Pacman 7.0.0 breaks dependency
Start with this:
 ╭─fenris@fenris in ~ took 21ms
 ╰─λ sudo garuda-inxi
[sudo] password for fenris:
  Kernel: 6.10.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=eed48c34-1b13-4d71-bad8-04acafd7f053 rw rootflags=subvol=@
    quiet rd.luks.uuid=6e967d35-e4db-410a-a8eb-2613aa0cd353
    rd.luks.uuid=79041de9-b072-44cd-a361-6b70bf057db1
    resume=/dev/mapper/luks-79041de9-b072-44cd-a361-6b70bf057db1 loglevel=3
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
  Type: Desktop Mobo: AZW model: MINI S v: 10 serial: N/A part-nu: 01
    uuid: 03000200-0400-0500-0006-000700080009 UEFI: American Megatrends LLC.
    v: ADLNV104 date: 02/06/2023
  Info: model: Intel N100 socket: U3E1 bits: 64 type: MCP arch: Alder Lake
    level: v3 note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6
    model-id: 0xBE (190) stepping: 0 microcode: 0x1A
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
    desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 1x2 MiB L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 2065 high: 2984 min/max: 700/3400 base/boost: 2871/3400
    scaling: driver: intel_pstate governor: performance volts: 1.0 V
    ext-clock: 100 MHz cores: 1: 700 2: 2575 3: 2003 4: 2984 bogomips: 6451
  Device-1: Intel Alder Lake-N [UHD Graphics] driver: i915 v: kernel
    alternate: xe arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
    active: HDMI-A-1 empty: HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:46d1
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.4:8
    chip-ID: 041e:40a0 class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
    display-ID: :0.0 screens: 1
  Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Acer G247HYL serial: <filter>
    built: 2016 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL-N)
    device-ID: 8086:46d1 memory: 7.52 GiB unified: yes
  API: Vulkan v: 1.3.295 layers: 5 device: 0 type: integrated-gpu
    name: Intel Graphics (ADL-N) driver: mesa intel v: 24.2.2-arch1.1
    device-ID: 8086:46d1 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
    (LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.2-arch1.1 (LLVM
  Device-1: Intel Alder Lake-N PCH High Definition Audio driver: snd_hda_intel
    chip-ID: 8086:54c8 class-ID: 0403
  API: ALSA v: k6.10.9-zen1-2-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.2.3 status: n/a (root, process) with:
  Device-1: Intel CNVi: Wi-Fi driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:54f0 class-ID: 0280
    bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-3: ASIX AX88179 Gigabit Ethernet driver: ax88179_178a type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-4.1:5
    chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
  IF: enp0s20f0u4u1 state: down mac: <filter>
  IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
  IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
    wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:6 chip-ID: 8087:0026
  Local Storage: total: 4.55 TiB used: 2.98 TiB (65.5%)
    model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 731100WD temp: 70.8 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM015-2E8174
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000LM015-2E8174
    size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: HDD rpm: 5400
    serial: <filter> fw-rev: 0202 scheme: MBR
  ID-1: / raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
    used: 60.95 GiB (6.7%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
    maj-min: 254:0 mapped: luks-6e967d35-e4db-410a-a8eb-2613aa0cd353
    used: 728 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1
  ID-3: /home raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
  ID-4: /var/log raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
  ID-5: /var/tmp raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
  ID-1: swap-1 type: partition size: 16.94 GiB used: 0 KiB (0.0%)
    mapped: luks-79041de9-b072-44cd-a361-6b70bf057db1
  ID-2: swap-2 type: zram size: 15.4 GiB used: 8.78 GiB (57.0%)
  System Temperatures: cpu: 81.0 C mobo: N/A
  Memory: total: 16 GiB available: 15.4 GiB used: 13.69 GiB (88.9%)
    igpu: 60 MiB
  Processes: 392 Power: uptime: 11h 8m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.15 GiB services: upowerd,xfce4-power-manager
  Packages: pm: pacman pkgs: 1546 libs: 441 tools: pamac,paru pm: appimage
    pkgs: 0 Compilers: gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash
    v: 5.2.32 running-in: xfce4-terminal inxi: 3.3.35
  System install date:     2024-09-11
  Last full system update: 2024-09-13
  Failed units:            vmware-workstation-server.service vmware.service
I had to bypass pacman in the install by modifying pacman.conf, just wondering if there is any news on if there is a fix for this other then bypassing it?
 ╭─fenris@fenris in ~ as 🧙 took 3s
 ╰─λ garuda-update --aur --noconfirm
 garuda is up to date
 core is up to date
 extra is up to date
 multilib is up to date
 chaotic-aur           723.1 KiB  95.4 KiB/s 00:08 [----------------------] 100%
 garuda downloading...
 core downloading...
 extra downloading...
 multilib downloading...
 chaotic-aur downloading...
error: failed retrieving file 'multilib.db' from mirror.osbeck.com : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
error: failed retrieving file 'extra.db' from mirror.osbeck.com : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
spawn pacman -Su
resolving dependencies...
:: installing pacman (7.0.0.r3.g7736133-1) breaks dependency 'libalpm.so=14' required by libpamac-aur
:: installing pacman (7.0.0.r3.g7736133-1) breaks dependency 'pacman<6.2' required by libpamac-aur
Like with most arch issues like this if you wait 24-48 hours it should be resolved.
Well…that is rather annoying. Even more irritating about it is that one of my computers can’t upgrade paru either. I think because of a shared dependency :face_with_raised_eyebrow:
You could use the paru-git:
https://aur.archlinux.org/packages/paru#comment-990757
Wait. I think paru was fixed in chaotic-AUR:
[🔴] × garuda-update --aur
 core is up to date
 extra                   7.4 MiB   419 KiB/s 00:18 [----------------------] 100%
 multilib              132.9 KiB  29.1 KiB/s 00:05 [----------------------] 100%
 chaotic-aur           723.3 KiB  80.3 KiB/s 00:09 [----------------------] 100%
error: failed retrieving file 'garuda.db' from cdn-mirror.chaotic.cx : Connection time-out
New mirrorlist does not contain enough mirrors. Skipping mirrorlist update.
spawn pacman -Su
warning: pacman: ignoring package upgrade (6.1.0-3 => 7.0.0.r3.g7736133-1)
warning: ignoring package pacman-7.0.0.r3.g7736133-1
warning: cannot resolve "libalpm.so=15-64", a dependency of "paru"
:: The following package cannot be upgraded due to unresolvable dependencies:
      paru
:: Do you want to skip the above package for this upgrade? [y/N] y
warning: insufficient columns available for table display
Packages (3) libgoa-3.50.5-1  lutris-git-0.5.17.r293.gac72cc3-1
             openssh-9.8p1-2
Total Download Size:    3.09 MiB
Total Installed Size:  18.53 MiB
Net Upgrade Size:       0.02 MiB
Doesn’t look fixed to me
Can’t open Pacman at all.Is this an issue as of now?Please,
Ya it is
Uh oh, I just uninstalled paru to put paru-git and it didn’t work the way I thought it would, and now, I can get paru back installed
╭─fenris@fenris in ~ as 🧙 took 3m45s
 ╰─λ sudo pacman -Ss paru
chaotic-aur/pacui 1.14-1.1
    Bash script providing advanced Pacman and
    Yay/Pikaur/Aurman/Pakku/Trizen/Paru/Pacaur/Pamac-cli functionality in a
    simple UI
chaotic-aur/paru 2.0.3-1.2 [installed: 2.0.3-1.1]
    Feature packed AUR helper
chaotic-aur/paru-git 2.0.3.r2.g90656a9-1.1
 ╭─fenris@fenris in ~ as 🧙 took 2s
 ╰─λ sudo pacman -R paru
checking dependencies...
Package (1)  Old Version  Net Change
paru         2.0.3-1.1     -8.26 MiB
Total Removed Size:  8.26 MiB
:: Do you want to remove these packages? [Y/n]
==> root: 99
(1/1) removing paru                                [----------------------] 100%
warning: /etc/paru.conf saved as /etc/paru.conf.pacsave
(1/6) Arming ConditionNeedsUpdate...
(2/6) Foreign/AUR package notification
edrawmax-bin 13.5.2-0
kvirc-git 5.2.4.r15.g7e87d9ac7-1
openoffice-bin 4.1.15-1
pcloud-drive 1.14.7-1
snapd 2.65.1-1
trezor-suite-appimage 24.8.3-1
trezor-udev 1-3
vmware-unlocker 4.2.5-2
(3/6) Orphaned package notification...
ninja 1.12.1-1
(4/6) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/locale.gen.pacnew
/etc/updatedb.conf.pacsave
/etc/sudoers.pacnew
Please check and merge
(5/6) Performing snapper post snapshots for the following configurations...
==> root: 100
(6/6) Syncing all file systems...
 ╰─λ sudo pacman -S paru-git
Package (1)           New Version            Net Change  Download Size
chaotic-aur/paru-git  2.0.3.r2.g90656a9-1.1    8.26 MiB       2.73 MiB
Total Download Size:   2.73 MiB
Total Installed Size:  8.26 MiB
:: Retrieving packages...
 paru-git-2.0.3.r...     2.7 MiB   155 KiB/s 00:18 [----------------------] 100%
(1/1) checking keys in keyring                     [----------------------] 100%
(1/1) checking package integrity                   [----------------------] 100%
(1/1) loading package files                        [----------------------] 100%
(1/1) checking for file conflicts                  [----------------------] 100%
(1/1) checking available disk space                [----------------------] 100%
==> root: 101
(1/1) installing paru-git                          [----------------------] 100%
Optional dependencies for paru-git
    bat: colored pkgbuild printing [installed]
    devtools: build in chroot and downloading pkgbuilds
    chaotic-interfere
snapd 2.65.1-1
trezor-udev 1-3
ninja 1.12.1-1
.pac* files found:
/etc/sudoers.pacnew
==> root: 102
 ╭─fenris@fenris in ~ as 🧙 took 30s
 ╰─λ paru pacman
paru: error while loading shared libraries: libalpm.so.15: cannot open shared object file: No such file or directory
 ╭─fenris@fenris in ~ as 🧙 took 3ms
[🔍] × sudo pacman -R paru-git
paru-git     2.0.3.r2.g90656a9-1.1   -8.26 MiB
==> root: 103
(1/1) removing paru-git                            [----------------------] 100%
snapd 2.65.1-1
trezor-udev 1-3
ninja 1.12.1-1
.pac* files found:
/etc/sudoers.pacnew
==> root: 104
      paru
:: Do you want to skip the above package for this upgrade? [y/N] n
:: unable to satisfy dependency 'libalpm.so=15-64' required by paru
 ╭─fenris@fenris in ~ as 🧙 took 13s
[🔴] × paru test
bash: /usr/bin/paru: No such file or directory
 ╭─fenris@fenris in ~ as 🧙 took 4ms
Thanks for your reply.So what do we do now? Please? Are there any other software manager working right now that we can install? Thanks in advance.
Hold out for awhile I guess
hey first post so go esy on me. im getting this when running pacman
:: installing pacman (7.0.0.r3.g7736133-1) breaks dependency ‘libalpm.so=14’ required by libpamac-aur
:: installing pacman (7.0.0.r3.g7736133-1) breaks dependency ‘pacman<6.2’ required by libpamac-aur
and i dont know how to fix this if anyone could save me from a fresh install you be the bee’s knees. Thanks
Welcome, please use forum search function first :slight_smile:
Solution is in post 3
I don’t know what to do with the arch post. how do i run that in terminal?
By “post 3”, he means the third post in this topic. It is a link to this comment:
It’s not a solution per se, more of an explanation as to what is causing the issue. The maintainer of the package causing your error (Pamac) will need to update the package against the new version of Pacman.
You can either hold off on updating for now and wait for that to happen, or you can uninstall Pamac and take the update, then reinstall Pamac later after it’s fixed.
I did this and removed pamac dependencies then ran the update again and it worked. Found this solution when when it happened with pacman 6
sudo pacman -R pamac-aur libpamac-aur
Once you removed pacman, what did you do to put it back on? Did you do paru pacman?
Careful, they removed pamac not pacman.
Pacman should not be removed of course.
i ran this and the up date but now i dont have the software storeup and running but no store
If you need to fix what you had…BTRFS assistant is your friend
