Kernel: 6.1.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=de841ed7-b183-4377-967d-8cd9c33d91db rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASRock model: B450 Pro4 serial: <superuser required>
UEFI: American Megatrends v: P5.00 date: 05/10/2021
Info: model: AMD Ryzen 7 1700 bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001138
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1534 high: 2684 min/max: 1550/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 1376 2: 1550
3: 1550 4: 1376 5: 1349 6: 1377 7: 1375 8: 1550 9: 1378 10: 1550 11: 1550
12: 1550 13: 1550 14: 1409 15: 1376 16: 2684 bogomips: 95992
Device-1: AMD Vega 10 XL/XT [Radeon RX 56/64] vendor: Sapphire
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 0b:00.0 chip-ID: 1002:687f
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LG (GoldStar) MP59G
serial: <filter> built: 2015 res: 1920x1080 hz: 75 dpi: 102 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: AMD Radeon RX Vega (vega10 LLVM
15.0.7 DRM 3.49 6.1.7-zen1-1-zen) direct render: Yes
Device-1: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 1102:0012 class-ID: 0403
Device-2: AMD Vega 10 HDMI Audio [Radeon 56/64] driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.1
chip-ID: 1002:aaf8 class-ID: 0403
Sound API: ALSA v: k6.1.7-zen1-1-zen running: yes
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 2.04 TiB used: 1.62 TiB (79.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SV300S37A120G
type: SSD serial: <filter> rev: BBF0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Silicon Power model: SPCC M.2 SSD
type: SSD serial: <filter> rev: 21.1 scheme: GPT
ID-1: / raw-size: 68.36 GiB size: 68.36 GiB (100.00%)
used: 11.47 GiB (16.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 27.6 MiB (28.8%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-3: /home raw-size: 68.36 GiB size: 68.36 GiB (100.00%)
ID-4: /var/log raw-size: 68.36 GiB size: 68.36 GiB (100.00%)
ID-5: /var/tmp raw-size: 68.36 GiB size: 68.36 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.54 GiB used: 3 MiB (0.0%) priority: 100
System Temperatures: cpu: 32.9 C mobo: N/A gpu: amdgpu temp: 53.0 C
mem: 51.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1338
Processes: 351 Uptime: 1h 28m wakeups: 0 Memory: 15.54 GiB
used: 3.97 GiB (25.5%) Init: systemd v: 252 default: graphical
pkgs: 1484 libs: 459 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2023-01-20
Last full system update: 2023-01-20 ↻
Please, we need more details
and welcome in the forum.
Hello Garuda users.
Before opening a new help request, please search the Arch and Garuda Wiki’s, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum’s search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
I mean analog 5.1 sound from creative sundblaster recon3d PCI cards. I have a Cretive 5.1 set connected to this card using 3 jack cables. I have already tested all the ways from different forums. And alsa and pulse and pipewire and nothing helped. Only analog stereo is visible in the audio settings. 3 months already trying to do something about it and nothing. And that's how it is on every system (Ubuntu, Mint, Garuda, etc.) I don't want to go back to windows but I also don't want to have such poor sound quality. Please help.
Thank you and best regards.
There are several open kernel bugs filtering by "CA0132".
https://bugzilla.kernel.org/buglist.cgi?quicksearch=CA0132
Maybe many are not relevant, but some seem to me to be.
Missing (or poor) Linux support from the vendor should be probably blamed in my opinion...
thank you
