This is a common problem and has been asked allot. I have this error when I do a garuda-update
:: Retrieving packages...
chaotic-keyring-20220803-1-any downloading...
checking keyring...
checking package integrity...
error: chaotic-keyring: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/chaotic-keyring-20220803-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] error: failed to commit transaction (invalid or corrupted package (PGP signature))
What I have tried to do is
sudo pacman -Sy archlinux-keyring chaotic-keyring
garuda-update remote keyring
sudo pacman-key --refresh-keys
sudo pacman -U 'https://cdn-mirror.chaotic.cx/chaotic-aur/chaotic-keyring.pkg.tar.zst' 'https://cdn-mirror.chaotic.cx/chaotic-aur/chaotic-mirrorlist.pkg.tar.zst'
Aditionaly I used the garuda assistant to refresh keyrings and I am unable to update my system. This seemed to have happened in the past few days as previously I was only using the pamac utility to upgrade my system and it was successful for the past week or so. Its only in the past day or so that I started having failures. Only other system changes was installing steam games. Not sure how to solve this keyring problem. Any guidance would be appreciated. See my garuda-inxi here:
Kernel: 6.3.5-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=dcbd50b9-1e83-4eb3-9da5-43e6e7fb35bb rw rootflags=subvol=@
resume=UUID=ec4cbef9-6a00-4c35-be6f-587f055fd4dd loglevel=3 ibt=off
Desktop: GNOME v: 44.2 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Desktop System: Gigabyte product: Z690 UD AX DDR4 v: N/A
Mobo: Gigabyte model: Z690 UD AX DDR4 v: x.x serial: <superuser required>
UEFI: American Megatrends LLC. v: F7 date: 08/08/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MWireless M
serial: N/A charge: 100% (should be ignored) rechargeable: yes
Info: model: 13th Gen Intel Core i5-13600K bits: 64 type: MST AMCP
microcode: 0x113
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.7 MiB desc: d-8x32 KiB, 12x48 KiB; i-12x32 KiB, 8x64 KiB
L2: 56 MiB desc: 12x2 MiB, 8x4 MiB L3: 480 MiB desc: 20x24 MiB
Speed (MHz): avg: 3304 high: 5111 min/max: 800/5100:3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 4908 2: 3401 3: 5111
4: 3500 5: 800 6: 3500 7: 4823 8: 3500 9: 2003 10: 3500 11: 5100 12: 3500
13: 798 14: 3345 15: 3500 16: 805 17: 3500 18: 3500 19: 3500 20: 3500
bogomips: 139776
Device-1: Intel Raptor Lake-S GT1 [UHD Graphics 770] vendor: Gigabyte
driver: i915 v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+
ports: active: none empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:a780 class-ID: 0300
Device-2: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: ASUSTeK
active: HDMI-A-3 empty: DP-2,DP-3,DP-4 bus-ID: 03:00.0 chip-ID: 1002:73ff
compositor: gnome-shell driver: X: loaded: amdgpu,modesetting
unloaded: radeon alternate: fbdev,intel,vesa dri: radeonsi,iris
s-diag: 1165mm (45.88")
Monitor-1: HDMI-A-3 mapped: HDMI-A-2 model: Samsung LS32R75
serial: <filter> built: 2019 res: 3840x2160 hz: 60 dpi: 140 gamma: 1.2
max: 3840x2160 min: 720x400
API: OpenGL v: 4.6 Mesa 23.1.1 renderer: AMD Radeon RX 6600 XT (navi23
LLVM 15.0.7 DRM 3.52 6.3.5-zen2-1-zen) direct-render: Yes
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
API: ALSA v: k6.3.5-zen2-1-zen status: kernel-api tools: N/A
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 8087:0033 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 5 state: up address: <filter>
Local Storage: total: 3.98 TiB used: 419.52 GiB (10.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: BarraCuda 120 SSD
ZA1000CM10003 size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: E014 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SV300S37A120G
tech: SSD serial: <filter> fw-rev: BBF0 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3000DM008-2DM166
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC26 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 850 PRO 256GB
ID-1: / raw-size: 896.98 GiB size: 896.98 GiB (100.00%)
used: 419.52 GiB (46.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 580 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 896.98 GiB size: 896.98 GiB (100.00%)
ID-4: /var/log raw-size: 896.98 GiB size: 896.98 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.98 GiB size: 896.98 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.12 GiB used: 794.9 MiB (2.5%)
ID-2: swap-2 type: partition size: 34.24 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 31.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
mem: 38.0 C
Processes: 484 Uptime: 8d 6h 34m wakeups: 78 Memory: available: 31.12 GiB
used: 9.58 GiB (30.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 alt: 12 clang: 15.0.7 Packages:
pm: dpkg pkgs: 0 pm: pacman pkgs: 1704 libs: 511
tools: gnome-software,pamac,paru Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.27
System install date: 2023-03-16
Last full system update: 2023-06-07 â»
Is partially upgraded: Yes
System details :
jen@jennifer-z690udaxddr4
OS: Garuda Linux x86_64
Host: Z690 UD AX DDR4
Uptime: 8 days, 6 hours, 28 mins
Packages: 1704 (pacman)[stable]
Shell: fish 3.6.1
Display: 3840x2160
DE: Gnome 44.2
WM: Mutter (X11)
WM Theme: Adwaita
Theme: [Plasma], {?}Adwaita [GTK2/3/4]
Icons: Adwaita [GTK2/3/4]
Terminal: gnome-terminal-server 3.48.1
Terminal Font: FiraCode Nerd Font Mono 12
CPU: 13th Gen Intel(R) Core(TM) i5-13600K (20) @ 5.1 GHz
GPU: Intel UHD Graphics 770
GPU: AMD Radeon RX 6600 XT
Memory: 7.74 GiB / 31.12 GiB
