inxi -Faz
System: Kernel: 5.10.67-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=789aae57-fb43-4b3e-93d8-2f693d096e94 rw
rootflags=subvol=@ loglevel=3 quiet sysrq_always_enabled=1 splash
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux base: Arch Linux
Machine: Type: Laptop System: Micro-Star product: Please change product name v: REV:1.0 serial: <filter> Chassis: type: 10
Mobo: Micro-Star model: MS-16J9 v: REV:1.0 serial: <filter> UEFI: American Megatrends v: E16J9IMS.324
date: 03/23/2018
Battery: ID-1: BAT1 charge: 19.6 Wh (90.3%) condition: 21.7/43.2 Wh (50.2%) volts: 12.1 min: 10.8 model: MSI BIF0_9
type: Li-ion serial: N/A status: Unknown
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3 serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
CPU: Info: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake family: 6 model-id: 9E (158)
stepping: 9 microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44798
Speed: 3602 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 3602 2: 3569 3: 3708 4: 3677 5: 3610 6: 3604 7: 3732
8: 3498
Graphics: Device-1: Intel HD Graphics 630 vendor: Micro-Star MSI driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:591b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Micro-Star MSI driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c8d class-ID: 0302
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting,nvidia display-ID: :0
Screen-1: 0 s-res: 4480x1586 s-dpi: 96 s-size: 1185x419mm (46.7x16.5") s-diag: 1257mm (49.5")
Monitor-1: eDP-1 res: 1920x1080 dpi: 142 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
Monitor-2: HDMI-2 res: 2560x1440 hz: 58 dpi: 107 size: 608x345mm (23.9x13.6") diag: 699mm (27.5")
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 21.2.1 direct render: Yes
Audio: Device-1: Intel CM238 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:a171 class-ID: 0403
Device-2: Realtek TX-Hifi Type_C Audio type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5:2
chip-ID: 0bda:4c07 class-ID: 0300
Sound Server-1: ALSA v: k5.10.67-1-lts running: yes
Sound Server-4: PipeWire v: 0.3.35 running: no
Network: Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel port: e000 bus-ID: 02:00.0
Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: Micro-Star MSI driver: alx v: kernel port: d000
bus-ID: 03:00.0 chip-ID: 1969:10a1 class-ID: 0200
Bluetooth: Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-10:5 chip-ID: 8087:0aa7
Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
Drives: Local Storage: total: 5 TiB used: 58.16 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P1SSD8 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: P3CR010 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000BX500SSD1 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 030 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Toshiba model: External USB 3.0 size: 3.64 TiB block-size:
physical: 4096 B logical: 512 B type: N/A serial: <filter> rev: 5438 scheme: GPT
Partition: ID-1: / raw-size: 119.21 GiB size: 119.21 GiB (100.00%) used: 15.31 GiB (12.8%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 128 MiB size: 126 MiB (98.45%) used: 562 KiB (0.4%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 139.7 GiB size: 139.7 GiB (100.00%) used: 42.84 GiB (30.7%) fs: btrfs dev: /dev/nvme0n1p9
maj-min: 259:6
ID-4: /var/log raw-size: 119.21 GiB size: 119.21 GiB (100.00%) used: 15.31 GiB (12.8%) fs: btrfs
ID-5: /var/tmp raw-size: 119.21 GiB size: 119.21 GiB (100.00%) used: 15.31 GiB (12.8%) fs: btrfs
ID-1: swap-1 type: partition size: 14.9 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:4
ID-2: swap-2 type: zram size: 15.55 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 50.5 C mobo: 27.8 C
Info: Processes: 297 Uptime: 24m wakeups: 3 Memory: 15.55 GiB used: 3.97 GiB (25.5%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1057 lib: 290 Shell: fish v: 3.3.1 running-in: yakuake
inxi: 3.3.06
When using update-grub, the os-prober-btrfs finds all my OS without any trouble, the Garuda entries (on BTRFS) boot perfectly, but my other Linux distributions won't boot from the Garuda's GRUB bootloader. The entries for other Linux distros are generated as follows:
setparams 'Manjaro Linux (31.1.3) (on /dev/nvme0n1p6)'
insmod part_gpt
insmod ext2
search --no-floppy -fs-uuid --set=root <UUID>
linux /boot/vmlinuz/5.11-rt-x86_64 root=<UUID> rw quiet
initrd /boot/intel-ucode.img^/boot/amd-ucode.img^/boot/initramfs-5.11-rt-x86_64.img
As far as I can understand, the problem lies within that last line, since the images are separated by a '^' character instead of an space. If I manually replace those ^ by spaces, the distro boots without problem. Otherwise, it fails to boot.
I would like to know if this is a known bug or is there a way for me to make this work.
The installed version of os-prober-btrfs is:
chaotic-aur/os-prober-btrfs 1.79-3 [installed]
PS. I just installed Garuda yesterday. This problem was there from the moment I installed it.
