I click on Optimus and try to switch to Nvidia i get the error message .Now I'm not sure if Ive even installed my drivers correct;y ,as i have AMD as well .Thoughts please.
╰─λ paleofetch
.%;888:8898898: rob@rob-tufgamingfa506iifx506ii
x;XxXB%89b8:b8%b88: -------------------------------
.8Xxd 8X:. OS: Garuda Linux x86_64
.8Xx; 8x:. Kernel: 5.13.0-173-tkg-bmq
.tt8x .d x88; Uptime: 34 mins
.@8x8; .db: xx@;
,tSXX° .bbbbbbbbbbbbbbbbbbbB8x@; Packages: 1802 (pacman)
.SXxx bBBBBBBBBBBBBBBBBBBBbSBX8; Shell: bash
,888S pd! Resolution: 1920x1080
8X88/ q Terminal: Alacritty
GBB.
x%88 d888@8@X@X@X88X@@XX@@X@8@X. CPU: AMD Ryzen 7 4800H with Radeon Graphics (16) @ 2.9GHz
dxXd dB8b8b8B8B08bB88b998888b88x. Memory: 3197MiB / 15419MiB (20%)
dxx8o .@@;.
dx88 .t@x.
d:SS@8ba89aa67a853Sxxad.
.d988999889889899dd.
╭─rob at rob-tufgamingfa506iifx506ii in ⌁
╰─λ```
Stuffed up forgot how to post a screenshot in private bin omg i feel so stupid i can not for the life of me remember .I have googled help and the Private bin help .I still cant find this basic step.
Thank you for your help PrivateBin
i need the password
or post on here with ~~~ at the begining and ~~~ at the end
.tt8x .d x88; Uptime: 2 hours, 55 mins
.@8x8; .db: xx@;
GBB.
dxXd dB8b8b8B8B08bB88b998888b88x. Memory: 4327MiB / 15419MiB (28%)
dxx8o .@@;.
dx88 .t@x.
╰─λ inxi -Fza
Kernel: 5.13.2-180-tkg-bmq x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=eae5dbb5-1074-40c2-951c-63719da574c4 rw rootflags=subvol=@ quiet splash
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: ASUSTeK product: TUF Gaming FA506II_FX506II v: 1.0
Mobo: ASUSTeK model: FA506II v: 1.0 serial: <filter> UEFI: American Megatrends
v: FA506II.309 date: 07/02/2020
ID-1: BAT1 charge: 36.6 Wh (98.1%) condition: 37.3/48.2 Wh (77.3%) volts: 3.9
min: 11.9 model: ASUS A32-K55 type: Li-ion serial: N/A status: Unknown
Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1 microcode: 8600104
cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 92710
Speed: 1397 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz): 1: 1397
2: 1397 3: 1397 4: 1396 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397
12: 1397 13: 1397 14: 1396 15: 1397 16: 1397
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: ASUSTeK driver: N/A
alternate: nouveau bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0300
Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 05:00.0
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-4:3 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.12 compositor: kwin_x11 driver: loaded: amdgpu
unloaded: modesetting alternate: ati,fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 144 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.2-180-tkg-bmq LLVM 12.0.0)
v: 4.6 Mesa 21.1.4 direct render: Yes
Device-1: AMD vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 05:00.1
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.13.2-180-tkg-bmq running: yes
Sound Server-4: PipeWire v: 0.3.31 running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK
driver: r8169 v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: d000
bus-ID: 03:00.0 chip-ID: 10ec:c822 class-ID: 0280
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-1:2 chip-ID: 13d3:3548 class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 275.2 GiB (57.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AB
lanes: 4 rotation: SSD serial: <filter> rev: ECFK52.3 scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 275.2 GiB (57.7%)
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 560 KiB (0.2%)
fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 275.2 GiB (57.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.06 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 50.1 C mobo: 50.0 C gpu: amdgpu temp: 49.0 C
Processes: 345 Uptime: 2h 55m wakeups: 1 Memory: 15.06 GiB used: 5.88 GiB (39.1%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1
Packages: pacman: 1802 lib: 533 Shell: fish v: 3.3.1 default: Bash v: 5.1.8
running-in: alacritty inxi: 3.3.05
╰─λ```
Thanks for that
Did you install nvidia drivers using system setting / hardware configuration / auto install propriety drivers
I think i did at the first install you mean . Is there a way to check.Thanks for your help
you should see in hardware configuration video optimus enablled and video-nvidia-prime-render-offload enabled.
hmm ok i checked and i none of those are checked nothing of nvidia is checked
in that case auto install propriety drivers
Ok done this dosnt look good Starting
> Using config 'video-optimus-manager' for device: 0000:05:00.0 (0300:1002:1636) Display controller ATI Technologies Inc Renoir
Error: config 'video-optimus-manager' conflicts with config(s): video-chaotic-nvidia-tkg-prime-render-offload
Done ...``` B.R.B mate Tea time
When you tried the live usb did you try it with nvidia drivers the default live usb settings before you installed and was it working.
The reason i am asking it looks like you have fast boot enabled and secure boot enabled in your bios
Sorry i have no idea what i did .i made the use able usb i then installed it and i clicked on install,remove other o.s I then followed the 15 things to do after installing Garuda .so im not sure if i followed all the steps correctly at the time i was very new to linux Distros .What can you suggest please.
Ok i would check in your bios to see fast boot and secure boot are enabled and if they are disable them.
OMG your awesome i think ive been having issues since day one of my first install BRB.Ok i found Fast boot it is disabled ,cant find secure boot I just found this .
On many models, there is no way to directly disable Secure Boot mode. For this reason, we will have to erase the keys that activate it from the BIOS. Don’t worry, you can always reverse this process and enable Secure Boot without any issues. You will also not void the warranty by disabling or enabling Secure Boot.
Yes its ok to do that.
Then double check they are still disabled.
When done just reinstall and you should be good to go
In the boot menu i see Garuda kingston and uefi its on the Garuda kingston as boot first is that right .Like i said i cant see the secure boot option
sorry check bios and set to uefi boot only
Then reinstall garuda
reinstall farout really .from the usb .I will lose all my documents ?its boot option 1 UEFI
