Recently sound is not coming from my laptop speakers but when I put headphones then sound is working for headphones. I don't know what is the problem , I tried replacing pulseaudio with pipe wire support as told by others in telegram but nothing changed. Please help me
Read
And post your
inxi -Fxxxza
As text. Even if you think it’s unnecessary.
That way we will know where to start.
This problem seems to crop up regularly on kernel updates. Quite often testing alternate kernels will help.
I'd start with the following in this order:
linux-lts
linux-hardened
linux-mainline
linux-next-git
linux
Be sure you have the corresponding headers installed for each kernel as well.
With Garuda you can have multiple kernels installed at once. It is best to always keep at least 2 kernels installed at all times.
After changing kernel should I restart the system or the change are applied automatically
System: Kernel: 5.11.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=0fc89abe-9b55-4710-b3ef-36589fce7c87
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 2 dm: SDDM
Machine: Type: Laptop System: HP product: HP Pavilion Laptop 14-ce0xxx v: Type1ProductConfigId
Mobo: HP model: 84B9 v: 02.15 serial: <filter> UEFI: Insyde v: F.23 date: 12/25/2020
Battery: ID-1: BAT0 charge: 33.6 Wh (100.0%) condition: 33.6/33.6 Wh (100.0%) volts: 12.6 min: 11.4
model: HP Primary type: Li-ion serial: N/A status: Full
CPU: Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 8E (142) stepping: A (10) microcode: E0 cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
Speed: 3401 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 3401 2: 3401 3: 3400 4: 3401
5: 3400 6: 3400 7: 3400 8: 3400
Graphics: Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo bus-ID: 1-3:3
chip-ID: 0408:5300 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.0.3 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.11.16-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.26 running: no
Network: Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel port: 4040
bus-ID: 02:00.0 chip-ID: 8086:24fb class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-7:4
chip-ID: 8087:0aa7 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
Drives: Local Storage: total: 232.89 GiB used: 15.42 GiB (6.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter>
rev: 4B6Q scheme: GPT
Partition: ID-1: / raw-size: 46.85 GiB size: 46.85 GiB (100.00%) used: 15.38 GiB (32.8%) fs: btrfs
dev: /dev/sda6 maj-min: 8:6
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 38 MiB (39.6%) fs: vfat
dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 46.85 GiB size: 46.85 GiB (100.00%) used: 15.38 GiB (32.8%) fs: btrfs
ID-4: /var/log raw-size: 46.85 GiB size: 46.85 GiB (100.00%) used: 15.38 GiB (32.8%) fs: btrfs
ID-5: /var/tmp raw-size: 46.85 GiB size: 46.85 GiB (100.00%) used: 15.38 GiB (32.8%) fs: btrfs
ID-1: swap-1 type: zram size: 979.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 979.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 979.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 979.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 979.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 979.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 979.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 979.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 42.0 C mobo: N/A
Info: Processes: 220 Uptime: 6m wakeups: 1 Memory: 7.65 GiB used: 1.66 GiB (21.8%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1168 lib: 291
Shell: fish v: 3.2.1 running-in: konsole inxi: 3.3.04
You didn't read "Reporting bugs"
If you include terminal outputs in your post please use the proper output format in your post. Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
@SGS Thanks
I think you need to research things more fully in the future.
Installing any new kernel or driver will never automatically take effect. You must reboot first. At the grub boot menu you must switch kernels at the advanced grub submenu.
This doesn’t look right^^^
Please post:
rfkill list all
lsmod | sort
systemctl status bt.service
Also be sure to put 3 ~~~ before and after any terminal outputs you post for proper code formatting.
rfkill list all
0: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
lsmod | sort
ac97_bus 16384 1 snd_soc_core
acpi_pad 24576 0
acpi_thermal_rel 16384 1 int3400_thermal
aesni_intel 372736 7
af_alg 32768 6 algif_hash,algif_skcipher
agpgart 53248 5 intel_agp,intel_gtt,ttm,nouveau,drm
algif_hash 16384 1
algif_skcipher 16384 1
amdgpu 6574080 0
atkbd 36864 0
blake2b_generic 20480 0
bluetooth 704512 43 btrtl,btintel,btbcm,bnep,btusb,rfcomm
bnep 28672 2
bpf_preload 16384 0
btbcm 20480 1 btusb
btintel 32768 1 btusb
btrfs 1572864 1
btrtl 24576 1 btusb
btusb 65536 0
ccm 20480 6
cdrom 77824 2 hfsplus,hfs
cec 61440 2 drm_kms_helper,i915
cfg80211 978944 3 iwlmvm,iwlwifi,mac80211
cmac 16384 2
coretemp 20480 0
crc16 16384 2 bluetooth,ext4
crc32c_generic 16384 0
crc32c_intel 24576 2
crc32_pclmul 16384 0
crct10dif_pclmul 16384 1
cryptd 24576 3 crypto_simd,ghash_clmulni_intel
crypto_simd 16384 1 aesni_intel
crypto_user 20480 0
dm_mod 159744 0
drm 569344 14 gpu_sched,drm_kms_helper,amdgpu,radeon,i915,ttm,nouveau
drm_kms_helper 278528 4 amdgpu,radeon,i915,nouveau
ecc 36864 1 ecdh_generic
ecdh_generic 16384 1 bluetooth
ext4 929792 0
fat 86016 2 msdos,vfat
fb_sys_fops 16384 1 drm_kms_helper
fuse 163840 1
ghash_clmulni_intel 16384 0
glue_helper 16384 1 aesni_intel
gpu_sched 45056 1 amdgpu
hfs 73728 0
hfsplus 122880 0
hp_accel 28672 0
hp_wireless 16384 0
hp_wmi 20480 0
i2c_algo_bit 16384 4 amdgpu,radeon,i915,nouveau
i2c_i801 36864 0
i2c_smbus 20480 1 i2c_i801
i8042 32768 1 hp_accel
i915 2715648 31
int3400_thermal 20480 0
int3403_thermal 20480 0
int340x_thermal_zone 16384 2 int3403_thermal,processor_thermal_device
intel_agp 24576 0
intel_cstate 20480 0
intel_gtt 24576 2 intel_agp,i915
intel_pch_thermal 16384 0
intel_pmc_bxt 16384 1 iTCO_wdt
intel_powerclamp 20480 0
intel_rapl_common 28672 2 intel_rapl_msr,processor_thermal_device
intel_rapl_msr 20480 0
intel_soc_dts_iosf 20480 1 processor_thermal_device
intel_uncore 172032 0
intel_xhci_usb_role_switch 16384 0
ip_tables 32768 0
irqbypass 16384 1 kvm
iTCO_vendor_support 16384 1 iTCO_wdt
iTCO_wdt 16384 0
iwlmvm 479232 0
iwlwifi 417792 1 iwlmvm
jbd2 151552 1 ext4
jfs 217088 0
joydev 28672 0
kvm 933888 1 kvm_intel
kvm_intel 327680 0
ledtrig_audio 16384 1 snd_hda_codec_generic
libarc4 16384 1 mac80211
libcrc32c 16384 2 btrfs,xfs
libphy 151552 3 r8169,mdio_devres,realtek
libps2 20480 2 atkbd,psmouse
lis3lv02d 28672 1 hp_accel
mac80211 1101824 1 iwlmvm
mac_hid 16384 0
mbcache 16384 1 ext4
mc 61440 4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
mdio_devres 16384 1 r8169
minix 45056 0
Module Size Used by
mousedev 24576 0
msdos 20480 0
mxm_wmi 16384 1 nouveau
nouveau 2355200 0
processor_thermal_device 24576 0
psmouse 184320 0
r8169 102400 0
radeon 1658880 0
raid6_pq 122880 1 btrfs
rapl 16384 0
realtek 24576 1
rfcomm 90112 16
rfkill 28672 10 hp_wmi,bluetooth,cfg80211
rng_core 16384 1 tpm
roles 16384 1 intel_xhci_usb_role_switch
serio 28672 7 serio_raw,atkbd,hp_accel,psmouse,i8042
serio_raw 20480 0
snd 114688 16 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_compress,snd_soc_cor
e,snd_pcm
snd_compress 32768 1 snd_soc_core
snd_hda_codec 172032 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek,snd_soc_hdac_hda
snd_hda_codec_generic 98304 1 snd_hda_codec_realtek
snd_hda_codec_hdmi 73728 1
snd_hda_codec_realtek 147456 1
snd_hda_core 106496 8 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_soc_hdac_hda,snd_soc_skl
snd_hda_ext_core 36864 2 snd_soc_hdac_hda,snd_soc_skl
snd_hda_intel 57344 3
snd_hwdep 16384 1 snd_hda_codec
snd_intel_dspcfg 28672 2 snd_hda_intel,snd_soc_skl
snd_pcm 147456 9 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,soundwire_intel,snd_compress,snd_soc_core,snd_soc_skl,snd_hda_core,snd_pcm_dmaengine
snd_pcm_dmaengine 16384 1 snd_soc_core
snd_soc_acpi 16384 2 snd_soc_acpi_intel_match,snd_soc_skl
snd_soc_acpi_intel_match 45056 1 snd_soc_skl
snd_soc_core 323584 3 soundwire_intel,snd_soc_hdac_hda,snd_soc_skl
snd_soc_hdac_hda 24576 1 snd_soc_skl
snd_soc_skl 180224 0
snd_soc_sst_dsp 36864 1 snd_soc_skl
snd_soc_sst_ipc 20480 1 snd_soc_skl
snd_timer 45056 1 snd_pcm
soundcore 16384 1 snd
soundwire_bus 90112 3 soundwire_intel,soundwire_generic_allocation,soundwire_cadence
soundwire_cadence 36864 1 soundwire_intel
soundwire_generic_allocation 16384 1 soundwire_intel
soundwire_intel 45056 1 snd_intel_dspcfg
sparse_keymap 16384 1 hp_wmi
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
tpm 73728 3 tpm_tis,tpm_crb,tpm_tis_core
tpm_crb 20480 0
tpm_tis 16384 0
tpm_tis_core 28672 1 tpm_tis
ttm 114688 3 amdgpu,radeon,nouveau
ufs 94208 0
uinput 20480 0
usbhid 65536 0
uvcvideo 114688 0
vfat 24576 1
video 53248 2 i915,nouveau
videobuf2_common 65536 2 videobuf2_v4l2,uvcvideo
videobuf2_memops 20480 1 videobuf2_vmalloc
videobuf2_v4l2 36864 1 uvcvideo
videobuf2_vmalloc 20480 1 uvcvideo
videodev 294912 3 videobuf2_v4l2,uvcvideo,videobuf2_common
wmi 36864 4 hp_wmi,wmi_bmof,mxm_wmi,nouveau
wmi_bmof 16384 0
x86_pkg_temp_thermal 20480 0
xfs 2015232 0
xhci_pci 20480 0
xhci_pci_renesas 20480 1 xhci_pci
xor 24576 1 btrfs
x_tables 53248 1 ip_tables
zram 32768 8
Unit bt.service could not be found.
Thank you for guiding me. Now i have learnt how to post properly.
Now I have read reporting bugs and learnt how to post properly. Thank you.
This is not a chat and there is no prize for the most posts.
greetings SGS
You are welcome.
Your bluetooth is soft blocked.
Search online for how to remove a soft block.
unblocked it!
rfkill list all
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Soft blocked: no
Hard blocked: no
Is there any difference after unblocking?
Does it stay unblocked after rebooting?
Please post:
systemctl status bluetooth.service
No idea what happened but in the morning sound is working from speakers. Thanks all for ur help
Your bluetooth will not work if it is soft blocked, so I'm sure removing the soft block helped.
This is because restart is needed to apply changes, which you did this morning.
