I know there’s already plenty of other topics for this, like Nvidia-dkms fails to build, but I tried everything I could find without sucess.
I used snapshots, I tried the reinstall all packages from Garuda Settings, I had paru reinstall the dkms (this worked, but after that, trying the garuda-update still fails).
From the tail of garuda-update:
(7/7) Syncing all file systems...
--> A problem with the NVIDIA drivers has been detected
---> Building NVIDIA DKMS module for kernel 6.8.1-arch1-1
Module nvidia 550.67 is not installed for kernel 6.8.1-arch1-1 (x86_64). Skipping...
Module nvidia 550.67 is not built for kernel 6.8.1-arch1-1 (x86_64). Skipping...
Error! Your kernel headers for kernel 6.8.1-arch1-1 cannot be found at /usr/lib/modules/6.8.1-arch1-1/build or/usr/lib/modules/6.8.1-arch1-1/source.
Please install the linux-headers-6.8.1-arch1-1 package or use the --kernelsourcedir option to tell DKMS where it's located.
---> Failed to build NVIDIA DKMS module for kernel 6.8.1-arch1-1
System updated! 🐧
and, of course, the inxi (yeah, it says I need to reset, I know)
╰─λ garuda-inxi
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=5309dd87-249f-4b46-97cc-d3e9694e11ac rw rootflags=subvol=@
quiet resume=UUID=2bc0ab3f-115d-4d02-8834-b9c9e5ffcd56 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Laptop System: Dell product: G5 5590 v: N/A
Mobo: Dell model: 0CNDTP v: A04 serial: <superuser required> part-nu: 08EA
uuid: <superuser required> UEFI: Dell v: 1.13.2 date: 05/22/2020
ID-1: BAT0 charge: 43.6 Wh (100.0%) condition: 43.6/60.0 Wh (72.6%)
volts: 16.7 min: 15.2 model: SMP DELL JJPFK87 type: Li-poly serial: <filter>
status: full
Device-1: nintendo_switch_controller_battery_0005:057E:2009.0011
model: N/A serial: N/A charge: Full status: discharging
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3314 high: 4298 min/max: 800/4500 scaling:
driver: intel_pstate governor: performance cores: 1: 4286 2: 4062 3: 4281
4: 4298 5: 800 6: 4250 7: 4228 8: 3455 9: 4264 10: 800 11: 4246 12: 800
bogomips: 62399
ports: active: none off: eDP-1 empty: DP-2, DP-3, HDMI-A-2, HDMI-A-3
bus-ID: 0000:00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Dell
driver: nvidia v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 ports: active: none
off: DP-1,HDMI-A-1 empty: none bus-ID: 0000:01:00.0 chip-ID: 10de:1f11
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0c45:671f
class-ID: 0e02
alternate: fbdev,intel,nv,vesa dri: iris gpu: i915,nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 2560x2160 s-dpi: 96 s-size: 675x570mm (26.57x22.44")
s-diag: 883mm (34.78")
Monitor-1: DP-1 mapped: DP-1-0 note: disabled pos: primary,top
model: LG (GoldStar) HDR WFHD serial: <filter> built: 2018 res: 2560x1080
hz: 60 dpi: 81 gamma: 1.2 size: 798x334mm (31.42x13.15")
diag: 869mm (34.2") modes: max: 2560x1080 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-1-0 note: disabled pos: bottom
model: LG (GoldStar) ULTRAWIDE serial: <filter> built: 2013 res: 2560x1080
hz: 60 dpi: 96 gamma: 1.2 size: 677x290mm (26.65x11.42")
diag: 628mm (24.7") modes: max: 2560x1080 min: 640x480
Monitor-3: eDP-1 note: disabled model: BOE Display 0x084a built: 2018
res: 2560x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: EGL v: 1.5 hw: drv: intel iris platforms: device: 1 drv: iris
device: 2 drv: swrast surfaceless: drv: swrast x11: drv: iris
inactive: gbm,wayland,device-0
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.3-arch1.2
GT2) device-ID: 8086:3e9b memory: 15.07 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: integrated-gpu name: Intel
UHD Graphics 630 (CFL GT2) driver: mesa intel v: 24.0.3-arch1.2
device-ID: 8086:3e9b surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.3-arch1.2 (LLVM
v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 0000:00:1f.3
Device-2: NVIDIA TU106 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:10f9
Device-3: Generalplus USB Audio Device
lanes: 1 mode: 1.1 bus-ID: 1-4.3:14 chip-ID: 1b3f:2008 class-ID: 0300
Device-4: Realtek USB Audio driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.5:11 chip-ID: 0bda:4014
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
Device-1: Realtek vendor: Dell driver: r8169 v: kernel port: 3000
bus-ID: 0000:3b:00.0 chip-ID: 10ec:2502 class-ID: 0200
IF: enp59s0 state: down mac: <filter>
vendor: Dell driver: ath10k_pci v: kernel bus-ID: 0000:3c:00.0
chip-ID: 168c:003e class-ID: 0280
IF: wlp60s0 state: down mac: <filter>
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-1.2:3
IF-ID-1: br-3c64cafc6861 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: veth95e46cd state: up speed: 10000 Mbps duplex: full
mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8 chip-ID: 0cf3:e007
driver: intel_nvme_remap v: N/A port: 5060 bus-ID: 0000:00:17.0
chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.14 TiB used: 619.08 GiB (52.9%)
model: PC SN520 NVMe WDC 256GB size: 238.47 GiB block-size: physical: 512 B
logical: 512 B tech: SSD serial: <filter> fw-rev: 20240012 temp: 44.9 C
model: WD10SPZX-75Z10T3 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 4514 scheme: GPT
ID-1: / raw-size: 39.74 GiB size: 39.74 GiB (100.00%)
used: 36.23 GiB (91.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 600 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 181.46 GiB size: 181.46 GiB (100.00%)
used: 106.81 GiB (58.9%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 39.74 GiB size: 39.74 GiB (100.00%)
ID-5: /var/tmp raw-size: 39.74 GiB size: 39.74 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.43 GiB used: 2.93 GiB (19.0%)
ID-2: swap-2 type: partition size: 16.98 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 70.0 C pch: 70.0 C mobo: N/A
Memory: total: 16 GiB available: 15.43 GiB used: 4.92 GiB (31.9%)
Processes: 355 Power: uptime: 4h 38m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.13 GiB services: org_kde_powerdevil,
Packages: 1763 pm: pacman pkgs: 1755 libs: 489 tools: octopi,paru
pm: flatpak pkgs: 8 Compilers: gcc: 13.2.1 Shell: garuda-inxi default: fish
v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-03-11
Last full system update: 2024-03-23 ↻
– edit1
going thru other threads again, namely this one Nvidia DKMS failed to build - #2 by edu4rdshl reminded me that I had tried paru linux-headers-6.8.1-arch1-1 before and ended up empty handed, but I did not try paru linux-headers… doing it now.
But shouldn’t this already be installed? I mean, as you can see from the inxi, I just did a fresh install 12 days ago… and everything was working nicely (except for those wayland stuff, I’m back on X11)
