Hello all. Im using Garuda KDE. I have issue with this driver as tittle says. Issues are: Horizon Zero Dawn crash on Linux-tkg-pds kernel and on Linux-xanmod-git its start but after loading save on half it start to use high amount of RAM almost all 16GBs and after some time it crash or freeze my comp and I need to restart it its same on ZEN kernel and now I cant play HZD, on Nvidia driver 465 my RAM usage was nearly half of 16GB. PLS help. THX
And with Mass Effect Legendary Edition when I start the game on launcher only shows this:
Here is my inxi:
System: Kernel: 5.13.4-xanmod1-1-git+ x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod-git root=UUID=7fc014f4-e4fb-4efc-af71-263c81b35d51 rw
systemd.unified_cgroup_hierarchy=1 loglevel=3 nvidia-drm.modeset=1
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux base: Arch Linux
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME A320M-K v: Rev X.0x serial: UEFI: American Megatrends v: 5602
date: 07/14/2020
CPU: Info: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 8 stepping: 2
microcode: 800820D cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 118164
Speed: 2598 MHz min/max: 2200/3700 MHz boost: disabled Core speeds (MHz): 1: 2598 2: 3177 3: 2468 4: 2433 5: 2903
6: 2493 7: 2468 8: 3693 9: 2438 10: 2449 11: 2687 12: 2631 13: 2537 14: 3687 15: 3530 16: 3026
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: Micro-Star MSI driver: nvidia v: 470.57.02
alternate: nvidiafb,nouveau,nvidia_drm bus-ID: 07:00.0 chip-ID: 10de:1b80 class-ID: 0300
Display: x11 server: X.Org 1.20.12 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 42 s-size: 1161x653mm (45.7x25.7") s-diag: 1332mm (52.4")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 69 size: 708x398mm (27.9x15.7") diag: 812mm (32")
OpenGL: renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2 v: 4.6.0 NVIDIA 470.57.02 direct render: Yes
Audio: Device-1: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 07:00.1
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 09:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.13.4-xanmod1-1-git+ running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK PRIME B450M-A driver: r8169
v: kernel port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac:
Drives: Local Storage: total: 4.77 TiB used: 3.07 TiB (64.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Biostar model: S100-240GB size: 223.57 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: rev: V4.9 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-75M2NA0 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: rev: 1A01 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: HDWE140 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: rev: FP1R scheme: GPT
Partition: ID-1: / raw-size: 116.3 GiB size: 116.3 GiB (100.00%) used: 45.59 GiB (39.2%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 576 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4
ID-3: /home raw-size: 465.76 GiB size: 457.38 GiB (98.20%) used: 344.47 GiB (75.3%) fs: ext4 dev: /dev/sdb2
maj-min: 8:18
ID-4: /var/log raw-size: 116.3 GiB size: 116.3 GiB (100.00%) used: 45.59 GiB (39.2%) fs: btrfs dev: /dev/sda5
maj-min: 8:5
ID-5: /var/tmp raw-size: 116.3 GiB size: 116.3 GiB (100.00%) used: 45.59 GiB (39.2%) fs: btrfs dev: /dev/sda5
maj-min: 8:5
Swap: Kernel: swappiness: 133 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: zram size: 15.56 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 37.8 C mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 64%
Info: Processes: 398 Uptime: 18m wakeups: 0 Memory: 15.57 GiB used: 3.61 GiB (23.2%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1511 pacman: 1466 lib: 416 flatpak: 30 snap: 15 Shell: Zsh v: 5.8
running-in: konsole inxi: 3.3.05
