Continuing the discussion with @RodneyCK from Multi-Monitor on HP Omen 15 en1xxx (HDMI, DisplayLink not working as 2nd monitor):
I don't have any section for the X Server in the NVIDIA GUI that opens with sudo nvidia-settings.
- If there should be more available, please follow up!
I now can give you screenshots
- System Information
- GPU 0
Output of garuda-inxi see referenced post with much more details.
$>garuda-inxi
Kernel: 6.2.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=9c6fd0f2-7575-4c3e-859b-d832464e5fca rw rootflags=subvol=@
resume=UUID=be277372-da5e-4a26-a604-1cd532d0b7aa loglevel=3
Desktop: GNOME v: 43.3 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: HP product: OMEN Laptop 15-en1xxx v: N/A
Mobo: HP model: 88D2 v: 75.53 serial: <superuser required> UEFI: AMI
v: F.10 date: 07/28/2021
ID-1: BAT0 charge: 68.0 Wh (99.7%) condition: 68.2/68.2 Wh (100.0%)
volts: 12.9 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: not charging cycles: 29
Device-1: hidpp_battery_1 model: Logitech MX Keys Wireless Keyboard
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1325 high: 3200 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1197 2: 3200
3: 1200 4: 1200 5: 1200 6: 1209 7: 1200 8: 1200 9: 1200 10: 1200 11: 1200
12: 1200 13: 1196 14: 1200 15: 1200 16: 1198 bogomips: 102210
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 530.41.03
alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:249d class-ID: 0300
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 code: Vega
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: none
bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 43.0 C
Device-3: Sunplus Innovation ProXtend type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-2.2.4:19 chip-ID: 1bcf:2283
Device-4: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 3-3:3 chip-ID: 0408:5425 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 23.1.0
compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: HDMI-1-0 size-res: N/A modes: N/A
Monitor-2: eDP pos: primary res: 1920x1080 hz: 144 dpi: 142
API: OpenGL v: 4.6 Mesa 23.0.0 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.2.8-zen1-1-zen) direct-render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel bus-ID: 3-2.2.4:19 v: kernel pcie: chip-ID: 1bcf:2283
class-ID: 0102 gen: 1 serial: <filter> speed: 2.5 GT/s lanes: 8 link-max:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
Device-4: Sunplus Innovation ProXtend type: USB
Device-5: DisplayLink Dell Universal Dock D6000 type: USB
driver: cdc_ncm,snd-usb-audio bus-ID: 4-2.1:9 chip-ID: 17e9:6006
Sound API: ALSA v: k6.2.8-zen1-1-zen running: yes
IF-ID-1: enp6s0f3u2u1i5 state: up speed: 1000 Mbps duplex: half
mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:5
chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 476.94 GiB used: 83.97 GiB (17.6%)
model: MZVLB512HBJQ-000H1 size: 476.94 GiB block-size: physical: 512 B
rev: HPS0NEXF temp: 31.9 C scheme: GPT
ID-1: / raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
used: 83.97 GiB (18.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-4: /var/log raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-5: /var/tmp raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.48 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 14.97 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 50.2 C mobo: N/A gpu: amdgpu temp: 46.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Processes: 403 Uptime: 2h 46m wakeups: 10 Memory: 14.97 GiB
used: 7.13 GiB (47.6%) Init: systemd v: 253 default: graphical
pkgs: 1272 libs: 376 tools: pamac,paru Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.25
System install date: 2023-03-26
Last full system update: 2023-03-26 ↻
