I've had a similar issue in the past and there's an old post about it here, at first it was solved by installing the LTS Kernel but that doesn't seem to be the case now...
I've tried disabling the compositor and didn't work either, i had to reinstall Garuda because i changed my HDD for an SSD recently, hardware is still the same (8GB DDR3 RAM x2 1066MHz, I5 3470 and the integrated graphics card which is an Intel HD 2,500) for some reason this issue is only affecting that one game, all the others appear to work fine. The issue is just the same as in the previous post (See System logs out when i put games on fullscreen - #5 by IronRose for more information).
╰─λ inxi -Faz
Kernel: 5.15.33-1-lts arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=13cb63b1-f18c-4a17-b803-8b3479656813 rw [email protected]
Type: Desktop Mobo: Intel model: DH61CR v: AAG14064-210
serial: <superuser required> BIOS: Intel
v: BEH6110H.86A.0109.2012.1221.1455 date: 12/21/2012
Info: model: Intel Core i5-3470 bits: 64 type: MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
desc: 1x6 MiB
Speed (MHz): avg: 1718 high: 1850 min/max: 1600/3600 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1850 2: 1638 3: 1728
4: 1658 bogomips: 25541
Type: l1tf
STIBP: disabled, RSB filling
Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics
driver: i915 v: kernel ports: active: VGA-1 empty: DP-1,HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:0152 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1280x1024 s-dpi: 96 s-size: 338x270mm (13.31x10.63")
s-diag: 433mm (17.03")
Monitor-1: VGA-1 mapped: VGA1 model: HP L1740 serial: <filter>
built: 2006 res: 1280x1024 hz: 60 dpi: 99 gamma: 1.2
size: 330x270mm (12.99x10.63") diag: 426mm (16.8") ratio: 5:4 modes:
max: 1280x1024 min: 720x400
OpenGL: renderer: Mesa Intel HD Graphics 2500 (IVB GT1)
v: 4.2 Mesa 22.0.1 compat-v: 3.1 direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
Sound Server-1: ALSA v: k5.15.33-1-lts running: yes
Device-1: Intel 82579V Gigabit Network driver: e1000e v: kernel port: f080
bus-ID: 00:19.0 chip-ID: 8086:1503 class-ID: 0200
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
bus-ID: 2-1.4.4:12 chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
IF: wlp0s29u1u4u4 state: up mac: <filter>
Local Storage: total: 689.32 GiB used: 88.82 GiB (12.9%)
model: WD1600BEKT-75A25T0 size: 149.05 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500DM002-1BD142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: KC45
model: WD800JD-75MSA2 size: 74.51 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1E03
scheme: MBR
ID-1: / raw-size: 149.05 GiB size: 149.05 GiB (100.00%)
used: 84.66 GiB (56.8%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 149.05 GiB size: 149.05 GiB (100.00%)
ID-3: /var/log raw-size: 149.05 GiB size: 149.05 GiB (100.00%)
ID-4: /var/tmp raw-size: 149.05 GiB size: 149.05 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.24 GiB used: 14.5 MiB (0.2%)
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 215 Uptime: 20h 35m wakeups: 0 Memory: 7.24 GiB
used: 2.27 GiB (31.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1732 lib: 522 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
