Packet tracer
So i tried installing packet tracer for school, but when i start it from terminal in says:
Starting Packet Tracer 8.2.1
Fatal: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: linuxfb, xcb.
/usr/bin/packettracer línia 8: 30307 Avortat                 (s'ha bolcat la memòria)./PacketTracer "$@"
I’ve searched about linuxfb and xcb, but i found nothing to resolve the problem
  Kernel: 6.6.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=9a32edc4-ec1a-4a8b-aea5-f9d1c3bcfc11 rw rootflags=subvol=@
  Desktop: sway v: 1.8.1 info: waybar vt: 1 dm: greetd Distro: Garuda Linux
  Type: Laptop System: Micro-Star product: Prestige 16 A12UD v: REV:1.0
  Mobo: Micro-Star model: MS-1592 v: REV:1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: E1592IMS.10D date: 03/29/2023
  ID-1: BAT1 charge: 51.5 Wh (70.5%) condition: 73.0/80.3 Wh (90.9%)
    volts: 16.7 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
    status: charging
  Info: model: 12th Gen Intel Core i7-1280P bits: 64 type: MST AMCP
    arch: Alder Lake level: v3 note: check built: 2021+
    microcode: 0x430
  Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
    cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
    L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 413 high: 500 min/max: 400/4700:4800:3600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
    5: 497 6: 400 7: 500 8: 400 9: 400 10: 400 11: 479 12: 400 13: 400 14: 400
    15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 79872
  Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Micro-Star MSI
    driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
    ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:46a6 class-ID: 0300
  Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile]
    vendor: Micro-Star MSI driver: nouveau v: kernel non-free: 545.xx+
    status: current (as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
    lanes: 4 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a0
    class-ID: 0302
  Display: wayland server: Xwayland v: 23.2.2 compositor: sway v: 1.8.1
    driver: gpu: i915 display-ID: 1
  Monitor-1: eDP-1 model: AU Optronics 0xdb95 built: 2021 res: 2560x1600
    hz: 165 dpi: 189 gamma: 1.2 scale: 1.29999995231628
    size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10
    modes: 2560x1600
  API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
    Graphics (ADL GT2) driver: mesa intel v: 23.2.1-arch1.2
    device-ID: 8086:46a6 surfaces: xcb,xlib,wayland device: 1 type: cpu
    vendor: Micro-Star MSI driver: sof-audio-pci-intel-tgl
    chip-ID: 8086:51c8 class-ID: 0401
  API: ALSA v: k6.6.3-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
  Device-1: Intel Alder Lake-P PCH CNVi WiFi vendor: Rivet Networks
    driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-2.4:3
  IF: enp0s20f0u2u4 state: up speed: 100 Mbps duplex: full mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0033
    lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c010c
  Local Storage: total: 953.87 GiB used: 14.55 GiB (1.5%)
    model: MZVL21T0HCLR-00B00 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: GXA7601Q temp: 34.9 C scheme: GPT
  ID-1: / raw-size: 75.71 GiB size: 75.71 GiB (100.00%)
    used: 14.52 GiB (19.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
    used: 30.7 MiB (32.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 75.71 GiB size: 75.71 GiB (100.00%)
  ID-4: /var/log raw-size: 75.71 GiB size: 75.71 GiB (100.00%)
  ID-5: /var/tmp raw-size: 75.71 GiB size: 75.71 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.32 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20 dev: /dev/zram0
  Src: /sys System Temperatures: cpu: 30.0 C mobo: N/A
  Processes: 457 Uptime: 1h 24m wakeups: 0 Memory: total: 16 GiB note: est.
  available: 15.32 GiB used: 4.8 GiB (31.3%) Init: systemd v: 254
  pm: pacman pkgs: 1297 libs: 405 tools: paru Shell: fish v: 3.6.1
  running-in: alacritty inxi: 3.3.31
Garuda (2.6.19-2):
  System install date:     2023-12-01
  Last full system update: 2023-12-04 ↻
means there is a pending reboot. Try seeing if the issue persists after a reboot.
If still not working, try launching from terminal with
packettracer -platform xcb
It opens and says this:
Qt WebEngine resources not found at /opt/packettracer/bin/resources. Trying parent directory...
Installed Qt WebEngine locales directory not found at location /opt/packettracer/bin/translations/qtwebengine_locales. Trying application directory...
Is there a way to install linuxfb and xcb so the app can be opened normally
Looks like it fails to find the Qt plugin for wayland, which depending on the Qt version used by Packet Tracer (5 I guess), is provided by either qt-wayland or qt6-wayland.
I recall having this problem in the past but forgot the details.
I have a line in my history where I run a program with
QT_QPA_PLATFORM_PLUGIN_PATH=/usr/lib/qt/plugins/platforms COMMAND
I can’t remember if that worked though.
Online I see advised
QT_PLUGIN_PATH=/usr/lib/qt/plugins
instead.
Give both a try, it won’t hurt.
It’s /usr/lib/qt6/... in case it’s Qt 6.
QT_QPA_PLATFORM=wayland
should be already set by default.
/usr/lib/qt/plugins/platforms (on my computer)
.rwxr-xr-x  18k root 25 nov 14:08  libqeglfs.so
.rwxr-xr-x 449k root 25 nov 14:08  libqlinuxfb.so
.rwxr-xr-x 141k root 25 nov 14:08  libqminimal.so
.rwxr-xr-x 166k root 25 nov 14:08  libqminimalegl.so
.rwxr-xr-x 174k root 25 nov 14:08  libqoffscreen.so
.rwxr-xr-x 244k root 25 nov 14:08  libqvnc.so
.rwxr-xr-x  68k root 24 ott 11:36  libqwayland-egl.so
.rwxr-xr-x  18k root 24 ott 11:36  libqwayland-generic.so
.rwxr-xr-x  72k root 24 ott 11:36  libqwayland-xcomposite-egl.so
.rwxr-xr-x  51k root 24 ott 11:36  libqwayland-xcomposite-glx.so
.rwxr-xr-x  18k root 25 nov 14:08  libqxcb.so
I’ve this in /usr/lib/qt/plugins/platforms:
.rwxr-xr-x  68k root 24 oct 11:36  libqwayland-egl.so
.rwxr-xr-x  18k root 24 oct 11:36  libqwayland-generic.so
.rwxr-xr-x  72k root 24 oct 11:36  libqwayland-xcomposite-egl.so
.rwxr-xr-x  51k root 24 oct 11:36  libqwayland-xcomposite-glx.so
And I’ve this in /usr/lib/qt6/plugins/platforms:
.rwxr-xr-x  19k root 27 nov 08:51  libqeglfs.so
.rwxr-xr-x 373k root 27 nov 08:51  libqlinuxfb.so
.rwxr-xr-x  31k root 27 nov 08:51  libqminimal.so
.rwxr-xr-x  43k root 27 nov 08:51  libqminimalegl.so
.rwxr-xr-x 109k root 27 nov 08:51  libqoffscreen.so
.rwxr-xr-x 233k root 27 nov 08:51  libqvkkhrdisplay.so
.rwxr-xr-x 110k root 27 nov 08:51  libqvnc.so
.rwxr-xr-x  23k root 27 nov 17:34  libqwayland-egl.so
.rwxr-xr-x  19k root 27 nov 17:34  libqwayland-generic.so
.rwxr-xr-x  19k root 27 nov 08:51  libqxcb.so
OK so the files are there (would have surprised me otherwise), did any of those two variables work?
edit: note the VARIABLE=VALUE command syntax, it runs command with that variable temporarily set.
They don’t work
 ╭─confusedyeti@confusedyeti in /usr/lib/qt6/plugins/platforms🔒 as 🧙 took 10ms
 ╰─λ QT_QPA_PLATFORM_PLUGIN_PATH=/usr/lib/qt/plugins/platforms
fish: Unsupported use of '='. In fish, please use 'set QT_QPA_PLATFORM_PLUGIN_PATH /usr/lib/qt/plugins/platforms'.
[🔴] × set QT_QPA_PLATFORM_PLUGIN_PATH /usr/lib/qt/plugins/platforms
See “edit:” above, not just VARIABLE=VALUE then command, but all in one line.
QT_QPA_PLATFORM_PLUGIN_PATH=/usr/lib/qt/plugins/platforms COMMAND,
what do I need to wrtie instead of command?
packettracer?
Anyway, the second line I did not notice before, that is OK too.
Just run it, you did set the variable in that shell session.
QT_QPA_PLATFORM_PLUGIN_PATH=/usr/lib/qt/plugins/platforms packettracer
That’s all the error message?
So it now found the Qt plugin, but still fails to find its own resources (and locales, but that’s not a show stopper)?
It didn’t a pear any new line but it does not stop
I mean, no more
No, this error does not appear anymore
Good.
How is packettracer installed? AUR package or direct download from Cisco or?
I followed the aur, git clone it, go to packet tracer page, download .deb put it into the directory i just clonet and then makepkg -i
Ah, my sight is not good.
It’s not “its own resources”, it’s still something Qt it cannot find.
Give me a minute.
Is qt5-webengine installed?
Nevermind, it’s in the PKGBUILD dependencies… must be something else.
Yes and I’ve reinstall it
