Pacman 7.0.0 breaks dependency
Not really clear to me what happened.
You removed pamac-all → ok a dependency was broken
So you managed to update → ok
Of course now you don’t have pamac-all anymore, if this is what you mean with “store”.
Luckily, it looks like they fixed that broken dependency (libpamac-aur), so now reinstalling pamac-all should work.
paru pamac-all
I say “should” because I’ll never use that stuff… :smiling_face:
I had the same issue but yesterday I open Garuda assistant, refresh mirrors, remove orphans, clear caches, clear packages cache and system update. Everything goes well.
Regards.
That’s because the affected packages have been updated after the thread started. Time to close it :wink:.
