Hi everyone
inxi -Faz
Kernel: 5.15.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6f58aafa-9f36-4ae5-940b-ca0f2c54cd24 rw rootflags=subvol=@
Type: Desktop System: HP product: HP Z4 G4 Workstation v: N/A
Mobo: HP model: 81C5 v: MVB serial: <superuser required> UEFI: HP
v: P62 v02.75 date: 09/28/2021
status: Discharging
Info: model: Intel Core i9-10920X bits: 64 type: MT MCP arch: Cascade Lake
family: 6 model-id: 0x55 (85) stepping: 7 microcode: 0x5003103
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB desc: 12x1024 KiB
L3: 19.2 MiB desc: 1x19.2 MiB
Speed (MHz): avg: 2191 high: 4265 min/max: 1200/4800:4600:4700 scaling:
driver: intel_pstate governor: performance cores: 1: 2210 2: 1200 3: 1201
4: 1956 5: 4265 6: 3498 7: 2013 8: 2366 9: 3664 10: 1956 11: 1201
12: 2481 13: 1311 14: 2243 15: 1631 16: 1201 17: 1201 18: 1200 19: 2424
20: 1200 21: 3274 22: 2601 23: 2633 24: 3654 bogomips: 167995
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: PNY
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 21:00.0
chip-ID: 10de:1e07 class-ID: 0300
Device-2: Logitech StreamCam type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 2-5:2
chip-ID: 046d:0893 class-ID: 0300 serial: <filter>
loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 162 s-size: 602x341mm (23.7x13.4")
s-diag: 692mm (27.2")
Monitor-1: DP-2 res: 3840x2160 hz: 60 dpi: 163
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Device-1: Intel 200 Series PCH HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
Device-2: NVIDIA TU102 High Definition Audio vendor: PNY
driver: snd_hda_intel v: kernel bus-ID: 21:00.1 chip-ID: 10de:10f7
Device-3: Blue Microphones Yeti Stereo Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-13:7 chip-ID: b58e:9e84
Device-4: Logitech StreamCam type: USB
Sound Server-1: ALSA v: k5.15.12-zen1-1-zen running: yes
Device-1: Intel Ethernet I219-V vendor: Hewlett-Packard driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 07:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
bus-ID: 1-12:6 chip-ID: 8087:0029 class-ID: e001
Hardware-1: Intel C600/X79 series SATA RAID Controller driver: ahci v: 3.0
port: 2020 bus-ID: 00:17.0 chip-ID: 8086:2826 rev: class-ID: 0104
Local Storage: total: 2.75 TiB used: 548.89 GiB (19.5%)
model: MZVLB1T0HBLR-000H1 size: 953.87 GiB block-size: physical: 512 B
rev: HPS0NEXF temp: 29.9 C scheme: GPT
model: WD20EZRZ-00Z5HB0 size: 1.82 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
ID-1: / raw-size: 68.25 GiB size: 68.25 GiB (100.00%)
used: 51.54 GiB (75.5%) fs: btrfs dev: /dev/nvme0n1p12 maj-min: 259:12
used: 135.5 MiB (52.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 49.53 GiB size: 49.53 GiB (100.00%)
used: 15.65 GiB (31.6%) fs: btrfs dev: /dev/nvme0n1p11 maj-min: 259:11
ID-4: /var/log raw-size: 68.25 GiB size: 68.25 GiB (100.00%)
ID-5: /var/tmp raw-size: 68.25 GiB size: 68.25 GiB (100.00%)
ID-1: swap-1 type: partition size: 32.91 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p9 maj-min: 259:9
ID-2: swap-2 type: zram size: 31.14 GiB used: 256 KiB (0.0%)
System Temperatures: cpu: 38.0 C mobo: N/A gpu: nvidia temp: 45 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 32%
Processes: 504 Uptime: 11m wakeups: 2 Memory: 31.14 GiB
used: 6.41 GiB (20.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1557 lib: 353 Shell: fish
v: 3.3.1 running-in: konsole inxi: 3.3.11
there's something wrong with further linux os when running grub-mkconfig
in /boot/grub/grub.cfg the output lines for that os contain an undesired ^ simbol instead of blank space, like this:
initrd /boot/intel-ucode.img^/boot/initramfs-linux.img
found the same in that discussion:
Os-prober-btrfs generating faulty entries
seems like an update took away a snippet of code in /etc/grub.d/30_os-prober; here are actual lines 213 and 214:
LINITRD="`echo ${LINUX} | cut -d ':' -f 5`"
LPARAMS="`echo ${LINUX} | cut -d ':' -f 6- | tr '^' ' '`"
line 213 miss the final | tr '^' ' '
inserting it and running again grub-mkconfig, all is right again
on my archlinux installation there's the same line 213, and same problem with os-prober
on manjaro, line 213 is correct
I'm not so expert about the package maintenance chain: which is the right place to notify this?
until patch, changing that line and re-running grub-mkconfig can set things right if anyone found the same problem
