Hey y'all,
Loving Garuda so far, save for one thing. I've installed as a dual-boot next to Windows 10 on an HP Pavillion 15 laptop and in linux, I have no sound. This was an issue with Ubuntu 21 as well, it seems any linux distro I install is not seeing my sound card.
So, I came to you for help! I've followed a few different sound issue threads but was not able to get this figured out yet. I'm brand new to Garuda, and only had minor prior experience with Ubuntu when I used it over 5 years ago for gaming and some web browsing.
Where I'm at:
The 'muted' sound icon on taskbar, doesn't matter if I used keys to vol+/vol- or mute, this never changes. There is no dialog that pops up showing volume changes either when I'm using the keyboard shortcuts (fn + f8 for example is vol+ on my laptop). When I click configure audo devices to open the sound settings, there's just a blank page where I imagine my sound card should be.
What can I do to get some help here, I'm hoping to learn!
SGS
25 April 2021 19:07
#2
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
It's especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
Hit the </> button in Discource Post Toolbar.
Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy your…
please
and post
inxi -Fxxxza
as text! Even if you personally think it is unnecessary.
and
corezero:
If I write a suggestion or a solution, you will have to read it anyway.
Since reading is not avoidable, why don't you start reading Garuda wiki for ways to solve your basic problems and how to post a request ?
╭─[email protected] in ~
╰─λ inxi -Fxxxza
System: Kernel: 5.11.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=5c054efc-e3a4-4ce2-aee9-f313b2d91b4f
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 2 dm: SDDM
Machine: Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-cx0xxx v: Type1ProductConfigId
Mobo: HP model: 8478 v: 70.30 serial: <filter> UEFI: Insyde v: F.04 date: 03/31/2018
Battery: ID-1: BAT1 charge: 43.8 Wh (100.0%) condition: 43.8/52.8 Wh (83.1%) volts: 13.0 min: 11.6
model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter> status: Full
CPU: Info: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 9E (158) stepping: A (10) microcode: DE cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 36799
Speed: 4001 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 4001 2: 4000 3: 4000 4: 4000
5: 4000 6: 4000 7: 4000 8: 4001
Graphics: Device-1: Intel UHD Graphics 630 vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard driver: nvidia
v: 465.24.02 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c8d class-ID: 0300
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD Integrated Webcam type: USB
driver: uvcvideo bus-ID: 1-5:3 chip-ID: 05c8:03bc class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.0.3 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard driver: sof-audio-pci
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:a348
Sound Server-1: ALSA v: k5.11.16-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Network: Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel port: 5000
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8
bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 5060
bus-ID: 00:17.0 chip-ID: 8086.282a rev: 10 class-ID: 0104
Drives: Local Storage: total: 465.76 GiB used: 21.18 GiB (4.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDBNCE5000PNC size: 465.76 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter>
rev: 40RL scheme: GPT
Partition: ID-1: / raw-size: 80.45 GiB size: 80.45 GiB (100.00%) used: 21.15 GiB (26.3%) fs: btrfs
dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%) used: 25.5 MiB (26.9%) fs: vfat
dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 80.45 GiB size: 80.45 GiB (100.00%) used: 21.15 GiB (26.3%) fs: btrfs
ID-4: /var/log raw-size: 80.45 GiB size: 80.45 GiB (100.00%) used: 21.15 GiB (26.3%) fs: btrfs
ID-5: /var/tmp raw-size: 80.45 GiB size: 80.45 GiB (100.00%) used: 21.15 GiB (26.3%) fs: btrfs
ID-1: swap-1 type: zram size: 980.2 MiB used: 45 MiB (4.6%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 980.2 MiB used: 45.7 MiB (4.7%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 980.2 MiB used: 53.1 MiB (5.4%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 980.2 MiB used: 54.6 MiB (5.6%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 980.2 MiB used: 43.8 MiB (4.5%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 980.2 MiB used: 47.2 MiB (4.8%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 980.2 MiB used: 50.7 MiB (5.2%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 980.2 MiB used: 40 MiB (4.1%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 57.0 C mobo: 29.8 C
Info: Processes: 274 Uptime: 34m wakeups: 1 Memory: 7.66 GiB used: 2.55 GiB (33.3%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1212 lib: 296
Shell: fish v: 3.2.1 running-in: konsole inxi: 3.3.04
Reading up while I post this, thank you for the links!
There is another (solved) thread with the same laptop here:
After some more digging I actually found a solution to my issue in an askubuntu forum answer. The issue as was pointed out by @petsam , was that the incorrect audio driver was loaded.
The way to solve it for me was to perform the following:
sudo nvim /etc/default/grub
Change
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash ..."
to
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash snd_hda_intel.dmic_detect=0 ..."
and then update grub with:
sudo grub-mkconfig -o /boot/grub/grub.cfg
and reboot.
As I unders…
You're a rockstar. I followed along and there's glorious sound coming from the speakers now. Thank you for the help!
system
closed
27 April 2021 19:45
#7
