inxi -Faz
Kernel: 5.15.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=292a7c42-f67b-4ada-a0f8-70b1ac3e4f61 rw rootflags=subvol=@
Type: Laptop System: LENOVO product: 82EY v: IdeaPad Gaming 3 15ARH05
serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15ARH05
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: FCCN16WW date: 01/05/2021
ID-1: BAT0 charge: 39.7 Wh (95.9%) condition: 41.4/45.0 Wh (92.0%)
volts: 12.7 min: 11.4 model: SMP L19M3PF7 type: Li-poly serial: <filter>
status: N/A cycles: 86
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 2321 high: 3991 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2498 2: 2023
3: 1852 4: 2556 5: 1504 6: 1664 7: 1772 8: 1774 9: 2188 10: 2279 11: 3762
12: 3991 bogomips: 71863
Device-1: NVIDIA TU117M vendor: Lenovo driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f99
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 04f2:b6c2 class-ID: 0e02 serial: <filter>
loaded: modesetting,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
s-diag: 1052mm (41.4")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 92
size: 531x299mm (20.9x11.8") diag: 609mm (24")
Monitor-2: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
Device-1: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x bus-ID: 05:00.5
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2:2 chip-ID: 0c76:161e
Sound Server-1: ALSA v: k5.15.13-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: 2000
bus-ID: 04:00.0 chip-ID: 10ec:c822 class-ID: 0280
bus-ID: 3-3:3 chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 17.23 GiB (3.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8L
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: C04C
temp: 42.9 C scheme: GPT
ID-1: / raw-size: 184.08 GiB size: 184.08 GiB (100.00%)
used: 17.21 GiB (9.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 30.1 MiB (31.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 184.08 GiB size: 184.08 GiB (100.00%)
ID-4: /var/log raw-size: 184.08 GiB size: 184.08 GiB (100.00%)
ID-5: /var/tmp raw-size: 184.08 GiB size: 184.08 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.07 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A
GPU: device: nvidia screen: :0.0 temp: 50 C device: amdgpu temp: 48.0 C
Processes: 312 Uptime: 1h 13m wakeups: 1 Memory: 15.07 GiB
used: 5.2 GiB (34.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1449 lib: 418 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.11
Hello everyone, i'm kind of new to linux and i've got a small but really annoying problem: i can't set my keyboard layout changing shortcut to Alt + Shift.
i am not sure why but looks like there is two different input method frameworks installed with garuda : one can be opened through
system settings>hardware>input devices>keyboard>layouts>Main shortcuts
and another one that you can open with
system settings>personalization>regional settings>input method>configure global options
And for me the second one overrides the fist one most of the time
The problem is that in first one you can make shift + alt your main shortcut, but if you try that on second you will get "Empty" after pressing Alt + shift
i attached a clip for better understanding of my problem video
