You're close. nwg-panel complains that it's not Sway and no wlr-randr. The others as you predicted
Sure, see dependencies:
wlr-randr
: for use with other wlroots-based Wayland compositors
nwg-panel 0.2.2 released
nwg-panel 0.2.3 released
@SGS May I have a humble request?
I'm working on the MenuStart plugin to nwg-panel. Initially I planned to use the sway logo on the button, but now I think, that I need some nwg-shell logo. It should fit rectangular and circular buttons, and look well in color and monochrome. Would you have an idea?
Sounds simple
</kidding>
PNG or SVG?
Size 256x256px…?
Color from your avatar? I like it much.
Let me think about.
I have rebuilt it and you should continue to use it as a “brand”. My attempt without nwg doesn’t look so good.
SVG in any dimensions, if you don't mind. I gave up on png support in my code, as it happens to look like crap.
If it comes to colors: I depend on you. Colors are not my strong suit. I usually use what you see in the avatar, plus this orange (#ff8000):
The image should be simple enough, to look well in a button like this:
or even smaller:
Since I just thought of it, I assume that it doesn't exist yet
May be still too complex. Give me a minute to see it in a button...
Glad your paid by the icon.
Drawing icons is PITA. That's why I asked a pro.
24px looks slightly better:
Why are the big white circle?
Maybe we try a svg?
I only managed a few small icons, but they were very very good
It's also not quite clear to me, because I only use azote from you, what the logo is supposed to say. I just made a mixture of what you posted.
From the GTK theme. I may use a custom styling to get rid of the background. In the meantime: 48px in Nordic-bluish-accent:
24px, background: none
Mh, you use the circle on in rectangle, or 24 px is the square? So it is smaler.
I PM the SVG.
24px is the image size.
Button w/ the svg image:
Bigger than alacritty
