NVIDIA dkms driver problem
Hello, latest nvidia -dkms driver fail to install giving me a black screen after boot.
sudo garuda-inxi
Kernel: 5.17.0-rc5-1-mainline x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-mainline
root=UUID=995b984e-0171-4ed2-adff-0bc76cdf57e5 rw [email protected]
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1
mitigations=off intel_iommu=on iommu=pt acpi_enforce_resources=lax
snd_hda_intel.dmic_detect=0 snd-intel-dspcfg.dsp_driver=1 ignore_loglevel
Mobo: ASUSTeK model: ROG MAXIMUS XII FORMULA v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 2301 date: 07/13/2021
ID-1: hidpp_battery_0 charge: 83% condition: N/A volts: 4.0 min: N/A
serial: <filter> status: Charging
Info: model: Intel Core i9-10900K socket: LGA1200 bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: 0xA5 (165) stepping: 5 microcode: 0xEE
Topology: cpus: 1x cores: 10 tpc: 2 threads: 20 smt: enabled cache:
L1: 640 KiB desc: d-10x32 KiB; i-10x32 KiB L2: 2.5 MiB desc: 10x256 KiB
L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 5219 high: 5315 min/max: 800/5300 base/boost: 3700/8300
scaling: driver: intel_pstate governor: performance volts: 0.9 V
ext-clock: 100 MHz cores: 1: 5103 2: 5180 3: 5312 4: 5315 5: 5289 6: 5315
7: 5078 8: 5302 9: 5315 10: 5295 11: 5112 12: 5298 13: 5168 14: 5042
15: 5300 16: 4983 17: 5307 18: 5301 19: 5071 20: 5299 bogomips: 148040
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Gigabyte driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1b81 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-2.2:10 chip-ID: 046d:082d
Display: server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 7280x1440 s-dpi: 109 s-size: 1696x333mm (66.8x13.1")
s-diag: 1728mm (68")
Monitor-1: DP-0 pos: bottom-r res: 1920x1080 dpi: 92
size: 531x298mm (20.9x11.7") diag: 609mm (24")
Monitor-2: DP-2 pos: bottom-l res: 1920x1080 dpi: 92
size: 531x299mm (20.9x11.8") diag: 609mm (24")
Monitor-3: DP-4 pos: primary,top-center res: 3440x1440 dpi: 109
size: 800x330mm (31.5x13.0") diag: 865mm (34.1")
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-2: NVIDIA GP104 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: Logitech HD Pro Webcam C920 type: USB
Device-4: RODE Microphones NT-USB type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2 chip-ID: 19f7:0003
Sound Server-1: ALSA v: k5.17.0-rc5-1-mainline running: yes
Sound Server-3: PipeWire v: 0.3.47 running: yes
Device-2: Aquantia AQC107 NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 2 link-max: lanes: 4 port: N/A bus-ID: 04:00.0 chip-ID: 1d6a:07b1
Device-3: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0
bus-ID: 1-14:12 chip-ID: 8087:0026 class-ID: e001
Hardware-1: Intel Comet Lake PCH-H RAID driver: ahci v: 3.0 port: 4020
bus-ID: 00:17.0 chip-ID: 8086:06d6 rev: class-ID: 0104
Local Storage: total: 1.61 TiB used: 84.35 GiB (5.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: N/A
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: RKT343.4
temp: 28.9 C scheme: GPT
SMART: yes health: PASSED on: 6d 1h cycles: 82
read-units: 753,839 [385 GB] written-units: 988,214 [505 GB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
family: based SSDs size: 232.89 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 2B6Q temp: 24 C
SMART: yes state: enabled health: PASSED on: 1y 285d 11h cycles: 2827
written: 32.81 TiB
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
rev: 2B6Q temp: 25 C
SMART: yes state: enabled health: PASSED on: 1y 332d 21h cycles: 3102
written: 40.9 TiB
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
rev: 1B6Q temp: 25 C
SMART: yes state: enabled health: PASSED on: 3y 122d 4h cycles: 2691
written: 40.93 TiB
used: 84.35 GiB (8.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 31.16 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 31.0 C mobo: 33.0 C gpu: nvidia temp: 36 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1498 fan-3: 0 fan-4: 0 fan-5: 0
fan-6: 915 fan-7: 0 gpu: nvidia fan: 0%
Processes: 492 Uptime: 8m wakeups: 17 Memory: 31.16 GiB
used: 3.95 GiB (12.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: note: see --pkg pacman: 1744 lib: 478
inxi: 3.3.13
Garuda (2.5.5-1):
System install date:     2022-02-13
Last full system update: 2022-03-02
Failed units:            systemd-guest-user.service
sudo mkinitcpio --allpresets
==> Building image from preset: /etc/mkinitcpio.d/linux-lts.preset: 'default'
-> -k /boot/vmlinuz-linux-lts -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-lts.img
==> Starting build: 5.15.25-2-lts
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: [consolefont]
-> Running build hook: [plymouth]
-> Running build hook: [filesystems]
-> Running build hook: [grub-btrfs-overlayfs]
==> Generating module dependencies
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-lts.img
==> Image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux-lts.preset: 'fallback'
-> -k /boot/vmlinuz-linux-lts -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-lts-fallback.img -S autodetec
t
==> WARNING: Possibly missing firmware for module: aic94xx
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: wd719x
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-lts-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux-mainline.preset: 'default'
-> -k /boot/vmlinuz-linux-mainline -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-mainline.img
==> Starting build: 5.17.0-rc6-1-mainline
==> ERROR: module not found: `nvidia'
==> ERROR: module not found: `nvidia_modeset'
==> ERROR: module not found: `nvidia_uvm'
==> ERROR: module not found: `nvidia_drm'
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-mainline.img
==> WARNING: errors were encountered during the build. The image may not be complete.
==> Building image from preset: /etc/mkinitcpio.d/linux-mainline.preset: 'fallback'
-> -k /boot/vmlinuz-linux-mainline -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-mainline-fallback.img -S
autodetect
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-mainline-fallback.img
Have you tried the zen kernel or lts
Looks like the module build failed for the 5.17rc6 kernel so the modules can't be included in the initramfs.
Look at the output of e.g. dkms autoinstall and it might tell you which log file has information about the build failure.
I've run both 510 and 470 DKMS modules with 5.17rc6 so it does work.
Everything works on my laptop!
For some reason, it doesn't work on my desktop now on any kernels!
If you could look at the log files there might be some information about why.
If the module isn't building then there's probably something missing from the desktop.
File: /var/lib/dkms/nvidia/510.47.03/source/dkms.conf does not exist.
OK, so that means you didn't install the package, or it was corrupted, or you deleted files.
Reinstall nvidia-dkms and try again.
Also, if you could provide the full command and output it will be useful for context.
I am copying by hand from the tty to my mobile :sweat_smile:
SSH into the desktop from the laptop, then you can easily run commands and copy-paste output etc.
Oh, thank you, I hadn't thought of that.
Sorry it took a while, but I had to fix other errors I caused earlier trying to fix this.
paru -S garuda-nvidia-config nvidia-dkms
risoluzione delle dipendenze in corso...
ricerca dei pacchetti in conflitto in corso...
Pacchetti (2) garuda-nvidia-config-1:r62.889aefa-2  nvidia-dkms-510.54-1
Dimensione totale dei pacchetti da installare:  50,65 MiB
:: Vuoi procedere con l'installazione? [S/n] S
(2/2) verifica delle chiavi presenti nel portachiavi               [------------------------------------] 100%
(2/2) verifica dell'integrità dei pacchetti                        [------------------------------------] 100%
(2/2) caricamento dei file dei pacchetti                           [------------------------------------] 100%
(2/2) controllo dei conflitti in corso                             [------------------------------------] 100%
(2/2) controllo dello spazio disponibile sul disco                 [------------------------------------] 100%
:: Esecuzione degli hook di pre-transazione...
==> root: 209
:: Elaborazione delle modifiche al pacchetto...
(1/2) installazione in corso di nvidia-dkms                        [------------------------------------] 100%
(2/2) installazione in corso di garuda-nvidia-config               [------------------------------------] 100%
ldconfig: Il file /usr/lib/libnvidia-gtk3.so.510.54 è vuoto, non controllato.
ldconfig: Il file /usr/lib/libOkular5Core.so è vuoto, non controllato.
ldconfig: Il file /usr/lib/libOkular5Core.so.9 è vuoto, non controllato.
ldconfig: Il file /usr/lib/libOkular5Core.so.9.0.0 è vuoto, non controllato.
ldconfig: Il file /usr/lib/libkcupslib.so è vuoto, non controllato.
:: Esecuzione degli hook di post-transazione...
(1/8) Arming ConditionNeedsUpdate...
(2/8) Install DKMS modules
==> dkms install --no-depmod nvidia/510.54 -k 5.16.12-arch1-1
readelf: errore: /usr/lib/modules/5.16.12-arch1-1/build/vmlinux: impossibile leggere il numero magic del file
Error! Bad return status for module build on kernel: 5.16.12-arch1-1 (x86_64)
Consult /var/lib/dkms/nvidia/510.54/build/make.log for more information.
==> WARNING: `dkms install --no-depmod nvidia/510.54 -k 5.16.12-arch1-1' exited 10
==> dkms install --no-depmod nvidia/510.54 -k 5.17.0-rc6-1-mainline
Error! Bad return status for module build on kernel: 5.17.0-rc6-1-mainline (x86_64)
==> WARNING: `dkms install --no-depmod nvidia/510.54 -k 5.17.0-rc6-1-mainline' exited 10
(3/8) Updating linux initcpios...
autodetect
errore: l'esecuzione del comando non è riuscita correttamente
(4/8) Foreign/AUR package notification
conky-lua-nv 1.12.2-1
kde-service-menu-reimage 2.5-1
mongodb-bin 5.0.6-1
mqtt-explorer-appimage 0.3.5-2
parsec-bin 150_28-3
runjs-bin 2.3.0-1
(5/8) Orphaned package notification...
android-tools 31.0.3-3
check 0.15.2-2
cmake 3.22.2-1
discount 2.2.7-1
electron 17.1.0-1
electron14 14.2.6-1
flutter 2.10.2-1
fontforge 20201107-3
kimageannotator 0.5.3-2
kpmcore 21.12.3-1
libcroco 0.6.13-2
libmms 0.6.4-3
libofa 0.9.3-9
libosinfo 1.9.0-2
libsolv 0.7.20-1
libspectre 0.2.10-1
libvirt-python 1:8.1.0-1
lld 13.0.1-1
mailcap 2.1.53-1
meson 0.61.2-1
mingw-w64-gcc 11.2.0-1
mingw-w64-tools 9.0.0-1
nasm 2.15.05-1
python-cairosvg 2.5.2-3
python-click 8.0.4-1
python-nose 1.3.7-14
python-psutil 5.9.0-1
python-pynput 1.7.6-1
python-qtpy 1.11.2-3
python-sphinx 4.4.0-1
python-virtualenv 20.11.0-1
(6/8) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/locale.gen.pacnew
Please check and merge
(7/8) Performing snapper post snapshots for the following configurations...
==> root: 210
(8/8) Syncing all file systems...
Reinstalling doesn't seem to work.
You have other issues.
These imply filesystem corruption.
As far as the NVIDIA driver goes,
Look in this file to see why the module did not build.
CC [M]  /var/lib/dkms/nvidia/510.54/build/nvidia/nv.o
CC [M]  /var/lib/dkms/nvidia/510.54/build/nvidia/nv-pci.o
CC [M]  /var/lib/dkms/nvidia/510.54/build/nvidia/nv-acpi.o
CC [M]  /var/lib/dkms/nvidia/510.54/build/nvidia/nv-cray.o
cc1: error: incompatible gcc/plugin versions
cc1: error: failed to initialize plugin ./scripts/gcc-plugins/structleak_plugin.so
CC [M]  /var/lib/dkms/nvidia/510.54/build/nvidia/nv-dma.o
CC [M]  /var/lib/dkms/nvidia/510.54/build/nvidia/nv-i2c.o
CC [M]  /var/lib/dkms/nvidia/510.54/build/nvidia/nv-mmap.o
CC [M]  /var/lib/dkms/nvidia/510.54/build/nvidia/nv-p2p.o
make[2]: *** [scripts/Makefile.build:288: /var/lib/dkms/nvidia/510.54/build/nvidia/nv-pci.o] Errore 1
make[2]: *** Attesa per i processi non terminati....
make[2]: *** [scripts/Makefile.build:288: /var/lib/dkms/nvidia/510.54/build/nvidia/nv.o] Errore 1
make[2]: *** [scripts/Makefile.build:288: /var/lib/dkms/nvidia/510.54/build/nvidia/nv-acpi.o] Errore 1
make[2]: *** [scripts/Makefile.build:288: /var/lib/dkms/nvidia/510.54/build/nvidia/nv-cray.o] Errore 1
make[2]: *** [scripts/Makefile.build:288: /var/lib/dkms/nvidia/510.54/build/nvidia/nv-dma.o] Errore 1
make[2]: *** [scripts/Makefile.build:288: /var/lib/dkms/nvidia/510.54/build/nvidia/nv-i2c.o] Errore 1
CC [M]  /var/lib/dkms/nvidia/510.54/build/nvidia/nv-pat.o
make[2]: *** [scripts/Makefile.build:288: /var/lib/dkms/nvidia/510.54/build/nvidia/nv-mmap.o] Errore 1
make[2]: *** [scripts/Makefile.build:288: /var/lib/dkms/nvidia/510.54/build/nvidia/nv-p2p.o] Errore 1
make[2]: *** [scripts/Makefile.build:288: /var/lib/dkms/nvidia/510.54/build/nvidia/nv-pat.o] Errore 1
make[1]: *** [Makefile:1831: /var/lib/dkms/nvidia/510.54/build] Errore 2
make[1]: uscita dalla directory «/usr/lib/modules/5.17.0-rc6-1-mainline/build»
make: *** [Makefile:82: modules] Errore 2
It seems that there are some problems with GCC plugins.
How can I reinstall all packages to try to fix that? I can't use garuda-assistant because Xorg doesn't work
This means you're in a partial upgrade state, where the kernel was built with a different version of GCC than you have installed. You need to rebuild/update linux-mainline.
Something like
sudo pacman -S $(pacman -Qqn)
I also know how it happened. When I compile the new NVidia driver, even if it does not give GCC errors, the system crashes as soon as the modprobe is run.
Hello.
The installation of the Nvidia drivers fails as it did before reinstalling (NVIDIA dkms driver problem).
I noticed that it doesn't boot live with Nvidia drivers going into kernel panic.
If I install without the Nvidia drivers and try to install them after installing, the dkms module fails.
sudo garuda-inxi
Kernel: 5.16.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/.snapshots/1/snapshot/boot/vmlinuz-linux-zen
root=UUID=55cd6875-ac91-482d-a72a-a27f6069f281 quiet quiet splash
rootflags=defaults,noatime,autodefrag,compress=zstd,discard=async,ssd,[email protected]/.snapshots/1/snapshot
Console: pty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
ID-1: hidpp_battery_0 charge: 82% condition: N/A volts: 4.0 min: N/A
Speed (MHz): avg: 4395 high: 5006 min/max: 800/5300 base/boost: 3700/8300
scaling: driver: intel_pstate governor: powersave volts: 0.9 V
ext-clock: 100 MHz cores: 1: 1158 2: 4344 3: 4900 4: 4900 5: 4902 6: 5006
7: 5005 8: 4959 9: 1813 10: 4904 11: 4900 12: 4900 13: 3623 14: 4411
15: 4901 16: 3675 17: 4900 18: 4903 19: 4899 20: 4901 bogomips: 147994
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Gigabyte driver: nouveau
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: DP-1,DP-2,DP-3 empty: DVI-D-1,HDMI-A-1
loaded: nouveau unloaded: modesetting alternate: fbdev,nv,vesa gpu: nouveau
Screen-1: 0 s-res: 7280x1440 s-dpi: 96 s-size: 1926x381mm (75.8x15.0")
s-diag: 1963mm (77.3")
Monitor-1: DP-1 pos: primary,left model: Mi Monitor built: 2019
res: 3440x1440 hz: 50 dpi: 110 gamma: 1.2 size: 797x334mm (31.4x13.1")
diag: 864mm (34") modes: max: 3440x1440 min: 720x400
Monitor-2: DP-2 pos: center model: AOC 2460G5 serial: <filter>
built: 2017 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 531x299mm (20.9x11.8") diag: 609mm (24") ratio: 16:9 modes:
Monitor-3: DP-3 pos: right model: LG (GoldStar) 24GL600F serial: <filter>
built: 2020 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 531x298mm (20.9x11.7") diag: 609mm (24") ratio: 16:9 modes:
OpenGL: renderer: NV134 v: 4.3 Mesa 21.3.7 direct render: Yes
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f0
Sound Server-1: ALSA v: k5.16.12-zen1-1-zen running: yes
Local Storage: total: 1.61 TiB used: 18.3 GiB (1.1%)
SMART: yes health: PASSED on: 8d 18h cycles: 159
read-units: 1,109,220 [567 GB] written-units: 1,810,521 [926 GB]
SMART: yes state: enabled health: PASSED on: 1y 288d 13h cycles: 2904
written: 32.81 TiB
SMART: yes state: enabled health: PASSED on: 1y 335d 23h cycles: 3179
written: 40.9 TiB
SMART: yes state: enabled health: PASSED on: 3y 125d 7h cycles: 2768
written: 40.93 TiB
ID-1: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
maj-min: 259:1
ID-2: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
used: 18.3 GiB (1.9%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-3: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
maj-min: 259:2
ID-4: /var/tmp raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
maj-min: 259:2
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nouveau temp: 36.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 0
Processes: 423 Uptime: 1m wakeups: 2 Memory: 31.16 GiB
used: 1.93 GiB (6.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1136 lib: 292 Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.5-1):
System install date:     2022-03-12
Last full system update: 2022-03-12
I have already tried with: linux-zen, linux, linux-lts, linux-mainline
Check you have fast boot and secure disabled
Just turned off, same problem.
check you are not booted into a snapshot as your garuda-inxi shows
