Hi to all,
i thimk i broke somthing else and now it is the layout swith function.
i don know the short cut dosent do anything.
i looked at old post and their solutions didnt work for me.
this is post one with solution: post one
and this is the second :post two
Kernel: 6.5.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=4c70d6ff-4940-478a-8c2e-f7784de40edb rw rootflags=subvol=@
resume=UUID=d7f7a46f-3e31-426d-9271-08a4089fcf2f loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Mobo: ASUSTeK model: PRIME B760M-A D4 v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1002
date: 04/07/2023
Info: model: 13th Gen Intel Core i5-13400F bits: 64 type: MST AMCP
process: Intel 7 (10nm) family: 6 model-id: 0xBF (191) stepping: 2
microcode: 0x2E
Topology: cpus: 1x cores: 10 mt: 6 tpc: 2 st: 4 threads: 16 smt: enabled
cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32 KiB, 4x64 KiB
L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 799 high: 800 min/max: 800/4600:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 798 2: 800 3: 800 4: 800
5: 800 6: 799 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 bogomips: 79872
Device-1: NVIDIA GA106 [GeForce RTX 3060] vendor: ASUSTeK driver: nvidia
v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2544 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau,nvidia
Screen-1: 0 s-res: 1920x1080 s-dpi: 90 s-size: 542x301mm (21.34x11.85")
s-diag: 620mm (24.41")
Monitor-1: HDMI-0 pos: primary res: 1920x1080 dpi: 90
size: 544x303mm (21.42x11.93") diag: 623mm (24.52") modes: N/A
Monitor-2: None-1-1 size-res: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.264 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 535.113.01
device-ID: 10de:2544 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.1 (LLVM
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7a50
Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
Device-3: Intel USB PnP Sound Device
lanes: 1 mode: 1.1 bus-ID: 1-8.1:6 chip-ID: 8086:0808 class-ID: 0300
API: ALSA v: k6.5.5-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 4000 bus-ID: 05:00.0
lanes: 1 bus-ID: 06:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9.4:10
chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c0104
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 3.18 TiB used: 1.21 TiB (38.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40A temp: 40.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Transcend model: TS500GESD260C
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.1 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: SSD
serial: <filter> scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Extreme Portable SSD
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 1012 scheme: MBR
model: WD10SPZX-22Z10T0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: HDD rpm: 5400 serial: <filter> scheme: MBR
ID-1: / raw-size: 465.66 GiB size: 465.66 GiB (100.00%)
used: 74.41 GiB (16.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 25.9 MiB (8.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 465.66 GiB size: 465.66 GiB (100.00%)
ID-4: /var/log raw-size: 465.66 GiB size: 465.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 465.66 GiB size: 465.66 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.44 GiB used: 91.2 MiB (0.6%)
ID-2: swap-2 type: partition size: 16.98 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 39.0 C mobo: N/A gpu: nvidia temp: 54 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 55%
Processes: 348 Uptime: 38m wakeups: 5 Memory: total: 16 GiB
available: 15.44 GiB used: 6.12 GiB (39.7%) Init: systemd v: 254
pm: pacman pkgs: 1871 libs: 559 tools: octopi,paru,yay Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-10-04
Last full system update: 2023-10-06
Relevant software: snapper(custom) NetworkManager dracut nvidia-dkms
