So, I don’t know if it’s just a fortuitous coincidence or if it’s a consequence of a big upgrade done in the week but since Wednesday I’ve been having consistent network problems.
I have a ROG Zephyrus to which I have long ago replaced the Realtek network card with an Intel AX210, with which on average, I was traveling on 50-60 Mbps and maximum ping 25ms, with a very stable connection, but since precisely Wednesday I experience continuous disconnections, sometimes I have to reboot the computer in order to connect to any wi fi network.
Up until last night the disconnections were periodic every half hour or so, but today the pc connects yes or no 10 minutes and then goes into a “connection on/connection off” loop, going on for even half an hour and then "this network has no internet access (right now I’m using my cell in USB tethering even just to make this topic… and the phone is using wifi, so obviously the network is not the problem).
I know there is already this topic in the forum, but I have already tested several kernels and the situation is the same:
- zen
- mainline
- lts
- lts real time
- cachy lts
[https://forum.garudalinux.org/t/intel-ax210-my-wifi-cannot-find-any-networks-solved/7258
┬─[omar@ROG-book:~]─[14:26:26]
╰─>$ garuda-inxi 14:26:26
Kernel: 6.8.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=6edd2000-1e93-4215-8ee2-7e6d4c89d6d1 rw rootflags=subvol=@
quiet resume=UUID=6e738cf9-74e8-47a5-8011-d188987253a0 loglevel=3 ibt=off
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA402RJ_GA402RJ
Mobo: ASUSTeK model: GA402RJ v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: GA402RJ.316
date: 11/10/2022
ID-1: BAT0 charge: 36.0 Wh (62.9%) condition: 57.2/76.0 Wh (75.3%)
power: 58.5 W volts: 15.9 min: 15.9 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: charging
Info: model: AMD Ryzen 9 6900HS with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 747 high: 1762 min/max: 400/4935 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1316 2: 1751 3: 1347
4: 400 5: 400 6: 400 7: 400 8: 1762 9: 1390 10: 400 11: 400 12: 400
13: 400 14: 400 15: 400 16: 400 bogomips: 105392
Device-1: AMD Navi 23 [Radeon RX 6650 XT / 6700S 6800S] vendor: ASUSTeK
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
empty: HDMI-A-1,Writeback-1,eDP-1 bus-ID: 03:00.0 chip-ID: 1002:73ef
Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-2 empty: DP-2,
DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, DP-9, Writeback-2 bus-ID: 07:00.0
chip-ID: 1002:1681 class-ID: 0300 temp: 40.0 C
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 13d3:56eb
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.0.99
gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: VG34VQEL1A serial: <filter> built: 2023
res: 3440x1440 dpi: 110 gamma: 1.2 size: 794x340mm (31.26x13.39")
diag: 864mm (34") modes: max: 3440x1440 min: 640x350
Monitor-2: eDP-2 model: TL140ADXP01 built: 2021 res: 2560x1600 dpi: 216
gamma: 1.2 size: 301x188mm (11.85x7.4") diag: 355mm (14") ratio: 16:10
modes: max: 2560x1600 min: 640x480
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu
name: AMD Radeon RX 6700S driver: amd v: 2024.Q1.3 (LLPC)
device-ID: 1002:73ef surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: AMD Radeon Graphics driver: amd
v: 2024.Q1.3 (LLPC) device-ID: 1002:1681 surfaces: xcb,xlib,wayland
Device-1: AMD Navi 21/23 HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1
chip-ID: 1002:ab28 class-ID: 0403
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 07:00.1
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 07:00.5
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.8.9-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 10-1.2.4:5
IF: enp8s0f4u1u2u4 state: down mac: <filter>
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 8087:0032
Local Storage: total: 1.62 TiB used: 213.14 GiB (12.9%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: SD256 size: 238.3 GiB block-size:
physical: 512 B logical: 512 B type: Removable tech: SSD serial: <filter>
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2450 MTFDKBA1T0TFK
lanes: 4 tech: SSD serial: <filter> fw-rev: V5MA010 temp: 33.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Kingston model: SNV2S500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: N/A
serial: <filter> fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 928.59 GiB size: 928.59 GiB (100.00%)
used: 213.14 GiB (23.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 928.59 GiB size: 928.59 GiB (100.00%)
ID-4: /var/log raw-size: 928.59 GiB size: 928.59 GiB (100.00%)
ID-5: /var/tmp raw-size: 928.59 GiB size: 928.59 GiB (100.00%)
ID-1: swap-1 type: partition size: 24.98 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 22.71 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 41.2 C mobo: N/A
Fan Speeds (rpm): cpu: 2500
GPU: device: amdgpu temp: 40.0 C device: amdgpu temp: 42.0 C mem: 38.0 C
fan: 0 watts: 4.00
Memory: total: 24 GiB note: est. available: 22.71 GiB used: 5.97 GiB (26.3%)
Processes: 411 Power: uptime: 1h 43m states: freeze,mem,disk
suspend: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 9.06 GiB services: org_kde_powerdevil,upowerd
Packages: 1916 pm: pacman pkgs: 1891 libs: 510 tools: pacseek,paru
pm: flatpak pkgs: 25 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: kitty inxi: 3.3.34
System install date: 2024-04-01
Last full system update: 2024-05-06
