When I run garuda update, the nvidia DKMS modules fail to build
lii@lii-ms7b61
OS: Garuda Linux x86_64
Host: MS-7B61 1.0
Kernel: 6.7.8-zen1-1-zen
Uptime: 21 seconds
Packages: 1836 (pacman)[stable]
Shell: fish 3.7.0
Terminal: konsole 23.8.5
CPU: Intel(R) Core(TM) i5-9600KF (6) @ 4.70 GHz
GPU: NVIDIA GeForce RTX 3060 Lite Hash Rate
Memory: 2.71 GiB / 31.29 GiB (9%)
ββββββββββββββββββββββββ
ββlii@lii in ~
β°βΞ» upd
[sudo] password for lii:
\:: Synchronizing package databases...
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur 2.5 MiB 3.02 MiB/s 00:01 [------------------------------------] 100%
--> Refreshing mirrorlists using rate-mirrors, please be patient..π΅
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
spawn pacman -Su
there is nothing to do
--> A problem with the NVIDIA drivers has been detected
---> Building NVIDIA DKMS module for kernel 6.7.8-arch1-1
Module nvidia 550.54.14 is not installed for kernel 6.7.8-arch1-1 (x86_64). Skipping...
Module nvidia 550.54.14 is not built for kernel 6.7.8-arch1-1 (x86_64). Skipping...
Deleting module nvidia-550.54.14 completely from the DKMS tree.
Sign command: /usr/lib/modules/6.7.8-arch1-1/build/scripts/sign-file
Signing key: /var/lib/dkms/mok.key
Public certificate (MOK): /var/lib/dkms/mok.pub
Creating symlink /var/lib/dkms/nvidia/550.54.14/source -> /usr/src/nvidia-550.54.14
Building module:
Cleaning build area...
'make' -j6 IGNORE_PREEMPT_RT_PRESENCE=1 NV_EXCLUDE_BUILD_MODULES='__EXCLUDE_MODULES' KERNEL_UNAME=6.7.8-arch1-1 modules...(bad exit status: 2)
Error! Bad return status for module build on kernel: 6.7.8-arch1-1 (x86_64)
Consult /var/lib/dkms/nvidia/550.54.14/build/make.log for more information.
---> Failed to build NVIDIA DKMS module for kernel 6.7.8-arch1-1
---> Building NVIDIA DKMS module for kernel 6.7.8-zen1-1-zen
Module nvidia 550.54.14 is not installed for kernel 6.7.8-zen1-1-zen (x86_64). Skipping...
Module nvidia 550.54.14 is not built for kernel 6.7.8-zen1-1-zen (x86_64). Skipping...
Sign command: /usr/lib/modules/6.7.8-zen1-1-zen/build/scripts/sign-file
Building module:
'make' -j6 IGNORE_PREEMPT_RT_PRESENCE=1 NV_EXCLUDE_BUILD_MODULES='__EXCLUDE_MODULES' KERNEL_UNAME=6.7.8-zen1-1-zen modules...(bad exit status: 2)
Error! Bad return status for module build on kernel: 6.7.8-zen1-1-zen (x86_64)
---> Failed to build NVIDIA DKMS module for kernel 6.7.8-zen1-1-zen
System updated! π§
ββlii@lii in ~ as π§ took 53s
β°βΞ»
Make.log
DKMS make.log for nvidia-550.54.14 for kernel 6.7.8-zen1-1-zen (x86_64)
Tue Mar 5 07:49:02 AM CST 2024
make[1]: Entering directory '/usr/lib/modules/6.7.8-zen1-1-zen/build'
SYMLINK /var/lib/dkms/nvidia/550.54.14/build/nvidia/nv-kernel.o
SYMLINK /var/lib/dkms/nvidia/550.54.14/build/nvidia-modeset/nv-modeset-kernel.o
<command-line>: fatal error: /lib/modules/6.7.8-zen1-1-zen/build/include/linux/autoconf.h: No such file or directory
compilation terminated.
CONFTEST: hash__remap_4k_pfn
CONFTEST: set_pages_uc
CONFTEST: list_is_first
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: set_pages_array_uc
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: ioremap_driver_hardened
CONFTEST: ioremap_driver_hardened_wc
CONFTEST: ioremap_cache_shared
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: pde_data
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: dma_attr_macros
CONFTEST: get_dma_ops
CONFTEST: dma_map_page_attrs
CONFTEST: write_cr4
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_get_ibm_chip_id
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_rebar_get_possible_sizes
CONFTEST: wait_for_random_bytes
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: get_backlight_device_by_name
CONFTEST: pci_enable_msix_range
CONFTEST: timer_setup
CONFTEST: kernel_read_has_pointer_pos_arg
CONFTEST: kernel_write_has_pointer_pos_arg
CONFTEST: tegra_get_platform
CONFTEST: dma_direct_map_resource
CONFTEST: tegra_bpmp_send_receive
CONFTEST: flush_cache_all
CONFTEST: vmf_insert_pfn
CONFTEST: jiffies_to_timespec
CONFTEST: ktime_get_raw_ts64
CONFTEST: ktime_get_real_ts64
CONFTEST: full_name_hash
CONFTEST: pci_enable_atomic_ops_to_root
CONFTEST: vga_tryget
CONFTEST: seq_read_iter
CONFTEST: cc_platform_has
CONFTEST: unsafe_follow_pfn
CONFTEST: drm_gem_object_get
CONFTEST: drm_gem_object_put_unlocked
CONFTEST: add_memory_driver_managed
CONFTEST: device_property_read_u64
CONFTEST: devm_of_platform_populate
CONFTEST: of_dma_configure
CONFTEST: of_property_count_elems_of_size
CONFTEST: of_property_read_variable_u8_array
CONFTEST: of_property_read_variable_u32_array
CONFTEST: i2c_new_client_device
CONFTEST: of_get_named_gpio
CONFTEST: i2c_unregister_device
CONFTEST: devm_gpio_request_one
CONFTEST: gpio_direction_input
CONFTEST: gpio_direction_output
CONFTEST: gpio_get_value
CONFTEST: gpio_set_value
CONFTEST: gpio_to_irq
CONFTEST: icc_put
CONFTEST: icc_get
CONFTEST: icc_set_bw
CONFTEST: dma_buf_export_args
CONFTEST: dma_buf_ops_has_kmap
CONFTEST: dma_buf_ops_has_kmap_atomic
CONFTEST: dma_buf_ops_has_map
CONFTEST: dma_buf_ops_has_map_atomic
CONFTEST: dma_buf_has_dynamic_attachment
CONFTEST: dma_buf_attachment_has_peer2peer
CONFTEST: dma_set_mask_and_coherent
CONFTEST: devm_clk_bulk_get_all
CONFTEST: get_task_ioprio
CONFTEST: mdev_set_iommu_device
CONFTEST: offline_and_remove_memory
CONFTEST: crypto_tfm_ctx_aligned
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: radix_tree_empty
CONFTEST: radix_tree_replace_slot
CONFTEST: pnv_npu2_init_context
CONFTEST: cpumask_of_node
CONFTEST: ioasid_get
CONFTEST: mm_pasid_drop
CONFTEST: mmget_not_zero
CONFTEST: mmgrab
CONFTEST: iommu_sva_bind_device_has_drvdata_arg
CONFTEST: vm_fault_to_errno
CONFTEST: find_next_bit_wrap
CONFTEST: iommu_is_dma_domain
CONFTEST: acpi_video_backlight_use_native
CONFTEST: drm_dev_unref
CONFTEST: get_user_pages_remote
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: pin_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_ref_counting
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: drm_connector_funcs_have_mode_in_name
CONFTEST: drm_connector_has_vrr_capable_property
CONFTEST: drm_framebuffer_get
CONFTEST: drm_dev_put
CONFTEST: drm_format_num_planes
CONFTEST: drm_connector_for_each_possible_encoder
CONFTEST: drm_rotation_available
CONFTEST: nvhost_dma_fence_unpack
CONFTEST: drm_vma_offset_exact_lookup_locked
CONFTEST: dma_fence_set_error
CONFTEST: fence_set_error
CONFTEST: sync_file_get_fence
CONFTEST: drm_aperture_remove_conflicting_pci_framebuffers
CONFTEST: drm_fbdev_generic_setup
CONFTEST: drm_connector_attach_hdr_output_metadata_property
CONFTEST: drm_helper_crtc_enable_color_mgmt
CONFTEST: drm_crtc_enable_color_mgmt
CONFTEST: drm_atomic_helper_legacy_gamma_set
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_gpl_sme_active
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: is_export_symbol_present_swiotlb_dma_ops
CONFTEST: is_export_symbol_present___close_fd
CONFTEST: is_export_symbol_present_close_fd
CONFTEST: is_export_symbol_present_get_unused_fd
CONFTEST: is_export_symbol_present_get_unused_fd_flags
CONFTEST: is_export_symbol_present_nvhost_get_default_device
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_byte_offset
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_aperture
CONFTEST: is_export_symbol_present_tegra_dce_register_ipc_client
CONFTEST: is_export_symbol_present_tegra_dce_unregister_ipc_client
CONFTEST: is_export_symbol_present_tegra_dce_client_ipc_send_recv
CONFTEST: is_export_symbol_present_dram_clk_to_mc_clk
CONFTEST: is_export_symbol_present_get_dram_num_channels
CONFTEST: is_export_symbol_present_tegra_dram_types
CONFTEST: is_export_symbol_present_pxm_to_node
CONFTEST: is_export_symbol_present_screen_info
CONFTEST: is_export_symbol_gpl_screen_info
CONFTEST: is_export_symbol_present_i2c_bus_status
CONFTEST: is_export_symbol_present_tegra_fuse_control_read
CONFTEST: is_export_symbol_present_tegra_get_platform
CONFTEST: is_export_symbol_present_pci_find_host_bridge
CONFTEST: is_export_symbol_present_tsec_comms_send_cmd
CONFTEST: is_export_symbol_present_tsec_comms_set_init_cb
CONFTEST: is_export_symbol_present_tsec_comms_clear_init_cb
CONFTEST: is_export_symbol_present_tsec_comms_alloc_mem_from_gscco
CONFTEST: is_export_symbol_present_tsec_comms_free_gscco_mem
CONFTEST: is_export_symbol_present_memory_block_size_bytes
CONFTEST: crypto
CONFTEST: is_export_symbol_present_int_active_memcg
CONFTEST: is_export_symbol_present_migrate_vma_setup
CONFTEST: dma_ops
CONFTEST: swiotlb_dma_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_has_address
CONFTEST: vm_insert_pfn_prot
CONFTEST: vmf_insert_pfn_prot
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: kmem_cache_has_kobj_remove_work
CONFTEST: sysfs_slab_unlink
CONFTEST: proc_ops
CONFTEST: timespec64
CONFTEST: vmalloc_has_pgprot_t_arg
CONFTEST: mm_has_mmap_lock
CONFTEST: pci_channel_state
CONFTEST: pci_dev_has_ats_enabled
CONFTEST: remove_memory_has_nid_arg
CONFTEST: add_memory_driver_managed_has_mhp_flags_arg
CONFTEST: num_registered_fb
CONFTEST: pci_driver_has_driver_managed_dma
CONFTEST: vm_area_struct_has_const_vm_flags
CONFTEST: memory_failure_has_trapno_arg
CONFTEST: mm_context_t
CONFTEST: backing_dev_info
CONFTEST: mmu_notifier_ops_invalidate_range
CONFTEST: mmu_notifier_ops_arch_invalidate_secondary_tlbs
CONFTEST: migrate_vma_added_flags
CONFTEST: migrate_device_range
CONFTEST: handle_mm_fault_has_mm_arg
CONFTEST: handle_mm_fault_has_pt_regs_arg
CONFTEST: mempolicy_has_unified_nodes
CONFTEST: mempolicy_has_home_node
CONFTEST: mpol_preferred_many_present
CONFTEST: mmu_interval_notifier
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_device_list
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_init_function_args
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_atomic_helper_plane_destroy_state_has_plane_arg
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dma_buf_owner
CONFTEST: drm_connector_list_iter
CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
CONFTEST: drm_driver_prime_flag_present
CONFTEST: drm_gem_object_has_resv
CONFTEST: drm_crtc_state_has_async_flip
CONFTEST: drm_crtc_state_has_pageflip_flags
CONFTEST: drm_crtc_state_has_vrr_enabled
CONFTEST: drm_format_modifiers_present
CONFTEST: drm_vma_node_is_allowed_has_tag_arg
CONFTEST: drm_vma_offset_node_has_readonly
CONFTEST: drm_display_mode_has_vrefresh
CONFTEST: drm_driver_master_set_has_int_return_type
CONFTEST: drm_driver_has_gem_free_object
CONFTEST: drm_prime_pages_to_sg_has_drm_device_arg
CONFTEST: drm_driver_has_gem_prime_callbacks
CONFTEST: drm_crtc_atomic_check_has_atomic_state_arg
CONFTEST: drm_gem_object_vmap_has_map_arg
CONFTEST: drm_plane_atomic_check_has_atomic_state_arg
CONFTEST: drm_device_has_pdev
CONFTEST: drm_crtc_state_has_no_vblank
CONFTEST: drm_mode_config_has_allow_fb_modifiers
CONFTEST: drm_has_hdr_output_metadata
CONFTEST: dma_resv_add_fence
CONFTEST: dma_resv_reserve_fences
CONFTEST: reservation_object_reserve_shared_has_num_fences_arg
CONFTEST: drm_connector_has_override_edid
CONFTEST: drm_master_has_leases
CONFTEST: drm_file_get_master
CONFTEST: drm_modeset_lock_all_end
CONFTEST: drm_connector_lookup
CONFTEST: drm_connector_put
CONFTEST: drm_driver_has_dumb_destroy
CONFTEST: fence_ops_use_64bit_seqno
CONFTEST: drm_aperture_remove_conflicting_pci_framebuffers_has_driver_arg
CONFTEST: drm_mode_create_dp_colorspace_property_has_supported_colorspaces_arg
CONFTEST: drm_unlocked_ioctl_flag_present
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: nvidia_grid_csp_build
CONFTEST: pm_runtime_available
CONFTEST: pci_class_multimedia_hd_audio
CONFTEST: drm_available
CONFTEST: vfio_pci_core_available
CONFTEST: mdev_available
CONFTEST: cmd_uphy_display_port_init
CONFTEST: cmd_uphy_display_port_off
CONFTEST: memory_failure_mf_sw_simulated_defined
CONFTEST: drm_atomic_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CONFTEST: drm_alpha_blending_available
CONFTEST: is_export_symbol_present_drm_gem_prime_fd_to_handle
CONFTEST: is_export_symbol_present_drm_gem_prime_handle_to_fd
CONFTEST: ib_peer_memory_symbols
CC [M] /var/lib/dkms/nvidia/550.54.14/build/nvidia/nv.o
CC [M] /var/lib/dkms/nvidia/550.54.14/build/nvidia/nv-pci.o
CC [M] /var/lib/dkms/nvidia/550.54.14/build/nvidia/nv-dmabuf.o
CC [M] /var/lib/dkms/nvidia/550.54.14/build/nvidia/nv-nano-timer.o
In file included from <command-line>:
././include/linux/kconfig.h:5:10: fatal error: generated/autoconf.h: No such file or directory
5 | #include <generated/autoconf.h>
make[3]: *** [scripts/Makefile.build:243: /var/lib/dkms/nvidia/550.54.14/build/nvidia/nv.o] Error 1
make[3]: *** Waiting for unfinished jobs....
make[3]: *** [scripts/Makefile.build:243: /var/lib/dkms/nvidia/550.54.14/build/nvidia/nv-pci.o] Error 1
CC [M] /var/lib/dkms/nvidia/550.54.14/build/nvidia/nv-acpi.o
make[3]: *** [scripts/Makefile.build:243: /var/lib/dkms/nvidia/550.54.14/build/nvidia/nv-dmabuf.o] Error 1
make[3]: *** [scripts/Makefile.build:243: /var/lib/dkms/nvidia/550.54.14/build/nvidia/nv-nano-timer.o] Error 1
make[3]: *** [scripts/Makefile.build:243: /var/lib/dkms/nvidia/550.54.14/build/nvidia/nv-acpi.o] Error 1
make[2]: *** [/usr/lib/modules/6.7.8-zen1-1-zen/build/Makefile:1909: /var/lib/dkms/nvidia/550.54.14/build] Error 2
make[1]: *** [Makefile:234: __sub-make] Error 2
make[1]: Leaving directory '/usr/lib/modules/6.7.8-zen1-1-zen/build'
make: *** [Makefile:85: modules] Error 2
Garuda-inxi
lii@lii-ms7b61
Host: MS-7B61 1.0
Uptime: 11 mins
Shell: fish 3.7.0
Memory: 4.59 GiB / 31.29 GiB (15%)
ββlii@lii in ~
β°βΞ» garuda-inxi
Kernel: 6.7.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=82f4f668-10d7-4b04-9701-198a8ae3e43b rw rootflags=subvol=@
resume=UUID=f4a34052-d3e1-450e-9f98-2fe3749629df loglevel=3 ibt=off
Type: Desktop Mobo: Micro-Star model: Z370 GAMING PLUS (MS-7B61) v: 1.0
UEFI: American Megatrends v: 1.A0 date: 06/08/2020
Info: model: Intel Core i5-9600KF bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xFA
desc: 1x9 MiB
Speed (MHz): avg: 800 min/max: 800/4700 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
bogomips: 44398
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: Gigabyte
driver: nvidia v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
off: DP-1,DP-2,HDMI-A-1 empty: HDMI-A-2 bus-ID: 01:00.0 chip-ID: 10de:2504
Device-2: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9.3:9
chip-ID: 1532:0e03 class-ID: 0102
Screen-1: 0 s-res: 3840x1080 s-dpi: 93 s-size: 1049x292mm (41.30x11.50")
s-diag: 1089mm (42.87")
Monitor-1: DP-2 pos: primary,right res: 1920x1080 dpi: 93
Monitor-2: HDMI-0 pos: left res: 1920x1080 hz: 60 dpi: 96
size: 510x287mm (20.08x11.3") diag: 585mm (23.04") modes: N/A
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.54.14
memory: 11.72 GiB
API: Vulkan v: 1.3.276 layers: 8 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 550.54.14
device-ID: 10de:2504 surfaces: xcb,xlib
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
Device-2: NVIDIA GA106 High Definition Audio vendor: Gigabyte
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
Device-3: Razer USA Nari Ultimate driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3
chip-ID: 1532:051a class-ID: 0300
Device-4: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.7.8-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Device-1: Realtek driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 0bda:a729 class-ID: e001
Local Storage: total: 7.28 TiB used: 2.86 TiB (39.3%)
fw-rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST6000VN0033-2EE110
size: 5.46 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SC60 scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 1.69 TiB (94.5%)
used: 1.69 TiB (94.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.29 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6 dev: /dev/zram0
ID-2: swap-2 type: partition size: 34.42 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 30.0 C mobo: N/A gpu: nvidia temp: 46 C
Memory: total: 32 GiB available: 31.29 GiB used: 4.71 GiB (15.1%)
Processes: 293 Power: uptime: 11m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.45 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1836 libs: 556 tools: gnome-software, octopi,
pamac, paru Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: garuda-inxi
default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-01-26
Last full system update: 2024-03-05
ββlii@lii in ~ took 2s
β°βΞ»
