Hello guys,
I'm using Garuda KDE Dr460nized. I have issue to connect any Android device (tried 3 different phones and tablet too) to it. The OS and the android devices also not recognize each other: adb devices doesn't list anything. I update my system every day so it can't be the issue. I'm not sure what is the problem might be any systemctl not enabled. Any advice please?
Thanks
Borshow
Is the problem limited to adb ?
If I connect any android devices no any sign of the connection. Not on the android side (it shows charging) and not on garuda side
Local Storage: total: 7.74 TiB used: 2.31 TiB (29.8%)
model: MZVLB512HAJQ-00000 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial:
rev: EXA7301Q temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Seagate model: ST32000542AS
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: HDD
rpm: 5900 serial: scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: HGST (Hitachi)
model: HUS726060ALE610 size: 5.46 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 7200 serial: scheme: GPT
used: 155.82 GiB (32.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
Please, full version from
, input and output in nice formatted style.
Read the guide .
λ garuda-inxi
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=b19aead1-2bd7-4886-bbe8-ccfa848c12d4 rw rootflags=subvol=@
Type: Laptop System: HUAWEI product: MACH-WX9 v: M1D
Mobo: HUAWEI model: MACH-WX9-PCB v: M1D serial: <superuser required>
UEFI: HUAWEI v: 1.37 date: 05/12/2021
ID-1: BAT0 charge: 50.4 Wh (100.0%) condition: 50.4/56.3 Wh (89.5%)
volts: 8.0 min: 7.6 model: DYNAPACK HB4593R1ECW-22T0 type: Li-ion
serial: <filter> status: full cycles: 185
Device-1: hid-20:20:05:1d:40:9d-battery model: Bluetooth 5.1 Keyboard
serial: N/A charge: N/A status: discharging
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 400/4000 scaling: driver: intel_pstate
8: 800 bogomips: 31999
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Huawei driver: i915 v: kernel
ports: active: DP-2 off: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Huawei driver: nvidia
v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s
lanes: 4 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1d12 class-ID: 0302
Device-3: Cheng Uei Precision Industry (Foxlink) HD Camera type: USB
driver: uvcvideo bus-ID: 1-7:8 chip-ID: 05c8:03c0 class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1015x571mm (39.96x22.48")
s-diag: 1165mm (45.85")
Monitor-1: DP-2 pos: primary model: Panasonic Panasonic-TV
serial: <filter> built: 2018 res: 3840x2160 hz: 60 dpi: 140 gamma: 1.2
size: 698x392mm (27.48x15.43") diag: 1469mm (57.8") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
Monitor-2: eDP-1 note: disabled model-id: JDI 0x422a built: 2017
res: 3840x2160 dpi: 260 gamma: 1.2 size: 293x196mm (11.54x7.72")
diag: 353mm (13.9") ratio: 3:2 modes: 3000x2000
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
v: 4.6 Mesa 22.0.2 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Huawei
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
Device-1: Intel Wireless 8265 / 8275 vendor: Huawei driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 3c:00.0
chip-ID: 8086:24fd class-ID: 0280
IF: wlp60s0 state: up mac: <filter>
Device-2: Realtek RTL8152 Fast Ethernet Adapter type: USB driver: r8152
bus-ID: 1-1.4:9 chip-ID: 0bda:8152 class-ID: 0000 serial: <filter>
IF: enp0s20f0u1u4 state: down mac: <filter>
Device-3: Realtek RTL8152 Fast Ethernet Adapter type: USB driver: r8152
bus-ID: 1-3.2.4:11 chip-ID: 0bda:8152 class-ID: 0000 serial: <filter>
IF: enp0s20f0u3u2u4 state: down mac: <filter>
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
bus-ID: 1-5:5 chip-ID: 8087:0a2b class-ID: e001
rpm: 5900 serial: <filter> scheme: MBR
logical: 512 B type: HDD rpm: 7200 serial: <filter> scheme: GPT
ID-1: swap-1 type: zram size: 15.38 GiB used: 1.2 MiB (0.0%)
Read your Android devices' user manuals, to learn what is required for PC connection.
You have to do something in your Android first.
If adb is properly installed in Linux and does not discover any devices, it's not Linux to troubleshoot.
I used to use Win10 and 11 and there were no any problem. That is why I thought it is on Linux side something
SGS:
Some lines missing
Post the last lines too, please.
System Temperatures: cpu: 64.0 C pch: 60.0 C mobo: N/A
Processes: 296 Uptime: 1d 19h 12m wakeups: 130 Memory: 15.38 GiB
used: 5.09 GiB (33.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1490 lib: 362
Shell: Bash (sudo) v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-03-08
Last full system update: 2022-05-02 ↻
KDE connect works but with wire no connection
Do they show up as a USB device using lsusb ?
Borshow:
(it shows charging)
If you want it to appear as a USB device then you have to change that setting on the phone.
Firewall software?
Also try rebooting with phone connected before startup, (sometimes this makes a difference).
Correct. It seems better to post the problem on XDA …
It is not a problem, especially I've tried 3 different phone and a tablet too. and how I said I used these on Win10 and 11 with no any issue
Try a different cable. Not all USB cables provide a data connection; a lot of them support charging only. This is true for many cables that are shipped with the phone.
It's not always easy to tell if a cable serves data by looking at it, but one way to tell is if the cable has the USB logo on it.
Another note worth mentioning is you typically cannot just plug in your phone and immediately access it--usually you need to respond to a prompt on the Android device. The device needs to be unlocked, and then say "yes, allow access to the data" or whatever comes up on the screen.
Usually this prompt comes up automatically when you plug it in, but on some devices (my dinosaur of a phone, for example) it does not and you have to go into the settings menu to turn it on.
Settings->Connected devices->USB and then under "USE USB FOR" select "File Transfer" (default is "No data transfer").
Yes, I know all what you mentioned. I have Xiaomi Mi11 Pro with developer options and everything set up. That is why I think something on the Linux side missing for me.
