708\]: <info> \[1765241828.8423\] device (wlan1): supplicant interface state: authenticating -> disconnected
Dec 08 19:57:08 mg-hal9 NetworkManager\[708\]: <info> \[1765241828.8424\] device (p2p-dev-wlan1): supplicant management interface state: authenticating -> disconnected
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.8424\] device (wlan1): supplicant interface state: disconnected -> scanning
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.8424\] device (p2p-dev-wlan1): supplicant management interface state: disconnected -> scanning
Dec 08 19:57:09 mg-hal9 wpa_supplicant\[805\]: wlan1: SME: Trying to authenticate with 10:93:97:4f:a5:70 (SSID='ATTtw5nn6a' freq=2412 MHz)
Dec 08 19:57:09 mg-hal9 kernel: wlan1: authenticate with 10:93:97:4f:a5:70 (local address=d4:ab:61:b4:61:a3)
Dec 08 19:57:09 mg-hal9 kernel: wlan1: send auth to 10:93:97:4f:a5:70 (try 1/3)
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.8734\] device (wlan1): supplicant interface state: scanning -> authenticating
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.8734\] device (p2p-dev-wlan1): supplicant management interface state: scanning -> authenticating
Dec 08 19:57:09 mg-hal9 wpa_supplicant\[805\]: wlan1: Trying to associate with 10:93:97:4f:a5:70 (SSID='ATTtw5nn6a' freq=2412 MHz)
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.9040\] device (wlan1): supplicant interface state: authenticating -> associating
Dec 08 19:57:09 mg-hal9 kernel: wlan1: authenticated
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.9040\] device (p2p-dev-wlan1): supplicant management interface state: authenticating -> associating
Dec 08 19:57:09 mg-hal9 kernel: wlan1: associate with 10:93:97:4f:a5:70 (try 1/3)
Dec 08 19:57:09 mg-hal9 kernel: wlan1: RX AssocResp from 10:93:97:4f:a5:70 (capab=0x411 status=0 aid=22)
Dec 08 19:57:09 mg-hal9 kernel: wlan1: associated
Dec 08 19:57:09 mg-hal9 wpa_supplicant\[805\]: wlan1: Associated with 10:93:97:4f:a5:70
Dec 08 19:57:09 mg-hal9 wpa_supplicant\[805\]: wlan1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.9294\] device (wlan1): supplicant interface state: associating -> associated
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.9294\] device (p2p-dev-wlan1): supplicant management interface state: associating -> associated
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.9451\] device (wlan1): supplicant interface state: associated -> 4way_handshake
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.9452\] device (p2p-dev-wlan1): supplicant management interface state: associated -> 4way_handshake
Dec 08 19:57:09 mg-hal9 kernel: wlan1: Limiting TX power to 30 (30 - 0) dBm as advertised by 10:93:97:4f:a5:70
Dec 08 19:57:09 mg-hal9 wpa_supplicant\[805\]: wlan1: WPA: Key negotiation completed with 10:93:97:4f:a5:70 \[PTK=CCMP GTK=CCMP\]
Dec 08 19:57:09 mg-hal9 wpa_supplicant\[805\]: wlan1: CTRL-EVENT-CONNECTED - Connection to 10:93:97:4f:a5:70 completed \[id=0 id_str=\]
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.9768\] device (wlan1): supplicant interface state: 4way_handshake -> completed
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.9770\] device (wlan1): ip:dhcp4: restarting
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.9841\] dhcp4 (wlan1): canceled DHCP transaction
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.9842\] dhcp4 (wlan1): state changed no lease
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.9842\] dhcp4 (wlan1): activation: beginning transaction (timeout in 45 seconds)
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.9842\] device (wlan1): ip:dhcp6: restarting
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.9843\] dhcp6 (wlan1): canceled DHCP transaction
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.9843\] dhcp6 (wlan1): state changed no lease
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.9843\] dhcp6 (wlan1): activation: beginning transaction (timeout in 45 seconds)
Dec 08 19:57:09 mg-hal9 NetworkManager\[708\]: <info> \[1765241829.9843\] device (p2p-dev-wlan1): supplicant management interface state: 4way_handshake -> completed
Dec 08 19:57:11 mg-hal9 wpa_supplicant\[805\]: wlan1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-54 noise=9999 txrate=52000
Dec 08 19:57:11 mg-hal9 NetworkManager\[708\]: <info> \[1765241831.1639\] dhcp6 (wlan1): state changed new lease, address=2600:1700:4a51:40b0::1c
Dec 08 19:57:11 mg-hal9 systemd\[1\]: Starting Network Manager Script Dispatcher Service...
ββ Subject: A start job for unit NetworkManager-dispatcher.service has begun execution
ββ Defined-By: systemd
ββ Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
ββ
ββ A start job for unit NetworkManager-dispatcher.service has begun execution.
ββ
ββ The job identifier is 8538.
Dec 08 19:57:11 mg-hal9 systemd\[1\]: Started Network Manager Script Dispatcher Service.
ββ Subject: A start job for unit NetworkManager-dispatcher.service has finished successfully
ββ
ββ A start job for unit NetworkManager-dispatcher.service has finished successfully.
ββ
Dec 08 19:57:11 mg-hal9 NetworkManager\[708\]: <info> \[1765241831.9996\] dhcp4 (wlan1): state changed new lease, address=192.168.1.156, acd pending
Dec 08 19:57:11 mg-hal9 NetworkManager\[708\]: <info> \[1765241831.9997\] dhcp4 (wlan1): state changed new lease, address=192.168.1.156
Dec 08 19:57:13 mg-hal9 wpa_supplicant\[805\]: wlan1: WNM: Disassociation Imminent - Disassociation Timer 60
Dec 08 19:57:13 mg-hal9 wpa_supplicant\[805\]: wlan1: WNM: Preferred List Available
Dec 08 19:57:20 mg-hal9 wpa_supplicant\[805\]: wlan1: WNM: Disassociation Imminent - Disassociation Timer 60
Dec 08 19:57:20 mg-hal9 wpa_supplicant\[805\]: wlan1: WNM: Preferred List Available
Dec 08 19:57:22 mg-hal9 systemd\[1\]: NetworkManager-dispatcher.service: Deactivated successfully.
