Obligatory inxi - however little relevance it has in this case
┌06:12:17 WD= [~]
└───freebird@nest ─▶$ inxi -Faz
Kernel: 6.3.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=d7e2905f-a721-4129-8b88-6010754d074d rw rootflags=subvol=@
splash loglevel=3 nowatchdog ibt=off
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel, plank
wm: xfwm v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda Linux
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 1407
date: 04/01/2020
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3709 high: 4391 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3630 2: 3731
3: 4265 4: 4391 5: 3600 6: 3589 7: 3592 8: 3586 9: 3600 10: 3665 11: 3744
12: 3593 13: 3600 14: 3586 15: 3588 16: 3589 bogomips: 114985
protection
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DVI-D-1,HDMI-A-2
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 08:00.0 chip-ID: 1002:67df
class-ID: 0300 temp: 55.0 C
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
Screen-1: 0 s-res: 5640x2400 s-dpi: 96 s-size: 1492x635mm (58.74x25.00")
s-diag: 1622mm (63.84")
Monitor-1: DVI-D-1 mapped: DVI-D-0 pos: right model: NEC LCD2090UXi
serial: <filter> built: 2006 res: 1800x2400 hz: 60 dpi: 149 gamma: 1.2
size: 306x408mm (12.05x16.06") diag: 510mm (20.1") ratio: 4:3 modes:
max: 1600x1200 min: 720x400
Monitor-2: HDMI-A-2 mapped: HDMI-A-1 pos: primary,left model: BenQ EL2870U
serial: <filter> built: 2018 res: 3840x2160 hz: 60 dpi: 157 gamma: 1.2
size: 621x341mm (24.45x13.43") diag: 708mm (27.9") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
missing.
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 1002:aaf0 class-ID: 0403
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.3.8-zen1-1-zen status: kernel-api with: aoss
Server-1: JACK v: 1.9.22 status: off with: a2jmidid status: off
tools: qjackctl
Server-2: PipeWire v: 0.3.71 status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: off with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: zdata type: zfs status: ONLINE level: linear raw: size: 2.72 TiB
free: 1.17 TiB allocated: 1.55 TiB zfs-fs: size: 2.63 TiB free: 1.08 TiB
Components: Online:
1:
Local Storage: total: raw: 3.64 TiB usable: 6.27 TiB used: 1.58 TiB (25.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP600
lanes: 4 tech: SSD serial: <filter> fw-rev: EGFM11.3 temp: 46.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3000DM001-1CH166
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC27 scheme: GPT
ID-1: / raw-size: 92.07 GiB size: 92.07 GiB (100.00%)
used: 30.89 GiB (33.6%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 235.2 MiB (23.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 92.07 GiB size: 92.07 GiB (100.00%)
ID-4: /var/log raw-size: 92.07 GiB size: 92.07 GiB (100.00%)
ID-5: /var/tmp raw-size: 92.07 GiB size: 92.07 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.25 GiB used: 1.2 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 32.81 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: 62.4 C mobo: N/A gpu: amdgpu temp: 55.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1164
Processes: 493 Uptime: 10m wakeups: 0 Memory: available: 31.25 GiB
used: 9.6 GiB (30.7%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1694 libs: 433 tools: pamac,yay Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.27
Cannot currently update because of this error:
nss-hg: /usr/lib/p11-kit-trust.so exists in filesystem
Having no familiarity with this item, or its affiliation, not sure how to proceed. Do I run with an overwrite? Just delete it? Other response? Thanks for any feedback…
