I will first start with this…
╭─fenris@fenris in ~ took 11ms
╰─λ garuda-inxi
Kernel: 6.1.70-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=576a4f6d-5c57-475b-8279-4f23d821f833 rw rootflags=subvol=@
quiet resume=UUID=6feff68d-462f-4c25-aead-653957ef83a3 loglevel=3 ibt=off
Type: Desktop Mobo: AZW model: MINI S v: 10 serial: <superuser required>
UEFI: American Megatrends LLC. v: ADLNV104 date: 02/06/2023
Info: model: Intel N100 bits: 64 type: MCP arch: Alder Lake level: v3
note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6
model-id: 0xBE (190) stepping: 0 microcode: 0x12
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 1x2 MiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 700 min/max: 700/3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 700 2: 700 3: 700 4: 700 bogomips: 6452
Device-1: Intel Alder Lake-N [UHD Graphics] driver: i915 v: kernel
arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports: active: HDMI-A-2
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46d1 class-ID: 0300
Display: x11 server: X.Org v: 21.1.10 compositor: xfwm v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Monitor-1: HDMI-A-2 mapped: HDMI-2 model: Acer G247HYL serial: <filter>
built: 2016 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
API: Vulkan v: 1.3.274 layers: 5 device: 0 type: integrated-gpu
name: Intel Graphics (ADL-N) driver: mesa intel v: 23.3.2-arch1.2
device-ID: 8086:46d1 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.2-arch1.2 (LLVM
Device-1: Intel driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:54c8
Device-2: C-Media CM106 Like Sound Device
lanes: 1 mode: 1.1 bus-ID: 1-4.2:6 chip-ID: 0d8c:0102 class-ID: 0300
API: ALSA v: k6.1.70-1-lts status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-1: Intel CNVi: Wi-Fi driver: N/A modules: iwlwifi bus-ID: 00:14.3
chip-ID: 8086:54f0 class-ID: 0280
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: ASIX AX88179 Gigabit Ethernet driver: ax88179_178a type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-4.1:3
chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp0s20f0u4u1 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 8087:0026
Local Storage: total: 1.38 TiB used: 541.88 GiB (38.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: PCIe SSD size: 476.94 GiB
tech: SSD serial: <filter> fw-rev: EHFM90.1 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 16.54 GiB (16.5%)
fs: btrfs dev: /dev/sda3 maj-min: 8:3
used: 584 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 719 GiB size: 719 GiB (100.00%)
used: 97.53 GiB (13.6%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
used: 16.54 GiB (16.5%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.4 GiB used: 122.5 MiB (0.8%)
ID-2: swap-2 type: partition size: 12 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 54.0 C mobo: N/A
Processes: 278 Uptime: 19h 57m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.4 GiB used: 6 GiB (39.0%) Init: systemd v: 255
pm: pacman pkgs: 1459 libs: 434 tools: pamac,paru,yay Shell: Bash v: 5.2.21
running-in: xfce4-terminal inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2023-12-28
Last full system update: 2024-01-05 ↻
Failed units: vmware-workstation-server.service vmware.service
╭─fenris@fenris in ~ took 4s
╰─λ sudo lsusb
[sudo] password for fenris:
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 1bcf:08a0 Sunplus Innovation Technology Inc. Gaming mouse [Philips SPK9304]
Bus 001 Device 003: ID 04f3:0103 Elan Microelectronics Corp. ActiveJet K-2024 Multimedia Keyboard
Bus 001 Device 004: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 005: ID 8087:0026 Intel Corp. AX201 Bluetooth
Bus 001 Device 006: ID 0d8c:0102 C-Media Electronics, Inc. CM106 Like Sound Device
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 002: ID 05e3:0612 Genesys Logic, Inc. Hub
Bus 002 Device 003: ID 0b95:1790 ASIX Electronics Corp. AX88179 Gigabit Ethernet
╭─fenris@fenris in ~ as 🧙 took 2s
╰─λ sudo lspci
00:00.0 Host bridge: Intel Corporation Device 461c
00:02.0 VGA compatible controller: Intel Corporation Alder Lake-N [UHD Graphics]
00:14.0 USB controller: Intel Corporation Device 54ed
00:14.2 RAM memory: Intel Corporation Device 54ef
00:14.3 Network controller: Intel Corporation CNVi: Wi-Fi
00:15.0 Serial bus controller: Intel Corporation Device 54e8
00:15.1 Serial bus controller: Intel Corporation Device 54e9
00:16.0 Communication controller: Intel Corporation Device 54e0
00:17.0 SATA controller: Intel Corporation Device 54d3
00:19.0 Serial bus controller: Intel Corporation Device 54c5
00:19.1 Serial bus controller: Intel Corporation Device 54c6
00:1c.0 PCI bridge: Intel Corporation Device 54be
00:1d.0 PCI bridge: Intel Corporation Device 54b2
00:1e.0 Communication controller: Intel Corporation Device 54a8
00:1e.3 Serial bus controller: Intel Corporation Device 54ab
00:1f.0 ISA bridge: Intel Corporation Device 5481
00:1f.3 Audio device: Intel Corporation Device 54c8
00:1f.4 SMBus: Intel Corporation Device 54a3
00:1f.5 Serial bus controller: Intel Corporation Device 54a4
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
02:00.0 Non-Volatile memory controller: Phison Electronics Corporation PS5015-E15 PCIe3 NVMe Controller (DRAM-less) (rev 01)
╭─fenris@fenris in ~ as 🧙 took 44ms
╰─λ sudo systemctl enable fstrim.timer
Created symlink /etc/systemd/system/timers.target.wants/fstrim.timer → /usr/lib/systemd/system/fstrim.timer.
╭─fenris@fenris in ~ as 🧙 took 838ms
╰─λ inxi -Faz
Type: gather_data_sampling status: Not affected
Type: spec_rstack_overflow status: Not affected
filling, PBRSB-eIBRS: Not affected
Local Storage: total: 1.38 TiB used: 541.9 GiB (38.5%)
tech: SSD serial: <filter> fw-rev: EHFM90.1 temp: 39.9 C scheme: GPT
used: 97.54 GiB (13.6%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-1: swap-1 type: zram size: 15.4 GiB used: 119.2 MiB (0.8%)
System Temperatures: cpu: 56.0 C mobo: N/A
Processes: 277 Uptime: 20h 23m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.4 GiB used: 6.28 GiB (40.8%) Init: systemd v: 255
First of all, I have been looking all over the web how to get WiFi networks to actually function in Garuda, and unfortunately, I have no success with with. However before I can even get to that point, I’m not sure my hardware is even functioning properly to begin with.
So, opening up Menu/Settings/Garuda Settings Manager then selecting Hardware Configuration to see all the installed drivers…I see:
=> Network Controller
- Unknown Device Name (Intel Corporation)
- RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (Realtek Semiconductor Co. Ltd.)
- network-r8168
=> Device Controller
- video-linux
- video-modesetting
When I do the following command to see all the hardware:
╰─λ sudo lspci
I can see my wifi device is on 00:14.3 and my Realtek controller is on 01:00.0 which is what I am using for internet access now. I don’t think Garuda recognises my hardware cause I see no where to put in my SSID and password for my router anywhere.
