No Fan control for CPU fans/case Desktop
Hello Garuda users,
After being transferred from the Garuda Forum to a gaming forum where things weren’t great and having all of my accounts wiped, I wanted to give this another shot to see if it was someone from here or one of my neighbours once again. Hopefully, it won’t occur again this time the.
I came here to ask for help because I was experiencing multiple issues with a game that wasn’t game-specific.
So after the hack, my computer and accounts were reconfigured, but at least one fan control issue persists. Despite my attempts, of stripping my PC down and cleaning it re-building everything changing the fan control in BIOS hasn’t improved it at all.
One of the reasons I moved from Windows 10 Pro to Garuda Linux is because, due to the Z270X-Gaming 5 motherboard I use, no more Bios updates that don’t crash the MB from 2016 are available for it and a fellow work mate suggested I go with a Linux Distro.
I went here to https://wiki.archlinux.org/title try to make sense of what could be modified and to try to figure out how to control my fans so they would be quieter. All I could manage to do here was enable/inspect the sensors; as for adjusting, there was a lot I didn’t understand and may just be a little over my head with tweaking “pwmconfig” files most of the other forums/sites pointed back to the the Arch wiki site. A step by step so to speak would be ideal but was unabale to find one
Side Note:
I utilised https://getfancontrol.com/ on Windows 10 Pro it was much easier when I was using W10Pro.
In the long run (i e side note) I was wondering if there was an easier way to control fans on Linux most of the other sites I visited was for different Distros, laptops and playing with the pwmconfig files which isn’t my cup of tea unless it can put in simpler terms or a how to create one or how to configure voltages. Power usage fan specs and voltage is a recipe for disaster for me with out knowing what the correct voltages are a or being a programmer/developer.
I was thinking of manual way maybe a fan controller with an attenuation switch, for; while, I am not gaming of course would only be for the case fans to be turned down a notch or two.
In the interim I’ll just keep my fingers crossed and hope that it doesn’t blow up or burn out the fans or maybe even get hacked again, I have left my Garuda inxi file below if you need any thing else journal errors, Systemd Analyze or last pacman logs let me now I have them in a folder ready to go.
Kernel: 6.10.0-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=d0f8eb0a-2d16-4cc4-9be1-6a244d1ed372 rw rootflags=subvol=@
loglevel=3 splash ibt=off
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Desktop Mobo: Gigabyte model: Z270X-Gaming 5
UEFI-[Legacy]: American Megatrends v: F4 date: 11/18/2016
Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 875 high: 901 min/max: 800/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 901 3: 800 4: 900
5: 900 6: 900 7: 900 8: 800 bogomips: 63999
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte driver: nvidia
v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-06; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 2
link-max: lanes: 16 ports: active: none off: DP-1,HDMI-A-2,HDMI-A-3
empty: DVI-D-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1c82 class-ID: 0300
d-rect: 5760x1080 display-ID: 0
Monitor-1: DP-1 pos: right res: 1920x1080 size: N/A modes: N/A
Monitor-2: HDMI-A-2 pos: primary,left res: 1920x1080 size: N/A modes: N/A
Monitor-3: HDMI-A-3 pos: center res: 1920x1080 size: N/A modes: N/A
x11: drv: zink inactive: device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
memory: 3.91 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1050 Ti driver: nvidia v: 555.58.02 device-ID: 10de:1c82
18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.4-arch1.2 (LLVM 18.1.8)
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
Device-2: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 2
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-3: SteelSeries ApS Arctis Nova 7
lanes: 1 mode: 1.1 bus-ID: 1-13:4 chip-ID: 1038:2202 class-ID: 0300
API: ALSA v: k6.10.0-zen1-2-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Gigabyte
driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 06:00.0 chip-ID: 1969:e0b1 class-ID: 0200
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
Local Storage: total: 8.42 TiB used: 234.36 GiB (2.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 950 PRO 256GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B0QBXX7 temp: 29.9 C
scheme: MBR
model: WD40EFRX-68WT0N0 size: 3.64 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
model: WD40EFRX-68N32N0 size: 3.64 TiB block-size: physical: 4096 B
fw-rev: 0A82 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 840 EVO 1TB
tech: SSD serial: <filter> fw-rev: DB6Q scheme: MBR
used: 234.36 GiB (25.2%) fs: btrfs dev: /dev/sdc1 maj-min: 8:33
ID-1: swap-1 type: zram size: 62.74 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 31.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0 fan-2: 0 fan-3: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.33 vbat: 3.27
Memory: total: 64 GiB note: est. available: 62.74 GiB used: 4.87 GiB (7.8%)
Processes: 315 Power: uptime: 51m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.04 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2260 libs: 568 tools: octopi,pamac,paru
Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date:     2024-06-19
Last full system update: 2024-07-25
Fan speed control:
https://wiki.archlinux.org/title informative
https://www.reddit.com/r/linux_gaming/comments/15u6ghz/system_fan_control/
GitHub - Maldela/fancontrol-gui: GUI for Fancontrol. It uses the KAuth module of the KDE Frameworks 5 to write the generated config file. Furthermore it communicates with systemd via dbus to control the fancontrol service. If you want to compile without systemd support set the -DNO_SYSTEMD option.
This is outdated and I had no control what so ever for fans that I could use or even utilise all I could do with this was freeze my system up once installed from Octopi I read through the info and followed the instructions to the letter but yeah for some reason I had to uninstall it as I am just guessing it is for a laptop hardware specific to Del as it works fine on my 2003 Del studio laptop running Garuda Linux Multi boot W10pro 11 pro Kali Linux and Ubuntu 20.24 and this laptop is nearly 20 years old and I haven’t had half the problems that I have had wit the desktop half its age. So I guess it goes without saying they are Laptop Distro’s and maybe the reason they don’t work as well and of course being windows.
Fan Speed and CPU Temp not showing plus Fan Controller not working
I also came across this on my search and would like to know how this guy got the equaliser working for my desktop, for laptop it just works.
I have no doubts that they are on a laptop as this also works fine on my laptop.
Did you replace the thermal paste of CPU and GPU too?
A neighbor has a computer with a 1050ti. Last year, we noticed that both the paste and the thermal pads were completely brittle and dried out.
Fans are also subject to ageing. The bearings wear out gradually and most people only notice when the temperatures rise or the worn bearings of the fans make noise.
Thank you for the thought yes I did for the CPU on idle runs at a constant 25°C but not the GPU as it has run at 53°C constant no fans it has been the same since I bought it and has never over heated.
I don’t know it just works.
When I have enough money to buy some new case fans I will replace them.
As I stated above the fans on my case run at full speed constantly and it is only since I installed Garuda Linux.
I have started to remove some programs from Garuda Linux and have found this has quelled the sound some what, while doing this I came across a program called CoreCtl and if this is a correct indication of where my CPU is at then I proceeded to play with the the global profiles and am starting to make some progress with that and removing programs I don’t use.
With using the CoreCtl and watching whats happening I found that some of my programs where using the internet and CPU usage without my knowledge I still have one more to find as I still get CPU spike and at the same time I get the same spike of the internet as well once I find this program I will be removing it as well.
So through process of elimination I think I will fix it the sound level is much lower than original installation in the last couple of hours or so.
thanks again.
As I have not stopped searching for a solution to fan control on my search I have found and installed this and am trialling it as I type this.
CoolerControl / CoolerControl · GitLab
So far I have found this to be a change in fan speed…
I have followed this and found something new
Just a quick edit on my system this works but this guy got me thinking so I have since open my case to find that my fans have been swap and connect to the wrong power source and this is the reason for my fans on full speed and not being detected by bios or any firmware for fan control.
Check your devices this may or may not have been the same problem as you but it all helps.
